Author Topic: [Reference] Fuel filter  (Read 21664 times)
Offline Kwikasfuki
    • Uk GTR Forum
« on: June 28, 2014, 07:46:07 PM »
This is for documentary purposes only. Don't do this yourself - get a qualified mechanic to do it. This involves fuel which is highly combustible. Again, get qualified mechanic.
Since Aussie Dave passed away, the pictures he took have more or less disappeared from the net. This is an attempt to document that process again. Thanks to motocopter from the zggtr.org forum for investigating on an alternative replacement fileter than can be used.
The tank/fuel pump removal is documented in the Kawasaki manual. Refer to the manual for detail instructions.
A little as possible fuel needs to remain in the tank.
Re: [Reference] Fuel filter
« Reply #1 on: June 28, 2014, 07:51:05 PM »
Where's the beer and fire extinguisher?  Seriously though, very timely and thank you very much, Asif.
Offline Kwikasfuki
    • Uk GTR Forum
« Reply #2 on: June 28, 2014, 07:53:06 PM »
Lol, I'm teetotal, and I did have a fire extinguisher and water hose pipe to hand
« Reply #3 on: June 28, 2014, 07:53:52 PM »
 :thumbs: :goodpost: :hail: :chugbeer:
Offline Gsun
« Reply #4 on: June 28, 2014, 10:01:09 PM »
Have they never heard of an external filter??? That's a lot of work! Is it a recommended service every so often?
Offline Big Casino
« Reply #5 on: June 28, 2014, 10:27:15 PM »
THANKYOU!
« Reply #6 on: June 28, 2014, 10:56:58 PM »
Not a 'service' per se.  Quite a few vehicles these days have the filter with the pump in the tank.  Pretty sure all my Toyotas have that and well as my daughter's Nissan Quest.  If the Kwak dealer has to replace the filter it's new pump time.  However, I think cleaning it out and replacing the filter every 50k miles wouldn't be a bad idea.
« Reply #7 on: June 28, 2014, 11:14:24 PM »
What an incredibly awesome posting and procedure!  Thanks!  And you attached all the photos to the forum instead of using external links, so they won't disappear in a year- great job.  I am just surprised the forum software allowed you to post so many and didn't barf.
Offline Rembrant
« Reply #8 on: June 29, 2014, 03:46:46 AM »
 :goodpost:
Nicely done. That write-up took a lot of work. That will be very helpful to many C14 owners.
Rem 8)
Offline 3redzxs
« Reply #9 on: June 29, 2014, 04:51:37 AM »
Great! Bookmarked for when it's needed. Thanks for going through all the trouble.
« Reply #10 on: June 29, 2014, 05:38:03 AM »
Jim, do your forum magic with this one.
Offline rocknrod
  • 2013 C14 - Blue
« Reply #11 on: June 30, 2014, 07:38:10 AM »
Here is a file you can download and print if you need it to do the job: https://app.box.com/s/7sw60d5qhxus8j8undbv
« Reply #12 on: June 30, 2014, 08:17:39 AM »
Outstanding Chief. That will in the back of my FSM. Thanks.
« Reply #13 on: June 30, 2014, 08:57:39 AM »
Outstanding write up and pics. This should be a permanent thread on C14 maintenance.
Offline rocknrod
  • 2013 C14 - Blue
« Reply #14 on: June 30, 2014, 09:01:53 AM »
You can call me by my first name :)
« Reply #15 on: June 30, 2014, 09:04:22 AM »
Yes Master.  :rotflmao:
Offline Kwikasfuki
    • Uk GTR Forum
« Reply #16 on: June 30, 2014, 01:44:47 PM »
With reference to this pic
Its probably best to block the pipes from the tank as fuel could leak when manipulating the tank (all depends on how much of the fuel is drained from the tank)
Offline 4cedars
« Reply #17 on: June 30, 2014, 02:15:53 PM »
Very nicely done  :finger_fing11:
IBA# 45862
MTF Tourers Assistant
« Reply #18 on: July 02, 2014, 04:31:29 AM »
Stumbled upon this...
http://www.fuelpumpfactory.com/Kawasaki-fuel-pump-Concours-14-s/6323.htm
This is just the pump itself.....for $50 bucks....new!  You would have to disassemble the existing pump structure but you have a new pump if you need it.  Unfortunately you can't buy the O-ring (670E5075) or the filter (49019-0013) with it and their cart system for buying it appears to be broken at the moment...yet another option.
We don't see inoperative fuel pumps, we do see clogged fuel filters..
« Reply #19 on: July 02, 2014, 10:42:47 AM »
read the ad closely, says it comes WITH a strainer (filter), and if you do the "view larger photo" thing, and pic the numbers at the bottom (1, 2, or 3) it shows the filter also...
just saying....
