Author Topic: Heated Grips Installed  (Read 5694 times)
Offline texrider
« on: December 04, 2013, 07:16:46 PM »
Just put this Oxford Sport heated grip kit on my '09, and it worked out great  8)
Wish I'd gotten around to it sooner. They've got a good feel to the grip, and of course they get quite toasty!
The controller is easy to use and looks good on the bracket they give with it.
Two warm thumbs up  ;D
2014 Valkyrie
Re: Heated Grips Installed
« Reply #1 on: December 04, 2013, 09:34:39 PM »
Yeah, that is a nice bracket/controller
« Reply #2 on: December 04, 2013, 09:56:39 PM »
Grats TR!  :thumbs: :chugbeer:
« Reply #3 on: December 04, 2013, 11:24:22 PM »
nice!
Offline 12menzer
« Reply #4 on: December 05, 2013, 10:28:45 AM »
Looks great.  Is that the "sports style" grip Oxford sells?
How hard was the install?
Offline texrider
« Reply #5 on: December 05, 2013, 07:08:12 PM »
Yes it is, and not too difficult.
I was even able to remove the stock grips with no damage to them.
Wiring was simply tied in to the accessory outlet behind the right dash panel, since I wanted a switched source, and that circuit is already fused for 10 amps.
Bit of patience with cable routings and ties is all. The bracket is sweet and easy with all hardware provided in kit.
http://www.ebay.com/itm/380762337575?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
2014 Valkyrie
Offline PH14
« Reply #6 on: December 06, 2013, 01:07:04 PM »
How are the grips themselves? I was looking at these and wonder about the diameter. I hated the stock grips since they were too small in diameter and installed the ones from Murph's. Mine is a 2009. Are these larger in diameter than the stock 2009 grips?
Also, how are they for vibration damping? I read the review of the touring model and someone complained about that.
« Reply #7 on: December 06, 2013, 01:21:10 PM »
http://www.vitalmx.com/video_frame_sources/2403?width=780&height=440
Another option!!  I will be getting a set for the EXC, reports to come.
Offline wildnphx
« Reply #8 on: December 08, 2013, 11:59:27 PM »
Hurry up I'm itching to spend money :)
Offline lonekazoo
« Reply #9 on: December 10, 2013, 10:36:23 PM »
I'm shopping for heated grips for my '08, and those do look cool.  Things I don't like:  You have to control each side individually, and to put both on high takes 12 clicks.  Also, I've read that they're very difficult to operate with gloves on, especially while riding.
Offline wildnphx
« Reply #10 on: December 10, 2013, 10:48:35 PM »
Problems solved with heat troller controller instead of the oxford one...
« Last Edit: December 11, 2013, 01:03:25 AM by wildnphx »
« Reply #11 on: December 10, 2013, 11:24:49 PM »
On order, I should have a pair within the next week.  From what Daryl told me they are light years ahead of anything else.  I'll post up as soon as I have a pair.
Offline wildnphx
« Reply #12 on: December 11, 2013, 01:02:58 AM »
I also have the grips as well as heat troller on order...  I am also doing ZX14 forks :)
Offline lonekazoo
« Reply #13 on: December 11, 2013, 07:37:12 AM »
I was referring to a previous reply, about the A'ME grips.  Everything is embedded in the grips (power button, LED status light, controller).  The grips themselves are supposed to be top notch.  They even come with the throttle tube and cable cam.   They get wired directly to the battery, and shut off when they detect battery discharge.
http://www.amegrips.com/motorcyclestreetheated/sport-bike-heated-chicane-grip
There are a couple youtube and web reviews about them, and it turns out they have some drawbacks, but still on my list, along with the Oxfords.
« Reply #14 on: December 11, 2013, 09:22:05 AM »
Same, these are the ones.
« Reply #15 on: December 13, 2013, 11:37:45 AM »
OH, I'm so getting me some A'ME Chicane Grips after XMAS! Thanks for the link.
« Reply #16 on: December 13, 2013, 11:52:31 AM »
the $5 ebay from China heated grips are  illegal knockoffs of our high end ones
