Author Topic: camchain tensioner removal  (Read 1957 times)
Offline jtk1531
  • Country: my
« on: February 13, 2014, 08:02:58 PM »
hello all,
while doing the valve adjustment, i lost the new camchain tensioner gasket that i bought.
i thought i could reuse back the old tensioner gasket, but it's leaking oil when i had the engine running.
is it safe to remove just the tensioner to replace the gasket, without removing everything else? i'm just wondering if there's a possibility that the cam chain might jump a teeth if it happens that some valve pushes the cam lobe off when tension on the chain is released?
Re: camchain tensioner removal
« Reply #1 on: February 13, 2014, 09:22:39 PM »
Yes, you can remove and replace the cam chain tensioner without touching anything else, just do not turn the engine over while the CCT is out.
My memory is a little foggy here but isn't the CCt 'gasket' an O-ring? Or am I thinking of an APE manual tensioner? Or something else entirely (happens with old age)?
hello all,
Offline jtk1531
  • Country: my
« Reply #2 on: February 13, 2014, 10:27:23 PM »
thank you!
the gasket for the original CCT uses those paper-thin gasket with the same shape as the base of the CCT. it's the APE tensioner that uses the o-ring inside the adjuster bolt (if i recall correctly from some forum threads discussing on APE tensioners...)
