Author Topic: Upper radiator hose I.D.? Confirmed at 25mm Thanks all.  (Read 2892 times)
« on: July 09, 2014, 06:07:55 PM »
No luck on the forum, on the web, in the parts fiche, or in the manual. Does anyone know offhand?
« Last Edit: July 10, 2014, 01:14:07 PM by gPink »
Re: Upper radiator hose I.D.?
« Reply #1 on: July 09, 2014, 06:18:12 PM »
Trying to find a replacement other than Kaw?
« Reply #2 on: July 09, 2014, 06:23:30 PM »
Thinking about adding a digital temp gauge.
« Reply #3 on: July 10, 2014, 04:15:49 AM »
Paranoid wondering if a rock jams up a fan, otherwise you know very well the cooling systems on these bikes are 'rock' solid.
« Reply #4 on: July 10, 2014, 04:43:32 AM »
just a farkel
Offline Rembrant
« Reply #5 on: July 10, 2014, 05:11:25 AM »
Just drill and tap the hose...that will work won't it?...lol. Make sure you do it when the bike is cool though...lol.
Seriously...
I don't know the size, but it's around 1" or 25mm.
You thinking of installing a tee fitting in the hose?
I'd install it in the big hose on the right hand side of the engine, somewhere convenient between the engine and the rad...this will give you the most accurate temp imho.
Good luck. I'd like to see how this is set up. I think it's a great idea.
Rem 8)
« Reply #6 on: July 10, 2014, 05:19:41 AM »
It'll go something like this...
Offline Rembrant
« Reply #7 on: July 10, 2014, 05:23:30 AM »
Cool beans, I like it.
You could measure the hose OD, and then subtract the wall thickness (twice of course).
Wall thickness would be 3/16"-ish...?
« Reply #8 on: July 10, 2014, 10:26:13 AM »
Not sure what all you got stuffed in under the right side top black side cover, but pretty sure you could reach down thru there, and mic' the fitting on the radiator...that would be the male diameter you seek... ;)
Offline datsaxman@hotmail.com
« Reply #9 on: July 10, 2014, 12:59:07 PM »
The big hoses are 25mm == 1".  Got a set sitting in the toolbox.
saxman
161.5RWHP on the dyno
Formerly Silverdammit!
« Reply #10 on: July 10, 2014, 01:12:21 PM »
Thanks for the confirmation.
