Author Topic: Carb Air mix needle screw  (Read 1529 times)
Offline Jet86
  • California
« on: March 16, 2014, 08:21:40 PM »
I forgot to ask this but what is the install order of the tiny o-ring and washer  :-\
I tried to use Common sense and hope i got it right, i put the spring on the needle then the washer then o-ring and then screwed it down til it softly bottomed then Two full turns out.
Offline Nosmo
Re: Carb Air mix needle screw
« Reply #1 on: March 16, 2014, 10:21:54 PM »
That's correct.  Good luck getting things sorted.
