Author Topic: What shim kit size range to get for valves?  (Read 13263 times)
Offline theAmazingKickstand
« on: November 20, 2013, 10:19:46 PM »
Hey all,
I'm going to adjust my valves over Thanksgiving and wanted to buy a shim kit. It seems that the kits come in roughly 1.70 -2.9 and then 3.0 to 3.9.
What sizes should I be expecting to use? Am I just not looking at the correct kits?
I adjusted valves on my Buell and all of them required 2.xx shims. I made the mistake of buying them individually from the Harley store and spent about $60 + wasted half the day getting to the store an back.
If someone has a link to what kit to order and where that would be great. I just looked on Amazon.
Also a link to the valve cover gasket and oil steaming leaky O-ring would be great too.
Thank You.
Offline jsa
Re: What shim kit size range to get for valves?
« Reply #1 on: November 20, 2013, 10:31:46 PM »
I have been involved in shim changes on 3 different bikes and the installed shims were between 2.23 and 2.38.
Offline feelergaugephil
« Reply #2 on: November 20, 2013, 11:40:27 PM »
I believe I got a shim kit hot cams or something like that for my Kawasaki ZRX 1200, this kit is the same for all Concours.
I shimmed my 08 with it, no issues.
Check ebay, I got mine from there.
Dont take my LOW post count as being a new Connie owner, I have been with the "other site" before it imploded........
13 Connie dressed in blue
« Reply #3 on: November 21, 2013, 08:49:14 AM »
The thinner kit.
The kit will probably work for you but remember, the kits do not contain all the sizes (there are shims available that are exactly half- way between the shim sizes in the kits) and I believe each kit only contians three of each size; it is possible that you may need more of the same size than the kit will provide. Not trying to talk you out of buying a kit, just pointing out possible results of doing it that way.
Now OFFTOPIC:
Does this thread title remind anyone besides me of the GREATEST FORUM THREAD OF ALL TIME? The Famous Haroldo and his 47 page valve adjusting thread? That thread had everything- thrills, chills, spills, two tows to the dealer, and was essentially endless. I miss Haroldo and I miss that thread. At the end of my life, I fully expect that thread to flash before my eyes..... well, maybe not flash but play out again in real time.... which will make me immortal I think.  :rotflmao:
Hey all,
Thank You.
Offline jsa
« Reply #4 on: November 21, 2013, 10:03:53 AM »
The thinner kit.
Very true.  Shim kits normally have 3 shims in each size.  If you have to pull cams to change shims you might as well change all of them so each valve is close to the loose edge.  JakeWilson.com sells shims in half sizes for $1.49 each, I bought 3 each in the half sizes from 2.18 to 2.28 and a couple of extras in the full size in that range.  I changed all 16 shims but was able to swap 10 of the OEM shims.  I had a lot of unused shims but it wasn't that expensive and they fit most of the bikes with shim under bucket valve trains.
« Reply #5 on: November 21, 2013, 10:39:24 AM »
  JakeWilson.com sells shims in half sizes for $1.49 each, I bought 3 each in the half sizes from 2.18 to 2.28 and a couple of extras in the full size in that range. ...
I went to that site, and cannot find the shims you speak of for $1.50 each....
have a link?
with regards to correct shim sizes for the C14 (other bikes may not be as close as these are) the Hot Cams Kits just don't do the job, they are 90% out of the range you will be needing.
Your best bet is to swap shims at a Kaw dealer, or at a Honda dealer. They both have the correct increments to get you right to the edge without waste.
Start off by contacting both Kaw and Honda dealers, and speak directly to the man in charge of service, ask him nicely if they will swap shims with you...it works.
You will need to get in there and measure clearances on all valves, then remove the cams and measure each shim, replacing them in their original positions don't pull them all out at once, too much chance of horrendous mishaps doing that.
calculate the needed shim differences, and then figure which ones you can re-purpose and swap.
While you have each shim bucket out, also Mic the head thickness of them as they differ also, and swapping a bucket's position in some instances goes a long way to saving a shim....
it seams like it is simpler to buy a kit, but really it's a waste of time and money, as will will ALLWAYS have to get one that doesn't come in the kit.
for reference, here is my first shim map, showing shims and buckets swapped, and what needed to be replaced.
best of luck...
Offline jsa
« Reply #6 on: November 21, 2013, 11:57:12 AM »
 JakeWilson.com sold shims (at that time)  in half sizes for $1.49 each, but it looks like current price is now $1.99 a shim....still a pretty good buy for me since the local dealer charges $8.00 a shim, does not carry half sizes, and will not exchange shims.
http://www.jakewilson.com/All-Vehicles/3998/26634/Pro-X-Valve-Shim
« Last Edit: November 22, 2013, 07:58:42 AM by jsa »
« Reply #7 on: November 21, 2013, 02:02:44 PM »
Yes, Brian, it certainly does...
« Reply #8 on: November 22, 2013, 03:53:53 AM »
JakeWilson.com sold shims (at that time)  in half sizes for $1.49 each, but it looks like current price is now $1.99 a shim....still a pretty good buy for me since the local dealer charges $8.00 a shim and will not exchange sizes.
Thanks for the link!!!! I selected a 2011 KAWASAKI ZX14R as my bike and the site provided the 9.48 O.D. (which is the size of the Kaw shims).
