Do you have handlebar risers and what brand (on your C14)
I do not have handlebar risers
30 (31.9%)
I have Murphs
26 (27.7%)
I have GenMar (Premier / Amotostuff / Twisted Throttle / etc)
6 (6.4%)
I have Motorcycle Larry's
5 (5.3%)
I have Helibar (Premier / etc)
19 (20.2%)
I have ProjekD
3 (3.2%)
I have ebay (Mfg Unknown)
1 (1.1%)
I also added ram balls and or power outlets to risers
4 (4.3%)
Total Members Voted: 94
Voting closed: June 21, 2011, 09:35:52 AM
Author Topic: C14 (Handlebar Risers)  (Read 36726 times)
Offline CrashKLRtoConnie
« on: June 06, 2011, 09:35:52 AM »
URLS / Info on C14 Bar Risers:
Amotostuff (GenMar): Handlebar risers
Code: K406
Price: $98.96
Shipping Weight: 3.00 pounds
Quantity On Hand: 1
Quantity in Basket: None
The risers are placed between the fork crown and the handlebars to raise the bars up 2" (51mm) and back 1-1/8" (28.5mm). This will help to relieve wrist and neck pain on long rides. Requires minimal re-routing of some control cables, wiring, or hoses. - K406
http://www.amotostuff.com/concours14_hand_cont/K406.html
$98.86
Murphs: Bar Risers
This set gives 3/4" pull back and 1-3/8" rise. For comparison, we have the stock measurement from the top of the mirrors to the bars at 12-1/4", while the height of the bar end is 41-7/8" on center from the ground. With the KB risers installed, the distance back is now 13", with a height of 43-1/4". The riser blocks themselves are 1-5/8" thick.
The KB risers come with the same grade stainless mounting bolts as stock, 4 bolts to use with, or to temporarily cover, the accessory mounting holes, and six allen head covers, just in case you want a little change of pace.
http://www.murphskits.com/catalog/product_info.php?cPath=130_133&products_id=282
$92
Motorcycle Larry Handlebar Risers: RISER BLOCKS
The MCL riser blocks raise your handle bars up 1 3/4" (44 mm) and back 3/4" (19.5 mm) . Retains: stock handlebars, cables, and hydraulic lines, bar angles do not change. The MCL riser blocks are machined out of  6061 T6 billet aluminum then powder coated and come with extra long stainless mounting screws.
You can mount either one of each of the above accessories or two of the same kind  on each block.  When ordering the MCLPOD  power bracket note in the attributes below if you want to mount it on the right or left bar riser.
The new MCL Bar Risers Offer:
1, 44mm (1 ¾) increased handlebar height 19.5 mm (3/4) rear offset to reduce reach to grips
2, Machined in house of aircraft grade aluminum, then stardust silver powder coated, sold
direct with no dealer middleman another MCL exclusive
3, Raises the bars up and out of your field of vision in your mirrors
4, Options include a Ram Ball mount block that will fit on right or left side or put
one on each side and a Powerlet socket bracket a MCL original to hold a 12 volt
Powerlet plug for your electronics or tank bag.
5, Maximum height without changing cables or hydraulic lines
(Ram and power are screw on to riser at extra cost)
http://www.motorcyclelarry.com/index.php?main_page=product_info&products_id=169
$89.98
Premier (HeliBar): Handlebar risers
HeliBars Handlebar Risers Kawasaki C14 ('08-'11)
(2" taller, 3/4" rearward. Includes: Powerlet Socket & Ram Mount Ball. Color: Aluminum)
51 mm (2 inch) increased handlebar height
19 mm (3/4 inch) rear offset to reduce reach to grips
•Removes bar and hand distractions in the rearview mirrors due to the bars
and controls being moved up and out of the field of view
•Left side features the Powerlet® socket for a convenient power source
•Right side bar adapter includes a vertically threaded boss with a 1” Ram Mount® Ball. This single feature simplifies and reduces the cost of mounting a GPS or other electronic device. Road testing dictated this ideal ball mount location which allows easy access to the tank top storage compartment lid. We also recommend a Ram Mount® 6” double socket extension arm, which will place your GPS at the ideal height
•Uses all stock cables and hydraulic lines
•Optional Wiring Harness not included.
•Part # 150-0034. This wiring harness is built by Powerlet specifically for these risers. Everything you need to wire the socket is included & the length is assured to be the correct distance from the socket to the battery.
https://www.premiercycleaccessories.com/HeliBars_Handlebar_Risers_Kawasaki_C14_08_10_p/helihr04042.htm
http://www.helibars.com/product/08-09-concours14-1400gtr-tour-performance-hr-adapters-0
$160
ProjekD Handlebar risers:  38 MM ~ 1½"
Handle Bar Risers for Kawasaki GTR1400 and Concours 14 CNC Machined from solid billet aluminum. Fits on 2008 to 2011 Model bikes. This accessory will raise the position of the handle bars by 38 mm ~ 1½", providing a more relaxed riding position.  Silver anodized finish blends in with the handle bar color of the GTR1400 / Concours 14.
http://projektd.com/product_info.php?products_id=86
$80
Twisted Throttle (GenMar) Handlebar risers
The risers are placed between the fork crown and the handlebars to raise the bars up 1 1/2" (38mm) and back 7/8" (22mm). This will help to relieve wrist and neck pain on long rides. Requires minimal re-routing of some control cables, wiring, or hoses.
