Author Topic: mid pipe options  (Read 3993 times)
Offline petepro
mid pipe options
« on: June 20, 2014, 04:30:29 AM »
Looks like a have a hole punched in the mid pipe.
Wondering if anyone has had this piece welded or managed to
find a replacement one.
The OEM part finder shows it as part of the complete exhaust!
Does it come apart or is it already welded together.
I have a feeling this is going to be a tough job as I have no experience with bike exhaust.
2012 Concours 14abs - 2013 - Current
2002 BMW R1150R - 2012-2013
1995 Honda 750 Nighthawk - 2001-2009
1984 Suzuki GS1150ES - 1987
Re: mid pipe options
« Reply #1 on: June 20, 2014, 04:37:50 AM »
How big a hole?  JB Weld?
Offline petepro
« Reply #2 on: June 20, 2014, 04:49:57 AM »
total area is about the size of a dime.    Do you think JB weld would hold?
Offline petepro
« Reply #3 on: June 20, 2014, 04:51:50 AM »
Isn't that pipe going to get too hot for this stuff?
« Reply #4 on: June 20, 2014, 04:53:52 AM »
It might but that's a bit big of a hole for JB Weld I would think unless you bridged it with a small piece of metal.
http://www.jbweld.com/faqs/   500 degrees....I don't think the mid-pipe gets that hot.
Offline petepro
« Reply #5 on: June 20, 2014, 04:56:40 AM »
I agree Jim,  It looks like one clamp and a couple springs are all that is holding it on.   Might take it off
and bring it to a local welder.   I'm sure the welder would appreciate if I didn't try JB weld first.
Have you ever removed the midpipe?  is it more complicated than I imagine?
« Reply #6 on: June 20, 2014, 04:58:01 AM »
Never had the pleasure of removing it.  Others here have.  ZG most likely.  I don't think that there's anything original left on his bike but him.
« Reply #7 on: June 20, 2014, 05:05:36 AM »
soup can and hose clamps  ;)
No problem to r & r. A competent welder can lay a patch over it.
Offline petepro
« Reply #8 on: June 20, 2014, 05:56:59 AM »
Once again.....  Thanks for all the support and quick replies.
This kind of support is what makes this forum great.
Pete
« Reply #9 on: June 20, 2014, 07:26:54 AM »
 :rotflmao: :rotflmao: :rotflmao:
« Reply #10 on: June 20, 2014, 09:57:42 AM »
So ... um ... how did you get a dime size hole in your mid pipe??  ???
« Reply #11 on: June 20, 2014, 11:35:57 AM »
If the hole is on the bottom or an accessible location, I would think a welder could do it while the pipe was still on the bike. Might have to put the bike on a stand or lift it with a cherry picker but that would be easier then pulling the exhaust.
Offline petepro
« Reply #12 on: June 21, 2014, 04:42:14 AM »
Road Debris.
Not sure what it was but with my amazing skill I hit it perfectly.
My talented driving allowed me to strike it in such a way that
I tested its density against the exhaust and removed it from the
roadway.   I'm doing my part to keep the road clear for other
riders.
Or I was checking my gauges and didn't have time to avoid it.
« Reply #13 on: June 21, 2014, 05:55:03 AM »
Think what that could have done to a tire.  :o
