With the shield still mounted on the bike, I applied masking tape to the shield. Then I measured in from the outer edges and marked the center line of the shield. Next, I measured down from the center top edge (3.75" in my cace) and placed a mark. With those referances, I place several more marks. After I had it dotted lines so to speak, I'd step back and take a look. If I didn't like something (not semetrical from side to side or just the overall shape) I'd just apply more masking tape over the marks that I wanted to change and then re-mark.
When I was satisfied with the shape, I removed the shield from the bike and using soft jaw clamps and a protective towel, I clamped the shield down to my work table. Was only able to clamp down one side, but when I got half way thru the cut, I re-clamped it on the other side. I used a standard jigsaw (some call it an isolating saw) to cut just to the wast side (about a 1/16 of an inch) of the line that I had marked. Then I re-mounted the shield to determine if I wanted to make any other changes. While it was mounted, I mounted the bike and raised & lowered the shield to see what it would look like from the rider's possition and I even took the bike out for a short ride when I was 90% sure that I was happy with the shape. I would then decide if I was happy with it or if I wanted to make some more adjustments (round off the corners more, cut it shorter, add the Cal Sci opening, etc....).
When I was happy with the shape and cutout, I removed the shield from the bike and used an isolating sander on the outer edges and a drimel with a small sanding drum for the Cal Sci opening to clean it up to the line. When the shape was done, I took a propane tourch and lightly flamed the edges to take out all of the sanding marks.
As far as the tint.... sprayed the inside of the shield with tail light spray tent.
Sorry for the book!!!!
