Author Topic: Help..... With Rear Shock  (Read 5382 times)
Offline MGvaleri
  • Country: it
« on: August 23, 2013, 11:01:03 AM »
Regolazione prevarico bloccato,no perdita olio.
Preload adjustment locked, no oil leakage.
thanks
MGvalerio :(
« Last Edit: September 04, 2013, 11:27:36 PM by MGvaleri »
Re: Help.....
« Reply #1 on: August 23, 2013, 11:03:07 AM »
soak with penetrating oil around shaft
Offline MGvaleri
  • Country: it
Re: Help.....
« Reply #2 on: August 23, 2013, 11:06:13 AM »
Tranks :thumbs:
MGvalerio. ;D
Re: Help.....
« Reply #3 on: August 23, 2013, 11:20:29 AM »
I just love your sound effects!
Offline MGvaleri
  • Country: it
Re: Help.....
« Reply #4 on: August 23, 2013, 11:31:28 AM »
Posso pure esagerare!!! ;D OK
MGvalerio. ;)
Re: Help..... With Rear Shock
« Reply #5 on: August 24, 2013, 11:54:15 AM »
We've had at least one or two reports of the adjuster locking up.  I'll have to see if I can find them...
Offline MGvaleri
  • Country: it
« Reply #6 on: August 24, 2013, 12:24:11 PM »
thanks Jim ;D
mg valerio ;)
« Reply #7 on: August 24, 2013, 12:30:02 PM »
Ok, try some Liquid Wrench Dry Lubricant.  You don't want to use something like WD40.  You may also have to use a strap wrench for some extra oomph...
http://www.amazon.com/Liquid-Wrench-L512-Lubricant-CERFLON/dp/B000CPJLE4
Don't know if you can get it in Italian....and if you can't, I'm sure you can fabricate it.  ;)
Here's the only thread I found.  I think that there were some more but they were lost in the old forum.. :'(
http://www.zggtr.org/index.php?topic=11886.msg145975#msg145975
Offline MGvaleri
  • Country: it
« Reply #8 on: August 28, 2013, 01:46:04 PM »
Per la mia esperienza fatta, seve un buon lavaggio con Benzina.
http://youtu.be/7fSdwz2qlzA
PS.Grazie a VirginiaJim se ho risolto. ;D
MG valerio. 8)
« Last Edit: September 04, 2013, 11:26:33 PM by MGvaleri »
« Reply #9 on: August 28, 2013, 02:19:22 PM »
I'm not exactly sure what you did except to take it apart and clean it.  Not sure what that spray was that you used.  But am glad it worked for you.  I was half expecting it to fly apart in your hands.  That would have been funny.  At least we know it can be done and thank you so much for the video.  :thumbs: :goodpost:
Offline MGvaleri
  • Country: it
« Reply #10 on: August 28, 2013, 02:32:01 PM »
To clean the inside made ​​with gasoline.
MG valerio. 8)
Offline fmwhit
« Reply #11 on: August 28, 2013, 07:25:16 PM »
Good Job :)
