Author Topic: FZ1 Fuze block under Corbin Seat  (Read 4675 times)
Offline xsv
« on: March 26, 2014, 06:59:02 AM »
...I could not find the specific information in a search....
I had my FZ1 Fuze block on top of my ECU under the stock seat.  Well that is not going to happen with the new Corbin seat.  I have read that it will fit in the tool box if you cut away the sides of the tool box.  However, it seems as if most remove the FZ1 base when doing that.....so is it necessary to remove the fuze block base to get this to fit in the tool kit under the Corbin Seat?
I'd prefer to keep the fuze block somewhere under the seat.
Thanks!
2015 Triumph Trophy SE
Re: FZ1 Fuze block under Corbin Seat
« Reply #1 on: March 26, 2014, 07:12:47 AM »
I have the Corbin seat, here's some pics of my install.
http://www.zggtr.org/index.php?topic=10985.0
Offline xsv
« Reply #2 on: March 26, 2014, 07:45:13 AM »
I looked at that location.  I was hoping to mount it in a spot that if I wanted to add more accessories that I would not have to remove it in order to make the connection.  By pressing one side of the box all the way up to the seat mount it would make that difficult!
« Reply #3 on: March 26, 2014, 09:47:15 AM »
It comes off in less than a minute if you want to make another connection.
Offline xsv
« Reply #4 on: March 26, 2014, 11:02:40 AM »
After posting I remembered the modeling clay valve clearance check method.  Found some modeling clay and went to work.
I mocked it up with the tool box lid cut off and the fuze block with base.  Turns out there is .40 inch clearance between the top of the block and bottom of the seat.
Thanks for the input.
Offline Gsun
« Reply #5 on: March 26, 2014, 08:58:09 PM »
I put mine under the left upper (black) fairing. I had to make a mount for it that bolts to the mirror mount. It is easily accessible and most of the stuff you add is in the front so the wiring is easier.
Offline C14lvr
« Reply #6 on: March 26, 2014, 09:42:30 PM »
I put mine in the tool box's place, took the tool box out.
« Reply #7 on: March 27, 2014, 10:29:40 AM »
I put mine INSIDE the tool box.... ;)
Offline Stubby
  • 2011 Silver ABS Concours 1400
« Reply #8 on: March 27, 2014, 04:32:11 PM »
XSV sounds like you got it figgered out but here is the post I did on putting the fuze block in the tool holder.
http://www.zggtr.org/index.php?topic=15897.0
it's better to ask forgiveness than permission..... So I have been told
Offline xsv
« Reply #9 on: March 27, 2014, 09:32:56 PM »
Finally had time to finish today and it looks JUST like that! LOL
Sometimes I have a heck of a time finding posts with this website's search feature.
Thanks!
Offline Smokeyzx
« Reply #10 on: March 28, 2014, 11:56:53 AM »
Colorado
2013 Blue
