Author Topic: Seat Mount  (Read 2266 times)
Offline KCCINDY
Seat Mount
« on: April 18, 2014, 08:27:10 AM »
Hi,
I'm new at the Concours thing but I have been riding for about 40 years. That is ti say I'm not TOTALLY incompetent. I got the seat off my C14 but can't get the *@#%ing!!!! thing back on properly. Help!
Thanks,
KCC
Offline clogan
Re: Seat Mount
« Reply #1 on: April 18, 2014, 08:38:49 AM »
There's only one catch: the little tab thing on the seat bottom fits into the slot on the bike frame, and catches. Maybe some lube would help?
If you bend over, you can see the tab as it, hopefully, slides into the slot. I always have to watch mine, or else I miss the slot, and the seat fails to catch. Try some silicone spray lube.
2010 Neptune blue C14
2009 blue KLR
2013 DRZ400
Offline Stephen.G.Fiddes
Re: Seat Mount
« Reply #2 on: April 18, 2014, 09:41:01 AM »
Thats a lot of Bending over and lubing as it slides into the slot...  :censored: :censored: :censored:
EDIT:  To make this post not completely useless, Make sure everything is lined up (Including the slot mentioned above) and the clip is as well.  Take the key out of the seat lock, and push down on the seat.  If that doesn't work, punch it down.  Don't worry, it's softer than your butt thinks it is.
1982 Honda CM450E - SOLD
jirod
Re: Seat Mount
« Reply #3 on: April 18, 2014, 11:58:37 AM »
Check that the two rubber blocks are still glued to the frame. Thet look like two wedges about 1" to tbe side. They are known to come loose after a few years and might be in the way.
Re: Seat Mount
« Reply #4 on: April 19, 2014, 10:06:38 AM »
Welcome aboard!
I have never reattached a stock seat before, because after I took off the stock, the Sargent World low seat went on.  And it is a nightmare to get back on the bike (not exactly easy to get off the bike either, but that is a lot easier).  I tried showing the dealer this last time, they ended up just leaving the thing unlatched the whole time.  I like the seat a lot, just not getting it on/off.
Offline freebird6
  • In a big country...
Re: Seat Mount
« Reply #5 on: April 19, 2014, 07:42:54 PM »
Welcome aboard!
I can't get my seat to latch at all since I got it back from Laam. The other seat I have locks in fine. I keep hoping and screwing around with it every few days and sit and ponder both to see if there is something I have missed but I am unable to figure it out.
2008 Concours
2007 Mean Streak
99 r1100rt
