Author Topic: Lowering front end of the bike  (Read 9286 times)
Offline Awaz
« on: October 10, 2013, 08:48:20 AM »
Ok...you guys bullied me into lowering my front end !  ;D
Just kidding....well, here is the issue. I had my bike lowered (just back end) for the longest with muzzy's link. Recently (like a week back), I went back to original links to raise it up again because I thought I can now handle the bike much better, which I do. But the problem I am having is that my planter's facia in my left foot is flaring back up. Right now, I am attributing this to backing the bike out of garage on my tippie toes putting undue stress on the bottom of my foot. My left foot is a pretty much a patch job from a car accident many moons ago (think like when I was 10 yrs) - so the ankle and all is not quite right. Long story short, think I might lower it back again, but this time want to lower the front as well. So question is, what is the process of lowering the front? I know you gotta take the bolts off the clams that holds the fork leg, but do you take the wheel off? Since the front wheel bear some weight when the bike is in center stand, do you put a small jack underneath so that the thing does not move and down on its own?
EDIT: Another question I have is whether it is safe to cut half an inch off a stock side stand? Or advisable to buy a new short one?
2016 Ducati Scrambler
2008 C14
Re: Lowering front end of the bike
« Reply #1 on: October 10, 2013, 10:03:56 AM »
You probably could but sounds like a pain in the butt, I suggest just buying the 1" shorter one from PE, it's very quality built IMO.  :thumbs: :thumbs:
Offline Awaz
« Reply #2 on: October 10, 2013, 12:09:44 PM »
Thinking about it more, I may just get a new one. Not sure if I will trust a weld.
What about the lowering bit? How did you do your front end?
2008 C14
Offline RBX QB
2011 Concours 14 ABS
« Reply #4 on: October 10, 2013, 03:17:30 PM »
You should always lower the front and back the same amount to maintain handling characteristics.  You can cut the side stand, but you will have to weld a foot back on it.  To lower the front, you must install risers first to allow the tubes to be raised.
http://www.zggtr.org/index.php?topic=260.0
Offline rocknrod
  • 2013 C14 - Blue
« Reply #5 on: October 10, 2013, 03:21:21 PM »
After all that the most informative thread I found (lowering the front) was:
Allot of threads on the rear and the seat though.  :)
« Reply #6 on: October 10, 2013, 05:41:32 PM »
I do try to be informative when I can be :)
This forum has given me a TON of info, I am happy to try and give back however I can.
Offline rocknrod
  • 2013 C14 - Blue
« Reply #7 on: October 10, 2013, 08:08:05 PM »
So as I understand it, you loosed the upper and lower fork clamps and raised the fork tubes? Is that right?
« Reply #8 on: October 10, 2013, 08:37:47 PM »
Yes, although I really only remember loosening the top, but it has been so long I can't remember now :)
Offline Awaz
« Reply #9 on: October 20, 2013, 04:28:47 PM »
So I loosened the top two pinch bolts and bottom two pinch bolts (by the horn bracket). The fork tubes still won't budge (I have not used too much strength yet). My biggest question is do you guys take the wheel off and raise each tube individually? Or can you raise both at the same time by somehow leveraging up the entire wheel assembly? Any tips will be much appreciated.
2008 C14
Offline BMahar
« Reply #10 on: October 20, 2013, 05:05:01 PM »
  Did you install the handlebar risers already to make room for the fork tubes ??
2011 Concours ABS, Black
Offline Awaz
« Reply #11 on: October 20, 2013, 05:51:55 PM »
Yep - handle bar risers already in place. Before I start applying gorrilla force, just need to know if I should move each individual fork tube or the whole assembly (wheel and all)
2008 C14
« Reply #12 on: October 20, 2013, 06:49:13 PM »
Is there room to get a wedge in the pinch bolt gap to spread the clamps?
Offline Awaz
« Reply #13 on: October 22, 2013, 06:34:24 PM »
I am about to give up....the tubes just won't budge. There is room to wedge something in between, but I am kinda scared of wedging something in there and mess things up. I took the wheel off as well so I can work on each tube individually. I never got an answer from someone who did it whether they took the wheel off or left the wheel on. Oh well.
2008 C14
« Reply #14 on: October 22, 2013, 07:55:43 PM »
I had mine done at my local shop and didn't watch them do it, sorry bro, good luck...  :-\
« Reply #15 on: October 22, 2013, 09:54:57 PM »
Sorry, my master-mechanic friend did it with me/for me... and it was years ago now, so I really don't remember much.  But it only took a few minutes and did NOT involve removing the wheel.
Offline Classvino
  • Longtime Kawi Rider
« Reply #16 on: October 23, 2013, 08:36:54 AM »
Had mine done yesterday at a local Kawi shop, and they just loosened the nuts and slid the 'T' down a bit before re-tightening them.
 It looked to me (and at this point I was just a spectator) that it was more of an issue preventing them from sliding down too far, too fast, once the bolts were loosened.
No wheel removal - about 15 minutes start to finish - and this involved measuring them to insure evenness, which the mechanic said they did every time, even though it had never been necessary in hindsight.
Jamie
2013 C14 - First "new" bike
Offline Awaz
« Reply #17 on: October 23, 2013, 09:22:10 AM »
Looks like on mine the lower clamps are hugging way too tight on the forks. I will try some wd40 and prying on the clamps a bit more tonight.
2008 C14
« Reply #18 on: October 23, 2013, 11:04:12 AM »
no WD40 needed (or desired for that matter...)
You have to loosen ALL the bolts on both forks, you can't move just one, they move as a pair....
Offline Awaz
« Reply #19 on: October 23, 2013, 11:21:17 AM »
All four pinch bolts are loose to the extent that I can just pluck them out. But the fork tubes will not budge. I was hoping I can individually move them, align them up, and then put the wheel back on.
2008 C14
