Author Topic: HID projector headlight install  (Read 10000 times)
Offline jwolffie
« on: March 09, 2014, 05:24:33 PM »
I decided I wanted better light and I also wanted the front of the bike blacked out so I bought a projector headlight retrofit kit from "The Retrofit Source" http://www.theretrofitsource.com/complete-retrofit-kits/motorcycle-stage-iii-kit-dual-headlight.html#.UxztS_ldWuI
The kit came very complete and was fairly easy to install and the lights are crazy bright too without annoying other drivers. I got the 4300K bulbs because they are the brightest and whitest, and I got the 70mm angel eye LED's. The angel eyes are way brighter than I expected, they could be used as day time running lights without the low beams on. The low beams have a very white and bright light that goes down the road about twice as far as the stock headlights, and they have a very cool blue line right at the low beam cut off line. It gives a very noticeable flicker to oncoming traffic. Here is what it takes to do it:
First remove all of the plastic from the bike from the gas tank forward, including the windshield and the cover under the windshield, and the mirrors, and then slide the headlight housing out the front of the bike. (see photos) Next bake the housing in the oven to loosen the glue (230 for 6 minutes worked for me) or use a heat gun on the seam (probably easier) and pry the headlight housing apart. Use some cheep home depot gloves because it will be too hot to hold. While I had the housings apart I sprayed all of the chrome parts with oven cleaner to remove the chrome and then I painted everything satin black with high temp engine paint including the shrouds for the projectors. I attached the angel eyes to the shrouds using very fine wire in three places and attached the entire projector to the existing headlight buckets using the hole for the old bulbs. Next test fire the system and make sure the projectors are level by twisting them slightly and close up the headlight and reheat it and then finish closing it with a pair of pliers. I then mounted the ballasts to the two existing screws at the bottom of the headlight housing below the city lights, and wired the angel eyes into the city light sub-harness so they come on with the ignition. (see photo) I ran the provided harness to the battery and plugged it into the right side headlight wire for a trigger signal and ran the rest of the wires to the headlights. Used lots of zip ties too. I put everything back together and aimed the headlights and I was done. This was a two day weekend project but well worth it.
Click on the photos to make them larger.
« Last Edit: March 10, 2014, 10:28:20 PM by jwolffie »
Black 2011
Full Delkevic no cat, Ivan's Flash, Projector headlights, Dunlop Q3+
Valentine 1 with JBV1 on phone
Offline jwolffie
Re: HID projector headlight install
« Reply #1 on: March 09, 2014, 05:26:44 PM »
More photos:
Black 2011
Offline jwolffie
« Reply #2 on: March 09, 2014, 05:28:11 PM »
Last ones:
Black 2011
« Reply #3 on: March 09, 2014, 05:48:53 PM »
Thanks for sharing.  (Do post some pixs of the finished assembly from the front, you forgot!)  I have been, overall, disappointed with my non-projector HID conversion.  It is more light, but the pattern is pretty sucky, not putting light where I really need it.  I am very spoiled by the *excellent* projector HID's in my G37.  Maybe this will be a greatly improved option for some people looking to gain the extra lighting but while also having a reasonable pattern that is both useful for the rider as well as all the other traffic being subjected to it.
It is probably too much for me to tackle, especially after having already invested time and money in a non-projector kit.  Maybe one day when LED projectors have some innovation I won't be able to resist anymore...
« Reply #4 on: March 09, 2014, 05:53:14 PM »
Nice.
I started on that project but never finished it. Hmmmmm. Maybe I can see if I can re- start that....
Offline jwolffie
« Reply #5 on: March 09, 2014, 06:01:34 PM »
close up, If I get any closer all I get is reflection from the outer lens of the headlight.
Black 2011
« Reply #6 on: March 09, 2014, 09:32:19 PM »
 :finger_fing11: :chugbeer:
Offline Stephen.G.Fiddes
« Reply #7 on: March 09, 2014, 10:47:21 PM »
This is something I will be doing before next winter. I had projo's (TRS Mini H1) retro'd on my Ninja 650 and I hate not having them now...
Im considering going with the mini D2S. Can you send some photos of the install process?  I know theres PLENTY of room in there (unlike my 650 which I had to cut up the bucket to mount) but i wanna see some details before I go splitting the only housing I have.
Also, does that kit come with the mini-H1 or D2S?  I want the D2S for the extra heat handling to run 55W HIDs.
In return, when I finally do mine I'll post massive details about my retrofit.
1982 Honda CM450E - SOLD
« Reply #8 on: March 10, 2014, 05:38:09 AM »
Morimoto 3Five mini H1 35 watt bi-xeonon
http://www.theretrofitsource.com/components/bulbs/morimoto-3five-h1-bulbs.html
« Reply #9 on: March 10, 2014, 07:37:31 AM »
Should have clarified.  He mentioned the "motorcycle 2-light kit" which I believe comes with the MH1's, which can only handle 35w bulbs without melting.  I want 55w for the extra brightness.
