Author Topic: digital display  (Read 11103 times)
Offline Jaxter
digital display
« on: June 11, 2011, 06:42:39 PM »
which screen to you use most?
I find myself leaving mine on out side temperature then occasionally togle thru to see the tire pressure, when the fuel guage gets low I pit it on range. I never leave it on voltage.
I've Never Had A Better Day
Bob
Re: digital display
« Reply #1 on: June 11, 2011, 07:04:56 PM »
The 08 didn't have the outside temp display. So mine had an external, external outside temp display that was always on! On the OEM display though was almost always on the tire pressures! So I technically was on both outside temps and tire pressure!  ;D
Offline So Cal Joe
Re: digital display
« Reply #2 on: June 11, 2011, 08:54:09 PM »
I leave mine on AVERAGE MPG
Re: digital display
« Reply #3 on: June 11, 2011, 08:55:48 PM »
I leave mine on voltage when it is really cold out so I can see how much power our heated clothing is using. Often on tire pressure otherwise and just recently, on a long trip, I started using the range display for the first time ever.
Offline lt1
  • 2008 C14
Re: digital display
« Reply #4 on: June 11, 2011, 08:56:16 PM »
Almost always on tire pressure.  In cold weather, I'd use the voltage display if I was using heated gear, especially 2-up.
Only rarely will I use the other diplays, and usually only briefly.
'08 model - aftermarket ambient temp display.
Eyes, Brain, Hands.  Repeat.
Offline lt1
  • 2008 C14
Re: digital display
« Reply #5 on: June 11, 2011, 08:57:55 PM »
Did you take a long trip recently, Brian?  Why don't you tell us about it?   ::)
Re: digital display
« Reply #6 on: June 11, 2011, 09:20:32 PM »
Always on tire pressure.......
Offline metzgerf16
Re: digital display
« Reply #7 on: June 11, 2011, 11:07:36 PM »
For local riding, mine stays on tire pressure.  I can get a good idea of tire temps that way.  On long rides through the desert or mountains, I'll use the range calculator as well.
"You serious, Clark?"
'09 Red Concours- Sargent seat, Area-P exhaust, BMC filter, PC-V, flies out, PR2's, Murph's risers
'06 Ninja zx10r- Dear tiny baby Jesus, it's fast!
Bob
Re: digital display
« Reply #8 on: June 12, 2011, 03:34:17 AM »
http://www.zggtr.org/index.php?topic=1441.0
Re: digital display
« Reply #9 on: June 12, 2011, 05:41:42 AM »
Tire pressure...
Offline CigarSki®
  • Newb again?
Re: digital display
« Reply #10 on: June 12, 2011, 05:50:54 AM »
Temp
Wayne Sikorski aka CigarSki
2010 ZG1400 - South Jersey
COG 9250
Offline jjsC6
Re: digital display
« Reply #11 on: June 12, 2011, 05:58:12 AM »
Either temperature or tire pressure.  Look at it this way, if tire pressure does go down much the big red light is going to come on.  I mostly switch to tire pressure mode when I'm running the twisties hard where even a slow leak could effect handling.
Jim
2010 Concours - Sold Feb 2013
Current bikes....
Re: digital display
« Reply #12 on: June 12, 2011, 07:49:34 AM »
Tire pressure for me too.
Offline S.Ga.Rider
Re: digital display
« Reply #13 on: June 12, 2011, 07:59:52 AM »
I leave mine on tire pressure.
Flathead
Re: digital display
« Reply #14 on: June 12, 2011, 08:01:36 AM »
Mainly current MPG
Re: digital display
« Reply #15 on: June 12, 2011, 01:24:48 PM »
I usually do exactly what you do-  Temp, then occasionally look at tire pressures and range.  It is a shame with such a large screen that they didn't put more of those things on at the same time or have that as an option.
You should have made the posting a poll :)
« Last Edit: June 12, 2011, 06:20:50 PM by maxtog »
Re: digital display
« Reply #16 on: June 12, 2011, 01:32:41 PM »
Yeah, I rode the peninsular between a couple of cricks. Will post details after I get back to the other side if the peninsular.  ;)
Offline GVmerle
Re: digital display
« Reply #17 on: June 12, 2011, 03:42:37 PM »
Temperature
Re: digital display
« Reply #18 on: June 12, 2011, 04:59:42 PM »
Tire pressure...
Offline mkorn
Re: digital display
« Reply #19 on: June 12, 2011, 06:39:31 PM »
When i first got mine it was on MPG ... but now it is almost always on tire pressure.
2009 C14 ABS
2002 750 Nighthawk (sold)
2006 DRz 400s