Here's the link to the 2011 KAWASAKI ZX14R Shim page on Jake Wilson:
http://www.jakewilson.com/p/3998/26634/Pro-X-Valve-Shim?v=10019
« Reply #9 on: November 22, 2013, 10:56:46 AM »
COOL!!
it's also nice they supply shims in the .025mm increments, and actually go down to 1.20mm, Kaw only shows the shims going down to 1.75mm for the C14.... not that I think we would ever need to go that far without doing a valve job....heheheh
thanks for that link!
« Reply #10 on: November 22, 2013, 10:52:25 PM »
Thank you all. Is the consesus that I should just get my measurements and drive to the Concours store? (which is relatively close)
Ordering individually for $2 would be great but this is my daily commuter so it has to be running by Monday. Hopefully the dealers open that weekend.
Whos gotta link to the that poor souls valve adjustment fiasco?
Offline jsa
« Reply #11 on: November 23, 2013, 07:44:29 AM »
I would not only find out if the dealer was open that weekend, I would find out of they carry half size shims.  I needed 8 half sized shims for my valve adjustment and 5 of those were ones that I purchased in advance.  As it turned out, I broke even dollar wise on buying the shims in advance but I had all the sizes I needed.....and a lot of extra shims for the next valve adjustment (there are several of us using the same shim kit, we replace what we use from the kit).
« Reply #12 on: November 23, 2013, 09:39:11 AM »
I believe you will find that there is actually a fairly narrow range of shims used on a C-14, now where near the range of typical kits. I believe you could order, say, 4 of each of perhaps 4 shim sizes and have a pretty good shot at having enough shims on hand. Please understand that that is only a reasonable prediction, not any type of guarantee.
If by 'poor soul' and 'fiasco' you mean Haroldo, I am afraid that went to digital heaven when this forum was born again. And it was not a fiasco, it was much, much worse, and better, and funnier than that. Truly epic. I miss Haroldo- he is the stuff of legend.... :-)  Superman and Batman are merely imaginary entities while Haroldo, greater than any mere superhero, is a real, flesh- and- blood "doer of things". And once seen, the 'things' and the 'do' simply cannot be forgotten.  ;D
« Reply #13 on: November 23, 2013, 10:25:35 AM »
All hail, Haroldo!  :hail:
« Reply #14 on: November 23, 2013, 08:52:21 PM »
Haroldo, a true legend.  Home grown and not forgotten.  I wonder if he is still researching the poor soul who received his bike without oil?
Offline spatten
« Reply #15 on: November 23, 2013, 09:04:56 PM »
"If you have to pull cams to change shims you might as well change all of them so each valve is close to the loose edge. "
So the clearance on these engines never goes loose?  It only goes tight?
« Reply #16 on: November 23, 2013, 09:10:38 PM »
We chat ever now and then. Last story he told me involved a [Triumph I think], some bent crash bars, gasoline, a phone book and a torch. Of course it did not go well or directly but the twists and turns you just could not believe. His neighbors must live either awe or fear- perhaps a kind of terrified awe. The writers at 20th Century- Fox got nothin' on Haroldo, and I truly mean that as a compliment.
Remember when he lost the dowel from the valve cover and had a little breakdown? I said 'Haroldo, you are in a garage, right? The bike is in the garage and so is the valve cover. Hence, the dowel MUST be somewhere in the garage.... When he finally found it I remember the sun breaking out all over the US of A. Ah.... good times. :-)
Never met him in person but would consider it a personal honor to do so. Any scars incurred during said meeting would only be icing on the cake. "Oh, the eyepatch? Well, that was from the time I was helping Haroldo....."    :rotflmao:
« Reply #17 on: November 23, 2013, 09:12:36 PM »
Not a rule but probably overall, yeah, they get tighter. Some will get looser (easy boys!). Depends on whether the cam surface and follower wear faster or slower than the valve face and valve seat. It is not predictable outside of setting some odds.
Offline jsa
« Reply #18 on: November 24, 2013, 11:10:48 AM »
Many, many moons ago when the metal hardness was pretty inconsistent and valve adjustments were lock and screw with very small surface areas, the valves could get loose and it was pretty common to hear a ticking sound when they did....but they had to be pretty loose before you could hear the tick.  Modern engines have very consistent metal hardness and when using a shim under bucket valve adjustment, have very large contact surfaces, so it is really rare for a valve to loosen and a ticking valve is almost unheard of.  Loose valves generally are not considered a serious risk because of the built in early warning system (the tick) but anyone having a valve significantly loosen probably should check the camshaft to see if it is past the service limit and/or there is some other reason it need to be replaced.
« Reply #19 on: November 24, 2013, 11:56:16 AM »
Yep, all of that.
And then add the fact that once lead was removed from fuel, the valve faces and valve seats had to be made much harder and more wear resistant (lead is a wonderful extreme pressure lubricant as well as being highly toxic). So the entire valve train has become much, much less subject to wear of any kind in the last 20, 30 years or so than older vehicles. Put that altogether and it ends up meaning there there really is very little wear anywhere in the valve train of a modern vehicle.
When was the last time anyone heard of anyone needing a 'valve job'? It has gone by the wayside due to the tremendous longevity of modern valve trains.
Modern engines really and truly are remarkable, especially in comparison to earlier engines. And I don't mean Model T engines either but the engines of the 50's through the 70's. Combined with modern lubricants and fuel, it is almost to the point where stuff just does not wear out.
