Author Topic: new EBC front rotors, notch on inner side of rotor  (Read 3920 times)
Offline jtk1531
  • Country: my
« on: July 27, 2013, 10:36:52 PM »
i've just received a new pair of EBC front rotors in the mail.
first thing i noticed is a notch on the inside of the steel rotors on both discs. not sure if this is a design feature or a manufacturing fault.
anyone have any ideas? i've emailed the seller, haven't received an answer yet.
Re: new EBC front rotors, notch on inner side of rotor
« Reply #1 on: July 27, 2013, 11:08:27 PM »
I just went out to the garage and checked mine and yep same mark, so I'd say normal.
Offline jtk1531
  • Country: my
« Reply #2 on: July 28, 2013, 01:30:05 AM »
thanks! that's a relief...
Offline Tarheelbob
« Reply #3 on: July 28, 2013, 08:23:17 AM »
Yes. Yes it is. (Bad engineering pun, implying geeky attempt at humor. You should laugh here.)
« Reply #4 on: July 28, 2013, 09:32:12 AM »
 :rotflmao:   Like this?
« Reply #5 on: July 28, 2013, 10:21:00 AM »
Wow you all check parts well.  I threw mine on, and once I saw the additional bite and performance with the double-H pads (compared to the stockers) I called it a day  :D
« Reply #6 on: July 28, 2013, 05:49:08 PM »
I never noticed it on mine.
Offline Tarheelbob
Offline con05
« Reply #8 on: July 28, 2013, 07:09:51 PM »
Not to hijack this thread but with so many of you using these rotors did any of you replace original rotors because of warping? I am headed to my 3rd pair of oem. Completely baffled. I am not a hard rider.
Silver 2011 C-14
« Reply #9 on: July 28, 2013, 07:44:51 PM »
I replaced mine because someone said the service level is 4.5mm or such and mine was 3.9mm and appeared paper thin
« Reply #10 on: July 28, 2013, 07:56:20 PM »
My oem's were as straight as Max.  ;D
I only went to the EBC's to match up with the gold wheels...  ;) 8)
Offline jtk1531
  • Country: my
« Reply #11 on: July 28, 2013, 10:54:23 PM »
no warping till date, but the original discs are under the wear limit within 22,000 miles (36,000 km). used OEM pads (new version) all this while. planning to use the discs till they're down to 4.0mm thick.
i'm replacing it with EBC because it's cheaper than OEM, even with international shipping costs and customs tax included.
incidentally, EBC discs measured 5.04mm and 5.09mm thick (used a micrometer to measure). looks a lot more better than the range given in kawasaki's oem disc thickness. EBC doesn't seem to publish their rotor thickness anywhere.
Offline jtk1531
  • Country: my
« Reply #12 on: July 28, 2013, 10:59:37 PM »
it worked, and i did...  :)
