Author Topic: Exhaust mod ...  (Read 9606 times)
Offline Smokinzx14
  • Lose nut behind the wheel
Exhaust mod ...
« on: November 14, 2013, 05:50:09 PM »
Brock is having a sale on all Hindle pipes.. He had listed exhaust for the gen 1 zx14 .. I figured what the hell it might fit ( I was told it would not fit ) ... Well it fit great , I only had to do two little mods to make it fit .. Shim the lower rad bracket out and 1/8 of an inch and make a small bracket for the muffler hanger .. The extra power was much welcome .. It wheelies at will in first gear with a snap of the throttle and bang shift second it sets the tire on fire .. It's not loud at all , very deep tone but not loud .. I'm sure it knocked off a good bit of weight over the stock exhaust also ..
2012 ZX14R Stock motor on pump gas  8.43@ 164.95 .
 2013 C14 , Soon to be the quickest C14 in the 1/4 mile .. :)
Offline Smokinzx14
Re: Exhaust mod ...
« Reply #1 on: November 14, 2013, 05:51:13 PM »
Offline Smokinzx14
Re: Exhaust mod ...
« Reply #2 on: November 14, 2013, 05:51:44 PM »
Offline Smokinzx14
Re: Exhaust mod ...
« Reply #3 on: November 14, 2013, 05:53:10 PM »
 ;D  I could not believe how small the factory header was compared to a stock ZX14R .. Looks like it should have come on a 600  and not a 1400 ... :o
Re: Exhaust mod ...
« Reply #4 on: November 14, 2013, 05:58:21 PM »
You have your own bike lift? I'm jealous....
Re: Exhaust mod ...
« Reply #5 on: November 14, 2013, 08:02:55 PM »
Very cool, grats!  8) :chugbeer:
Offline Smokinzx14
Re: Exhaust mod ...
« Reply #6 on: November 14, 2013, 09:00:00 PM »
Thank you ... Figured you guys would like to know about it .. Brocks still has a few left at 20% off ...
Offline katata1100
Re: Exhaust mod ...
« Reply #7 on: November 16, 2013, 08:30:54 PM »
How much louder than stock is it, when you are cruising? I like to listen to my tunes via blutooth and don't want to have the music drowned out by the exhaust.
I also agree with comment about the header pipes- they are about the same size as the pipes on my '80 GS 550e.
Offline Smokinzx14
Re: Exhaust mod ...
« Reply #8 on: November 18, 2013, 08:47:58 AM »
Not loud at all , very very deep tone on power , on cruising hardly any sound at all ..
Offline Smokinzx14
Re: Exhaust mod ...
« Reply #9 on: November 18, 2013, 08:52:55 AM »
pipe size ...  :o
Offline spatten
Re: Exhaust mod ...
« Reply #10 on: November 18, 2013, 01:47:07 PM »
Nice work!  Great that you shared.
Re: Exhaust mod ...
« Reply #11 on: November 18, 2013, 05:47:43 PM »
pipe size ...  :o
Wow- quite a diameter AND layout difference (of course the layout difference will be the 4 into 2  for ZX dual exhaust instead of the 4 into 2 into 1 for the C14 single exhaust).  Thanks for sharing that photo.
Re: Exhaust mod ...
« Reply #12 on: November 18, 2013, 09:43:54 PM »
pipe size ...  :o
That's what she said...  ;)
Offline Daytona_Mike
Re: Exhaust mod ...
« Reply #13 on: November 19, 2013, 12:16:41 AM »
What did you do for a fuel map? PCV?
So we now have several sources for an improved header. Muzzy, AreaP, Hindle and ZX14?
It would be nice to hear a few of these side by side or ride together at the Nationals.  ;D
Re: Exhaust mod ...
« Reply #14 on: November 19, 2013, 12:34:08 AM »
+1!
what else you have done, or plan to?
Offline Smokinzx14
Re: Exhaust mod ...
« Reply #15 on: November 19, 2013, 05:05:16 PM »
Working on a P/C and mapping soon ..I may work with Don Guhl on this and have him do a fuel tune with the ECU  and skip the P/C  ..
Offline Smokinzx14
Re: Exhaust mod ...
« Reply #16 on: November 19, 2013, 05:26:02 PM »
1!
Well seeing that i'm a racer and do lots of testing for aftermarket company's ,  I will do it just like I do all my testing .. I have base lined the bike totally stock at the track , now I will return to the track with just the pipe and NO tuning and see what we get .. Next will be a tune either by P/C or ECU ( maybe both ) and see what we get .. Some dyno time will also need to take place to back up the track numbers .. Once all that has happened I will need to do some street riding to make sure the mapping or ECU tune is spot on for a smooth riding bike..
  I know most of you guys are not looking for a drag bike, but I know you do want extra useable power on the street ..( don't we all ? )  :)
http://youtu.be/iaNXhtzJWY8
Re: Exhaust mod ...
« Reply #17 on: November 19, 2013, 07:29:44 PM »
Looked into ZX14 TBs?
Offline Smokinzx14
Re: Exhaust mod ...
« Reply #18 on: November 20, 2013, 09:42:33 AM »
I have a set of new ZX14 TBs  .. are the C14 smaller ?  The zx14R are 44mm..
I just looked it up , the c14 are 40mm .... hummmmm might be some power with the zx14 44mm TB
Offline Smokinzx14
Re: Exhaust mod ...
« Reply #19 on: November 20, 2013, 09:44:31 AM »
Ok I got some weights for the stock exhaust Vs the Hindle pipe ... stock 32 pounds , hindle 8 pounds .. So there is a 24 pound weight savings ..   :)
