Author Topic: Rear Wheel Disassembly for Powder Coat Question  (Read 2875 times)
Offline xsv
« on: April 20, 2014, 08:06:02 PM »
I am getting ready to powder coat my 09 silver wheels to black.  On the rear wheel I removed bearings, rotors, valve stem and TPMS.
I just want to confirm there is nothing else I can break down.  I am looking at the rear hub and trying to understand what I am seeing within the hub?
Can't seem to find anything in the service manual or with a search.
2015 Triumph Trophy SE
Offline xsv
Re: Rear Wheel Disassembly for Powder Coat Question
« Reply #1 on: April 20, 2014, 08:31:11 PM »
OK...I found the gigantic snap ring and removed it, but am really unsure about what I am even looking at let alone what I am removing.  EDIT...ok hub coupling and hub shock damper....
OK...disregard...found it in the manual. Work the hub coupling out and remove rubber shock damper....boy that might have been a mess when they baked it during the powdercoating!! :)
« Reply #2 on: April 20, 2014, 09:07:37 PM »
Yes, you need to remove all of that and the bearings too.
Offline xsv
« Reply #3 on: April 20, 2014, 09:13:39 PM »
Yep...that is what it looks like now!
Off topic...you had them powder coat inside of the hub where the damper goes?
« Reply #4 on: April 20, 2014, 09:27:19 PM »
That pic of my gold wheels were actually plated, not powder coated...
http://www.zggtr.org/index.php?topic=13506.0
But it was the only pic I could find in my library that showed that side of the rear wheel...
I've done a couple other sets of wheels too though and yes I had that section powder coated as well.
http://www.zggtr.org/index.php?topic=15761.msg193948#msg193948
http://www.zggtr.org/index.php?topic=17.msg21208#msg21208
Offline xsv
« Reply #5 on: April 20, 2014, 09:30:14 PM »
Thanks.....I've seen your variety of colors.  That is what got me interested in changing the color of mine.  That all black look is what I am going for!
Thanks for the input.
« Reply #6 on: April 20, 2014, 09:37:43 PM »
No worries, post up some pics after you get em done and mounted!  :cool: :chugbeer:
Offline swojo95
« Reply #7 on: April 21, 2014, 04:32:32 AM »
Jay, did you ever get a chance to see what the bike looks like with the gold rims on with the black plastics?  With the Ohlins and maybe the emblems painted gold, I think that might look pretty good?
« Reply #8 on: April 21, 2014, 07:24:35 AM »
Nope, once I moved forward with the green highlights on the black bodywork set I like the green wheels with it...  :)
