Author Topic: C14 Front Gear Case Cover Corrosion Problem?  (Read 7427 times)
Offline CobraJock477
« on: September 07, 2013, 04:08:29 AM »
My C14 has recently developed blistering on the topside of the front gear case cover.  I’ve compared it to two other C14 and one of those exhibited similar issues but at a much more advance stages.  Obviously Kawasaki has a deficiency or failure somewhere in their manufacturing process.  Anyone have any information regarding these symptoms and possible courses of action?
I must be three times stupid and stuck on dumb…  John Mellencamp, “Cuttin’ Heads”
Re: C14 Front Gear Case Cover Corrosion Problem?
« Reply #1 on: September 07, 2013, 04:14:12 AM »
Almost forgot pics...
« Reply #2 on: September 07, 2013, 04:53:35 AM »
Looks like damage caused by clutch/brake fluid.
« Reply #3 on: September 07, 2013, 05:39:53 AM »
Looks like it was used too much when it was new. ;)
« Reply #4 on: September 07, 2013, 05:45:06 AM »
I'm not sure it's brake or clutch fluid, it looks like corrosion under the paint to me...   Geez, now I have to check my bike.  It's the first time here we've been made aware of this issue.
What's above that area in the photo?  I don't have my bike with me at the moment so I can't look, but that bolt above the area looks as though it's doing the same thing.  Is that casing magnetic or is aluminum?
« Reply #5 on: September 07, 2013, 06:21:46 AM »
After seeing those pics I had to go out to the garage and check my bike. Mine's still perfect.    :)
« Reply #6 on: September 07, 2013, 06:23:32 AM »
Is the clutch slave cylinder above or below that location?
« Reply #7 on: September 07, 2013, 06:27:47 AM »
I'm not going out to the garage again, it's your turn.
« Reply #8 on: September 07, 2013, 06:30:18 AM »
...sigh...I'm at work, bikes not. I'll report back in a few hours.  8)
« Reply #9 on: September 07, 2013, 06:43:46 AM »
Your garage must be some distance from your home, eh?
« Reply #10 on: September 07, 2013, 06:43:49 AM »
Work?   :o
You must be hard at it eh?    ;)
I went back out to the garage and took a looksee. Yep, the clutch slave cylinder is right there but it's ahead and below of it. No way it could have dripped fluid onto that case.
« Reply #11 on: September 07, 2013, 06:45:20 AM »
It seems that way at times...
I was still enjoying my first cup-o-coffee and couldn't be bothered. I had to get up for my second cup anyways so I took the long hike out the back door to the garage.
« Reply #12 on: September 07, 2013, 06:45:47 AM »
Work?   :o
Yeah, the joys of being selfemployed.
« Reply #13 on: September 07, 2013, 06:49:36 AM »
Thanks for the effort.  I was up at 530 this morning and am on a job at the moment...   Hope to be on the road by mid-day or so.
« Reply #14 on: September 07, 2013, 07:07:08 AM »
Never thought of clutch fluid causing the blistering.  Although, there's never been any leaking etc so I think not.  I believe its poor adhesion of the top coating similar to what you would see in a bad paint job if the base material isn't clean enough.  I could see it being a one-off except for the other bike I checked had it worse than mine.
I need to schedule a service so I thought I'd point it out to Kawasaki to see what they have to say.
Offline texrider
« Reply #15 on: September 07, 2013, 07:23:39 AM »
And what model year/year of purchase might yours be?
2014 Valkyrie
« Reply #16 on: September 07, 2013, 07:25:54 AM »
2011
« Reply #17 on: September 07, 2013, 07:31:57 AM »
Look closely at the pics in post #1 (click 'em twice to zoom). The bolt above the area of corrosion is also a bit corroded and has some green stuff on it, unless that's a artifact from the camera?
« Reply #18 on: September 07, 2013, 07:39:54 AM »
Pics are two different bikes?
jirod
« Reply #19 on: September 07, 2013, 08:10:45 AM »
Can't say for sure, but the battery is right above that location. When on the sidestand, any leakage from the battery will flow down to the left side and might drip onto that cover. I don't see any corrosion on my bike but there is some green stuff on the heads of the bolts :yikes: Battery is coming out today!
