Author Topic: motorcyclelarry.com footpeg extensions  (Read 4653 times)
Offline spatten
« on: October 21, 2013, 03:25:15 PM »
Anybody happy or unhappy with motorcyclelarry.com footpeg extensions?
Thanks!
Re: motorcyclelarry.com footpeg extensions
« Reply #1 on: October 21, 2013, 03:52:47 PM »
Link?  ???
Offline spatten
« Reply #3 on: October 21, 2013, 05:05:17 PM »
They didn't work for me. No problem with quality or anything like that. It's just that it changed my sitting position and I felt more comfortable with the stock location even though my knees are more bent. Also I had to adjust the shifter and the rear brake. No problem on the shifter but I had to cut a bit off the stud on the rear brake to get the position low enough. I've since put it back and it's no problem back in the stock position with a shorter stud but you should be aware of the possibility that you might need to do that.
Offline manowarwi
    • Midwest Sport Riders
« Reply #4 on: October 21, 2013, 07:16:02 PM »
I went with Murph's lowering pegs instead: http://www.murphskits.com/catalog/product_info.php?cPath=130_133&products_id=401 but they both seem to be pretty similar in the amount the peg is lowered.  Personally I am very happy with the lower pegs - a huge improvement in comfort.
As Rhino mentioned, you need to cut a bit of the rear stud off for the rear brake but its a very simple process with a hand grinder - I'm no mechanic and I had the pegs swapped and ground the stud to adjust the brake in probably 30 minutes.
Offline spatten
« Reply #5 on: October 21, 2013, 07:25:02 PM »
Thanks for all of the input, it is definitely helpful.
Offline Flienlow
  • 2010 C-14 BLUE
« Reply #6 on: October 21, 2013, 11:32:11 PM »
I have the MC Larry ones, and they are perfect for me! Love 'em, and no you cant have 'em :)
« Reply #7 on: October 22, 2013, 03:32:08 AM »
I'm running the Buell pegs.
There's already threads on this topic.
Here's a good one:
http://www.zggtr.org/index.php?topic=5351.msg62530#msg62530
« Reply #8 on: October 22, 2013, 08:40:23 AM »
I used a Dremel with a cut off wheel. Took about 5 seconds.
Offline spatten
« Reply #9 on: October 22, 2013, 09:07:14 AM »
Great link Pope.  I saw that a while back when considering the C 14 and could not find it last week.
Offline lablank
« Reply #10 on: October 22, 2013, 10:47:35 AM »
I have MC's extensions on my 2012 Arabian Red. Work great but as with any peg lowering options, they will drag that much sooner when cornering!!  They do provide more comfort though.
2012 C14 Candy Arabian Red; 2005 Hayabusa Red/Black
1988 Katana 1100; 1990 Intruder 800; 1979 GS1000E; 1978 GS750E; 1973 CB350
Offline RubiconMike
« Reply #11 on: October 22, 2013, 11:36:15 AM »
I have a set. I like them, but as others have said, the foot pegs drag earlier that before.
They went on easily, and adjusting the shifter was a snap. Adjusting the brake lever took a little more work (cut down the bolt with a Dremel), but that works fine also.
I found it easier to make a sport/touring bike comfortable than to make a touring bike sporty.  ;D
Offline Flienlow
  • 2010 C-14 BLUE
« Reply #12 on: October 22, 2013, 11:39:46 AM »
For me, the Connie is a road liner. When I start scraping its only on a slow 90% corner. I have done the ol' super Motard lift you leg around the corner deal,but for me this is just too heavy of a bike to be railing corners that hard as I am not interested in finding the limit. :) I will say that I am impressed with the neutral position they leave my knees at. For me its the difference of only riding for a few hours, vs a 950 mile day.
Now for the seat!
« Reply #13 on: October 22, 2013, 11:46:51 AM »
I guess that you two didn't see the photos (post #6) in the link that I provided in post #8 of this thread.   ::)
Offline spatten
« Reply #14 on: October 22, 2013, 03:13:13 PM »
A couple of people on the other thread said the MC Larry lowering adapter has less cornering clearance than the Murphs and pushes the pegs out more.  Some people also said the Murphs push your feet out from the bike.
1. If you take off the peg feelers, is the MC Larry still less clearance than the Murphs?
2. Does anyone that's tried both find that the MC Larry adapters push your feet further out than the Murphs?
Thanks,
Scott