Code: K405
Price: $89.96
http://www.twistedthrottle.com/trade/productview/4649/218/
$99.95
2008 C14 GTR1400 AKA "Connie"
Offline Mighty
Re: C14 (Handlebar Risers)
« Reply #1 on: June 06, 2011, 10:35:51 AM »
This has my interest.  My right wrist bothered me yesterday while riding.
No Flies, PC V, BMC Air Filter, Two Brothers Carbon Fiber, Deep Tint Windshield, Gen Mar risers
Honda TRX700XX
Yamaha Warrior 1000cc 4 stroke Sled
68 Rag top Vette
Offline COGnosticat0r
« Reply #2 on: June 06, 2011, 12:27:16 PM »
I had Murphs risers, then decided to go with the LSL bars which are lower than the stock with risers
Jerry Holland
COG 4478
2013 C14
Offline Awaz
« Reply #3 on: June 06, 2011, 12:37:12 PM »
I bought mine from a good member here. I believe they are murph's. And they have helped me out a ton in relieving wrist pressure.
2016 Ducati Scrambler
2008 C14
Bob
« Reply #4 on: June 06, 2011, 12:44:11 PM »
I had KB risers that are known as Murph's on my C14!
Offline danvforce
« Reply #5 on: June 06, 2011, 12:53:36 PM »
No bar risers, but I do have Phils wedges.
Offline Wild_Bill
« Reply #6 on: June 06, 2011, 01:30:28 PM »
I had the genmar 2" risers, but that was not enough. I made my own and use phil's wedges. Gives me 2" rise with 2 1/2" pullback.
Bill
Formerly known as Badnews_Bill
Offline Bagger
« Reply #7 on: June 06, 2011, 06:57:09 PM »
I have MCLs plus my own design blocks (on the old forum) to pull back and raise the bars more .... and Phil's Wedges to adjust the cant.
I love this more Wing-like seating.  I know others will say that lower bars make the bike handle better, but I'm uncomfy at the lower settings.  I still manage to get thru the twisties with 3/8 inch chicken stripes.  And, I'm not a hard rider.
Making yourself comfortable on the bike is more important to me than how fast I can ride curvy roads quickly.  I'm happy with my set up.
« Last Edit: August 13, 2011, 05:04:38 PM by Bagger »
Offline overthehill
« Reply #8 on: June 06, 2011, 07:32:44 PM »
I had Helibar risers on my C10 and stuck with them on the 14.  Great workmanship.  Great fit.  Just what the Doctor ordered.
1987 Connie gone
2003 Goldwing (yikes, no lean angle) gone
1999 Connie gone
2008 Connie
Offline jonathan
« Reply #9 on: June 07, 2011, 09:14:07 AM »
I shortened mine by an inch (25mm).
Offline mkorn
« Reply #10 on: June 07, 2011, 09:39:03 AM »
I went with Murph's cause i wanted the RAM mount feature.
VEry pleased with the risers and the fit and finish.
2009 C14 ABS
2002 750 Nighthawk (sold)
2006 DRz 400s
Offline EpicBadass
« Reply #11 on: June 07, 2011, 01:25:37 PM »
Just threw on a set of murphs last weekend.   :D
Offline Restless
« Reply #12 on: June 07, 2011, 02:59:04 PM »
+1 bought a set of murph's used from a forum member and they sure help minimize the pain I used to get in my neck and upper shoulders!   :thumbs:
2010 Connie w/ABS
"Why is there never enough time to do the job right the first time but always enough time to do it over?"
Offline PH14
« Reply #13 on: June 07, 2011, 03:43:42 PM »
That might be helped more by a throttle lock.
Offline Murph
« Reply #14 on: June 09, 2011, 04:50:17 PM »
Well
 ya'll know what I have  8), and we should have our first production run of Phils wedges in another week.
don't forget the shipping is included in our price .
Murph
COG 2769
Industry Member
« Reply #15 on: June 09, 2011, 06:15:53 PM »
I've got COGnositicator's old risers and I really like them.  I am think about getting some wedges when Phil is ready to start selling them.
« Reply #16 on: June 11, 2011, 10:40:35 AM »
2" Heli with built in ram mount and powerlet plug for gps.  :thumbs:
Offline Murph
« Reply #17 on: June 11, 2011, 01:49:31 PM »
Phil has turned over his wedges to murphskits  8), I have the first "proof" batch sitting here on my desk.
Phils on a road trip right now, but he posted a few weeks back that he was happily handing this product over to us.
Murph
COG 2769
Industry Member
Offline metzgerf16
« Reply #18 on: June 11, 2011, 11:12:24 PM »
What are Phil's wedges?  Sorry if that's a dumb question.  Haven't heard of them before.
"You serious, Clark?"
'09 Red Concours- Sargent seat, Area-P exhaust, BMC filter, PC-V, flies out, PR2's, Murph's risers
'06 Ninja zx10r- Dear tiny baby Jesus, it's fast!
Offline Makz58
« Reply #19 on: June 12, 2011, 07:35:14 AM »
Murphs here....really help relieve the pressure on my wrists.
C-14 2010
