Author Topic: tpx 2.0 radar detector installation  (Read 6922 times)
Offline ropjohns
« on: August 31, 2013, 06:26:45 PM »
i need help!  i just purchased a tpx radar detector, and i am having trouble seeing how i am going to route the wires up to the handlebars.  has anyone done this exact thing, and can they help me out with it??  would be very appreciated!
motocopter
Re: tpx 2.0 radar detector installation
« Reply #1 on: August 31, 2013, 07:39:10 PM »
Get a Professional Kit CK-1 from http://www.vintageconnections.com/ and you'll be able to do lots - electrically speaking. I tapped power for my TPX at the connector for the accessory power outlet. I made a plug-in pig-tails for this location. Think through the bullet/socket contact placement on the hot/ground wires. Then, added the contacts to the TPX wiring, and connected. My TPX powers up with the key.
Offline Broz
« Reply #2 on: August 31, 2013, 08:09:03 PM »
I have a passport radar detector. I wired it directly to the battery. I ran the wires up the right side which is pretty easy no need to remove fairing.  From the opening on the top right side of handle bars i just used some zip ties to fix the wires to the bars.  The extra wire I zip tied to the air duct hose on the right side inside the fairing.
I  used a fiberglass kite batten to thread the wire between the fairing and the foam gaskets. I pushed it up from the right side above battery compartment and it pops out up near the opening.  A coat hanger would be too stiff but something about the same diameter is what would work well.    Good luck.
Broz
Semper Fi
Broz
2012 C-14.  Black
Offline ropjohns
« Reply #3 on: September 01, 2013, 07:28:43 AM »
what is a fiberglass kite batten?  i'm wondering if there is something i can get at home depot for this purpose, as i have nothing around my house that i can think of...
Offline Broz
« Reply #4 on: September 02, 2013, 10:30:25 AM »
I saw something in the electical dept at lowes that is made for fishing wires thru drywall. It was 6-8 feet long. I would use your imagination and make something work from stuff you have around the house/garage.  An old fishing rod something flexible. Kite batten is like a batten in a sail. Keeps the kite or sail from flapping. Mine was a spare from and old kitesurfing kite.
Semper Fi
Broz
2012 C-14.  Black
Offline Broz
« Reply #5 on: September 02, 2013, 10:35:06 AM »
Point I'm trying to make is you don't have to remove any fairing to run wire to front of bike or under seat from battery compartment.  Just push/ pull the wires thru. There is room to make it happen. Also I wrpped the wire w some cork screw type wire covering g I got at Radio Shack to prevent chaffing.
Semper Fi
Broz
2012 C-14.  Black
Offline ropjohns
« Reply #6 on: September 02, 2013, 05:20:11 PM »
yeah i went to home depot and just got a bunch of 14 inch zip ties. put 2 of em together and connected one to the wire and fished up and through the foam part in front of the gas tank(eventually).  it was actually kinda fun once i realized it was going to work.  wires cleaned up, detector on, everything ready to speed....thanks for the responses!
Offline PlaynInPeoria
« Reply #7 on: September 02, 2013, 08:22:15 PM »
You don't have to expose your detector to the wind, you can move it over a couple inches behind the fairing.  It will receive through the plastic just fine.  And I don't just mean the clear windscreen, I mean the black plastic.  Test it with a known radar source if you don't believe me.  I have mine mounted similarly but it's behind the windscreen and down a bit. There's a narrow range where it's high enough, yet low enough to where the handlebars will clear it when they are at full lock.
« Reply #8 on: September 02, 2013, 10:46:31 PM »
 :offtopic: I gotta get this off my mind.
WTF is the moral outrage at mounting a radar detector?  I mean a guy asks where he can get a PDF service manual and the hinges come off the door.
Rant off, I like how the mount looks and have nothing against folks who use detectors or for that matter a PDF version of the manual but I do have strong feelings for hypocrits...
Yes, I like KIPASS, use a full synthetic oil since mile 75ish, and I think car tires belong on cars.  I am also against search nazis.  Did I miss anything? ;D
« Reply #9 on: September 03, 2013, 05:52:42 AM »
Does anyone care he's mounting a radar detector? I think the problem is with copyrighted material, which could get the site shut down.  I suspect the outrage would be just as bad if he posted a pdf of "50 Shades of Gray".  Well, ok more, because no self respecting man should be reading that.
« Reply #10 on: September 03, 2013, 05:58:44 AM »
And you know this how?  ???
« Reply #11 on: September 03, 2013, 06:05:20 AM »
PIP, I think you may have missed my point.  I agree, this or any other site should not post an unauthorized PDF of anything, but for members to share where to get it in a non link form?  The moral outrage is what gets me, some laws are OK to be broken and even flaunted, yet others?  I'm not lilly white, yet I like to think I live well within MY moral values and work really hard at not forcing those values onto others.  Especially outside the Arena.
Like gPink, I too am interested in your knowledge of 50SG ;D
motocopter
« Reply #12 on: September 03, 2013, 06:34:08 PM »
Gosh, it was installed over a year and half ago and I'm not certain why I chose that location. It may be due to the laser detection and suspecting that the unit needed line of sight exposure. What is your take on laser?
Offline AZBob
« Reply #13 on: September 04, 2013, 12:41:16 PM »
It doesn't work, and when it does, all it tells you is that you've been tagged you should check your mirrors for some pretty lights. Better off with a device that jams laser, apparently there are some that work and a lot that don't but claim they do. They're illegal in some jurisdictions, however. I prefer to just keep it within 10 of the posted limit most of the time.
« Reply #14 on: September 04, 2013, 06:58:30 PM »
« Reply #15 on: September 05, 2013, 07:10:37 AM »
I don't think it's moral.outrage, just protecting the site.
And my gf read and loved 50SG. I was considering reading it to learn some tricks to play on her that she might enjoy, she's a nice looking gal and ahem "adventurous"? But I read the reviews and apparently the writing is just BAD so I can't stoop to it. But I did buy her some books in that vein that are more well written/ not idiotic but still a bit twisted. So I am gonna read them (yep!), give them to her and I'm sure she'll devour them. Then I'll bust s move like out of one of the books. Might be fun.
Offline Jake Mountain
« Reply #16 on: September 06, 2013, 04:17:35 AM »
Now that just takes the fun right out of riding a C14 doesn't it  :D
01 Kawasaki KLR 650
03 Suzuki Vstrom 1000
11 Kawasaki Concours 14
