Author Topic: * Price Reduced Again * 2008 C14 ABS Nicely Set-up for a Tall Rider  (Read 2342 times)
Offline ridingfar
2008 Concours 14 GTR ABS - St. Louis area
~23,500 Miles
$6800 OBO
ridingfar2cu at gmail dot com
Never down, well maintained and nicely set up for a taller 50+ rider with:
- 2" handlebar risers
- Sergeant standard touring seat
- Cee Bailey Euro-cut Mini windshield (and OEM, not installed but included)
- Throttlemeister bar-end weights/throttle lock
- Buell pegs (~1.5" lower)
- Grip Heaters
- BMW ribbed grips
- G2 Ergonomics Throttle Tamer
- Led turn signals in mirror housing (rear facing)
- License plate LED brake light bars
- Brake light flasher
- Cox radiator guard
- Project D frame sliders / tip-over protectors
- Murph's bearinged shifter mod
- TechMount accessory bar mount w/ RJ12 power plug
- MetalBender's air deflectors (black)
- MagKnight color matched tank protector
- RKA bag liners/soft luggage
- Hard bags "pinned" to lower mounts
- Fender Extender on front fender
Performance:
Stock = ~135 hp, Current =~150 hp
- Two Brothers carbon fiber can (stock can not installed but included)
- Stock headers w/ cats removed (stock headers w/ cats not installed but included)
- Power Commander V with FuelMoto custom map
- Throttle body "flies" removed (but also included)
Maintenance:
- Oil changed every ~3000 miles w/ full synthetic oil and premium filters
- Differential fluid changed every ~6000 miles
- Steering head bearings re-lubed and re-torqued @ 6748 miles
- Brake and clutch fluid changed ~annually
- New battery @ 11782 miles/ 11-27-09
- Air filter changed @ 11820 miles/ 2-6-10 (new OEM air filter also included)
- New front brake rotors and pads @ 14720 miles/ 11-26-10
- Valve adjustment, throttle body sync, coolant change, new spark plugs, exhaust air injection hose plugged, forks flushed and  fork oil changed @ 14775 miles/ 4-16-11 (valve adjust before/after valve clearance and current shim size records included)
- Kawasaki Shop Manual
- Maintenance "how-to" DVD's
Tires:
- Front Michelin PR3 w/ ~5k left
- Rear Michelin PR2 w/ 1k-2k left
- New Rear Michelin PR3  (un-mounted)
« Last Edit: August 18, 2014, 01:28:56 PM by ridingfar »
Offline ridingfar
Re: 2008 C14 ABS Nicely Set-up for a Tall Rider
« Reply #1 on: May 09, 2014, 12:45:06 PM »
Bump to the top...
Offline POLOMAN69
« Reply #2 on: May 29, 2014, 05:55:35 AM »
Please send me your Email , Thanx
Offline Arod
« Reply #3 on: May 30, 2014, 02:13:31 PM »
Nice bike.  wish you were closer.  GLWS.
Offline ridingfar
Re: 2008 C14 ABS Nicely Set-up for a Tall Rider * Price Reduced
« Reply #4 on: June 27, 2014, 01:00:56 PM »
Bump for lower price...
Offline ridingfar
Re: 2008 C14 ABS Nicely Set-up for a Tall Rider * Price Reduced Again *
« Reply #5 on: July 21, 2014, 11:02:54 AM »
TTT
Offline ridingfar
Re: * Price Reduced Again * 2008 C14 ABS Nicely Set-up for a Tall Rider
« Reply #6 on: August 18, 2014, 01:30:47 PM »
Really Folks - somebody needs to steal...I mean buy...this great bike.
Will help deliver, assist a Fly and Buy, whatever. It really should be out on the road with one of you chasing adventure....I'm just sayin'
