Author Topic: rear shock preload adjustor almost frozen  (Read 7984 times)
Offline wroman
  • 2012 C14
« on: September 18, 2013, 06:29:34 PM »
  I know I am not the only one to have this problem but has not been widespread that it gets talked about much on the forums.  I can barley budge the adjustor, even with the bike on the center stand.  I have tried the suggestions for using silicone spray.  Have unbolted the adjustor and let it hang overnight after loading it with solvent free silicone and even tried 3-in-one oil that seemed to work for awhile.  After my 2500 mile trip it can be barley budged again. I have had other bikes with the same type of adjustor and never had a problem.
I always wanted to be somebody......I guess I should have been more specific.
Re: rear shock preload adjustor almost frozen
« Reply #1 on: September 18, 2013, 06:57:13 PM »
MGvaleri  just recently posted a vid on this I think.
http://www.zggtr.org/index.php?topic=14888.msg183049#msg183049
Offline Spanky
« Reply #2 on: September 18, 2013, 07:12:27 PM »
Still under warranty I hope.
Offline fmwhit
« Reply #3 on: September 18, 2013, 09:16:14 PM »
MGvaleri video is excellent- definitely worth a try if the bike is not under warranty.
Fred
Offline wroman
  • 2012 C14
« Reply #4 on: September 18, 2013, 09:42:52 PM »
  The later model adjusters do not appear to be the same as on the video. I am pretty sure they function the same but cannot figure out hoe to disassemble as in the video.  I have a 2012 model.
Offline pistole
« Reply #5 on: September 18, 2013, 11:24:27 PM »
- that video posted is of the old model Concours' pre-load adjuster.
- newer concours models do not have an adjuster which can be opened up.
- mine was replaced under warranty when the adjuster seized (entire shock + adjuster replaced as one unit) , but 6 months later has also now seized.
- so , took it off the frame , hung it upside down in a plastic bag filled with engine oil for half a day , then got it back upright sprayed it full of wd40 whilst working the adjuster bit by bit. Now it works fine.
« Last Edit: September 19, 2013, 09:21:12 AM by pistole »
« Reply #6 on: September 19, 2013, 04:33:01 AM »
Should we feel slighted that he posted his vid over there but not here?
« Reply #7 on: September 19, 2013, 04:37:46 AM »
Is that not here? Am I in the wrong place? Is this the wrong thread? wtf?
« Reply #8 on: September 19, 2013, 04:42:46 AM »
Um...
Gilda Radner Nevermind
« Reply #9 on: September 19, 2013, 06:08:44 AM »
- that video posted is of the old classic fastest model Concours' pre-load adjuster.
- newer Less fast concours models do have an adjuster which can be opened up.
FIFY..
Offline wroman
  • 2012 C14
« Reply #10 on: September 19, 2013, 06:13:49 AM »
Conrad, did they replace the scock and spring as a whole unit?
« Reply #11 on: September 19, 2013, 08:29:32 AM »
Dunno, you'll need to ask Pistole. See post #5 above.
Offline pistole
« Reply #12 on: September 19, 2013, 09:22:23 AM »
complete rear shock , spring and preload adjuster was replaced as one unit.
Offline wally_games
« Reply #13 on: September 19, 2013, 11:27:18 AM »
My 2011 locked up fairly soon after buying the bike. Took it to the dealer, they rolled it to the back, returned 10 minutes later and it's not been an issue in over 2 years since. Not sure what they did. I asked them, just in case it happened again. They told me to just bring it back. I guess they didn't want me trying whatever it was that they did.
« Reply #14 on: September 19, 2013, 11:37:36 AM »
Pipewrench on the knob?
Offline wally_games
« Reply #15 on: September 19, 2013, 11:43:10 AM »
Probably, but they left no marks and it's worked great ever since.
« Reply #16 on: September 19, 2013, 12:15:35 PM »
« Reply #17 on: September 19, 2013, 12:53:58 PM »
I hate when that happens.
Offline SkyWalker
« Reply #18 on: September 19, 2013, 10:20:57 PM »
After a full year and 20,000mi I went out on a trip with roads following the seaboard (Gaspe Peninsula).
On a bright sunny day, high winds were carrying sea mist, noticeable as my helmet visor would become coated with a sheen just after 15min of riding.
Coming back to the big city a few things started to work awkwardly on the C14 (2012); rear brake pedal felt like a wooden block and the pre-load adjuster became very stiff.
Both issues where solved thanks to the help of my best friend; white lithium spray grease. A few shots, wiggle it and Voilà!
White lithium spray grease comes out from the can with a solvent allowing it to penetrate tight spots (just like penetrating oil) but once the solvent evaporates it takes the viscosity of grease, it is very resistant to water and the elements.
It also work wonders for lock's key cylinders.
Offline MikeB
« Reply #19 on: September 25, 2013, 07:41:49 AM »
My 2011 did this at about 9k miles.  I could tell that it was getting tighter and tighter every time I adjusted it.  Finally it seized.  I tried the pipe wrenched, but even with that it hardly budged.  Shot some WD-40 or Prolong (can't remember which up under the black adjuster knob and it's been working great ever since (I'm at 16k now).  I figured it must have been road dust.  ::)
Mike B.
2011 Kawi Concours 14 ABS
2006 Honda CBR1000RR