Now that I'm halfway awake, also:   Did you have to do any trimming?  I know the MH1 and MD2S come with a rubber/silicone washer type piece thats supposed to go between the housing reflector bowl, and the reflector cup for the projector.  I plan on omitting that piece, and instead using JB weld there to eliveate (sp?) any shifting. (Ive heard people say that when using the rubber piece theres enough movement allowed that it can move.  I don't plan on removing the lights ever.)
« Reply #10 on: March 10, 2014, 08:17:47 AM »
Ahh! Another issue i just remembered.
How did you remedy the issue of the low beams turning off when thhe high beams are activated?
« Reply #11 on: March 10, 2014, 09:35:28 AM »
Use a large capacitor on the control feed side of the low beam headlights. I ran into this problem retrofitting autos with HIDs. When switching to high beams, the low beam circuit is shut off for a fraction of a second; that is enough to cause the lights to go out and re- arc to start up again. A large capacitor (I believe mine is 4,700 microFarads) will hold the voltage high for long enough to step over this loss of signal voltage.
« Reply #12 on: March 10, 2014, 06:49:06 PM »
But on the connie the low beams are completely shut off when the highs are turned on, unless you hold down the pass button. (Which I guess you could rewire the switch so both switches did the pass function off highs on without shutting off the lows?)
« Reply #13 on: March 10, 2014, 08:04:57 PM »
How did you remedy the issue of the low beams turning off when the high beams are activated?
I don't know about the above system, but the HID lamps in both my car and bike have a single element.  There is no "high beam" and "low beam" lamp, just one lamp that always burns.   When the mode is switched on the bike, it physically moves the lamp in and out with a solenoid, changing the angle of the light on the reflector.    When the mode is switched on the projectors in the car, it raises or lowers a shroud via a solenoid, allowing or blocking light that would go in the high-beam range.
I had assumed all modern HID worked one of the ways I just described.
Offline jwolffie
« Reply #14 on: March 10, 2014, 08:53:48 PM »
The kit I bought came with a wiring harness that has the following connections:
Battery +
Battery -
Input from 1 headlight socket ( the connector that hooks up to the stock bulbs )
2 Ballast power connections (Ballast 12V + and - )
2 Connectors for the high beam solenoid (moves the shield to give you high beams)
It also contains a inline box that takes the signal from the headlight switch and uses it for high beams, it uses battery power to keep the headlights lit.
It was all plug and play and very easy, they have lots of good YouTube video how-to's that you can watch first also.
I would have taken more assembly photos but I was in a big hurry to get it done in 1 weekend because it is my commuter. My wife wasn't too happy with me baking the paint on the headlight parts for 20 minutes at 200 degrees in her oven to make sure the paint was dry either. (I sent her shopping first)
Flash to pass still works too
Black 2011
Offline jwolffie
« Reply #15 on: March 10, 2014, 10:25:48 PM »
No trimming was needed and yes I used the silicone washer on the install. There is a tiny wiggle with the washer but it causes the lights to look like they flicker to on coming traffic, at least they see me. :o
Black 2011
Offline jwolffie
« Reply #16 on: March 10, 2014, 10:30:04 PM »
They make an upgrade kit for people that already have HID, it is less money too.
Black 2011
Offline jwolffie
« Reply #17 on: March 10, 2014, 10:41:08 PM »
here are some of Brian's great photos of the housing disassembled: http://www.zggtr.org/index.php?topic=10405.0
Black 2011
« Reply #18 on: March 11, 2014, 12:37:38 AM »
Right, but the TRS kits (I've done these before) use the low-beam signal to power the HID Ballasts, and the high-beam signal to drop the shutter and raise the cutoff. If thw low-beam signal cuts out when you turn on the high-beams, that kindof defeats the purpose because you lose your headlights.
On my 650 it wasnt a problem because the low-beam bulb stayed on when the high beam was turned on (that STUPID one-side low one side high some MFRs like to do....)
If im understanding this correctly:
That inline p&p box has a capacitor inside that maintains the signal to the ballasts during the transition? (As was mentioned above)
I know on some vehicles you can modify a relay by snipping a prong off and that stops certain lights from turning off.
Thats a no-go for me. JB Weld it will be haha.
Just glad i wont have to cut it up like I did my 650. One wasnt perfectly lined up, so after a while I cut it all apart to fix it, and still had it tilted a bit..... Was so freaking annoying. I like the idea of being able to set the level in the bike, then re-remove the housing and JB weld the projos in place.
« Reply #19 on: March 11, 2014, 05:44:21 AM »
OK, got it.  I seem to have missed that point of it before now.  I am not sure how they addressed that in my kit, but it is not a problem.  Perhaps they did use a capacitor or something, like Brian pointed out earlier.  I can't remember that far back now, or if I ever even knew :)
