Author Topic: C14 OEM GPS Bracket (anyone)  (Read 3023 times)
Offline CrashKLRtoConnie
« on: June 08, 2011, 09:33:20 AM »
I did not know the C14 has a KAW OEM GPS bracket.
Anyone have one and want to share comments?
2008 C14 GTR1400 AKA "Connie"
Offline ljcorby
  • COG#: 9359
Re: C14 OEM GPS Bracket (anyone)
« Reply #1 on: June 10, 2011, 08:45:55 AM »
Go with the TechMount, looks nicer.....   :)
10 Kawi Concours 14 ABS
« Reply #2 on: June 10, 2011, 09:04:50 AM »
I saw on the Techmount site that if you have bar risers the standard arm on the Kaw c14 gps bracket is too short?
Anyone have risers and use the center mount C14 GPS Techmount?
Bob
« Reply #3 on: June 10, 2011, 09:28:49 AM »
Yes, I had KB risers and a Techmount in between the bars. The techmount will require longer bolts to mount it if you install risers. But if you buy or have already bought the KB risers from Murph as well as your techmount. If you make them aware of this. Murph (well Patty) will include the longer needed bolts for the techmount/ riser combination!
Offline So Cal Joe
« Reply #4 on: June 11, 2011, 08:20:49 AM »
I have this one
http://projektd.com/product_info.php?cPath=27_39_46&products_id=89
When ordering you can select option for longer bolts if you have bar risers.
Comes with new bolts,
