Author Topic: black solid deposit - clutch reservoir  (Read 2277 times)
Offline speed545
« on: October 07, 2013, 05:10:40 PM »
Hi
I m changing fluid every two years (12000M). I noticed black depot in the clutch reservoir. Look like brake dust. That was in may.
In august, I notice it was coming back. So I changed the fluid again and drained the entire reservoir. Cleaned it, bleed the system completely.
Now in October, fluid looking a little black again compare to the brake one
Any input on what s the cause.  Ill try to get a pic
Thx
08, Concours 14
Montreal Fire Dept
Offline speed545
Re: black solid deposit - clutch reservoir
« Reply #1 on: October 07, 2013, 05:15:54 PM »
dughhh
http://www.zggtr.org/index.php?topic=4458.0
Probably found some explanations
just have to use the right words when searching   ;D
08, Concours 14
Montreal Fire Dept
« Reply #2 on: October 08, 2013, 05:25:17 AM »
Must be nice.
I haven't had a solid black deposit in years. ::)
Offline Coomers
« Reply #3 on: October 08, 2013, 06:26:35 AM »
I always find the clutch fluid dirtier than the break fluid. I have also found black soot in the clutch fluid of various bikes. Could be due to usage.
Offline speed545
« Reply #4 on: October 08, 2013, 05:23:42 PM »
Must be nice.
should see your doc  ;)
08, Concours 14
Montreal Fire Dept
Offline whatcom
  • Bellingham, WA
« Reply #5 on: October 09, 2013, 12:56:51 PM »
Same thing happened on my first C14, the color changed progressively more often and at 80k plus, it was every 3k mi.
2013 ZX14r white abs no-flies, scottoiler
2012  C14 Arabian red
Full AreaP ZX14 TB's PCV with dyno map for TB's Rostra CC, W&S remote, A&R HID, Kawasaki trunk with SW-Motech rack, 08/09 storage compartment
