How many miles on your '14 by year
08 10000 miles+/-
08 20000 miles+/-
08 30000 Miles+/-
08 40000 Miles+/-
08 50000 Miles+/-
08 over 100000 Miles/-
09 10000 Miles+/-
09 20000 Miles+/-
09 30000 Miles+/-
09 40000 Miles+/-
10 10000 Miles+/-
10 20000 Miles+/-
10 30000 Miles+/-
11 10000 Miles+/-
11 20000 Miles+/-
11 30000 Miles+/-
Other, please post comment
Author Topic: MOB's Updated History with mileage poll  (Read 30144 times)
Offline Tactical_Mik
  • Lamh laidir an Uachtar
« on: May 12, 2011, 02:09:56 PM »
Black 2009 ABS purchased 11-25-09 used with 300 Miles on Odometer
Serial #XXXXXXXXXXXX20056
COG #9047
11-25-09 Fluid changed by dealer (Kawi Dino and filter)
12-10-09 648 Mile (600 mile  service), brake recall, TPS replacement front and rear via dealer
12-21-09 Fluids change 1134 miles (Kawi Dino and filter), install of 2" risers
1-09-10 installation of MetalBender's wind deflecters
2-05-10 installation of rad guard and Murph's oil filter protecter
2-18-10 Fluids change 2091 miles (Kawi Dino and filter)
3-9-10 Installation of CeeBaileys bronze Euro cut shield due to lots of negative pressure w/OEM
3-27-10 Fluids change 3431 miles (Kawi Dino and filter), throttle cable adjustment
4-2-10 Rough idle at startup-adjust warm idle to 1050 RPM
4-16-10 4321 mi. replaced BT021s with Mich. PR2s.  BTs were really scary and wearing weird.
4-17-10 Installed Phil's luggage rack with SW Givi mounts
4-24-10 Installation of Fujilock (8mm 1.25) nuts in replacement of factory header nuts that kept  loosening
5-1-10 Put Sears top box on Phil's rack. (eventually will be Givi E55 when funds are present)
5-23-10 6066 mi.Fluids change OEM filter Mobil1 4t 10-40 synthetic
5-29-10 Radiator fluid change with Honda OEM coolant
6-26-10 7921 miles, change air filter, inspect Hoses for wear (fuel, water, brake, clutch), brake pads, final
drive fluid change, fork seals, replace spark plugs (even though they were still in spec)  Think that makes me
good for the 7500 mile service.
fluid changes at 10,067 mi.,13,001 mi., 15,895 mi.
9-20-10 changed tires to Angel St
2-9-11 16,248 mi.  Warranty work for leaking valve cover and o ring.  Also 15,000 mi service intake valves in spec exhaust on the tight side of spec and adjusted
4-21-09  rebuild front left caliper
5-21-11 18,342 replace front caliper due to dragging, replace brakes all the way around, check TIR @ .022  Put on Shinko 009's
6-11-11  21,000 have dealer confirm warped rotor to start warranty process
6-16-11  Replace wheel bearings/dust seals front and rear
7-3-11 Fluid and filter changes @22,157 mi.
7-20-11 front left rotor replaced by dealer
8-18-11 Fork fluid change @ 23,094 mi.
8-19-11 New shinko 009 on rear
« Last Edit: August 21, 2011, 06:35:53 AM by Tactical_Mik »
T.S.R.
T.S.R.
Re: MOB's KEEP UPDATED HISTORY
« Reply #2 on: May 12, 2011, 05:15:44 PM »
Thanks Mik!!!
I copied it all, and pasted it into a word document....and will transcribe it into a spreadsheet....someday....when I have about a month.... ;D
any chance on finding the "How much would you pay"... posting about the extended warrentees?
I'd Like to re-do that one, and also get a final count of how many took up the offer...
Offline Tarheelbob
« Reply #3 on: May 12, 2011, 08:11:29 PM »
August 23, 2009
2009 Black with ABS
Purchased from MR Motorcycles in Asheville, NC
VIN: xxxxxxxxxxxx020042
paid $12,031
49 miles on ODO at pick-up
Rear tire pressure monitor not working.
Header bolts not tight.
Farkles
Throttlemeister
CalSci +4.5 windshield
Motorcycle Larry's risers
Sargent seat
Murph's Fenda Extenda
Tankslapper protection film
Symtec grip heaters
Phil's Rack
Cox Racing Radiator Guard
Grip Puppies
Service / Notes
September 30, 2009 - 600 mile service August 29. All checks good. Shell Rotella-T 15w-40 with Purolator Pure One PL14612.
Chasing good suspension set-up to get lousy OEM front tire better grip. (1300 - 1600 miles). Trying firmer spring force up front, slightly softer on rear preload.
March 2010 - 4062 miles. New Pirelli Angel ST's, rear TPS repaired.
Offline mstetson
« Reply #4 on: May 13, 2011, 04:08:53 AM »
Mark, No COG#, 2009 Red ABS, S/N 19400, Team Charlotte Motorsports 1/27/11
Current mileage 3223
600 miles - Warranty replacement of rear TPMS, 600 mile service
1800 miles - Replaced BT021s with Michelin PR2s
Farkles
Two Brothers Racing slip on exhaust
TechMount GPS mount with Garmin GPS
Alaska Leather Butt Pad
TechSpec tank grips
« Reply #5 on: May 13, 2011, 04:15:37 AM »
Thanks Mik!!!
Rich, I did a search and didn't really come up with anything.  If you can just repost the intial info, contact information, and such, I'll make it a sticky again.
« Reply #6 on: May 13, 2011, 10:59:15 AM »
Thanks, I got what I needed.....
folks, please refrain from turning this into a "discussion" post from here on out, it was originally meant to be a post of 'documentation on VIN, purchase date, dealer, price, location, and COG affiliation (COG#).[/b]
thanks for helping on the old, and now new database....I'll decode the old one, and make a spreadsheet.
Offline dbird29
DBird29's 2010
« Reply #7 on: May 14, 2011, 10:50:56 AM »
David, No COG#
2010 ABS Blue SN 3723
Purchased used, 1320 miles, from Paradise HD in Beaverton, OR 2/12/2011
just under $11K
Farkels added:
Cox Racing Group radiator guard
MC Larry's extenda fender (ABS cement)
Cee Baileys saddlebag liners
Go Cruise
Murph's Stebel horns
Phil's rack
Reflective saddle bag film
Murph's lowered pegs
Cortech Dryver tankbag & GPS bag
Powerlet luggage electrix system
Bag Connection seat bag
Murph's Sylvania headlights
Shad 50L topcase
2010 C14 Blue
2003 Buell XB9S
1982 GPz 750
Offline GPz1100
  • Red is Faster
« Reply #8 on: May 18, 2011, 12:14:00 PM »
J W Sherman
Warren, TX.
COG #8060 Expired
Purchased from Kawasaki Outpost Motorsports in Silsbee, TX. on 10/11/2007
Non-ABS #5864
Stebel air horn. Throttlemeister. Kisan headlight modulator, Tailblazer brake light flasher and Signal Minder turn signal canceler. Muzzy fender eliminator. Muzzy SS Slip-On. Cox racing radiator guard. Front fender extender. Battery tender. Targa tank cover. Skidmarx hugger. Eagle Screens tinted windshield. ZX-14 seat. Philipintexas/philsfarkels aluminum luggage rack. Rostral CC. Dashboard shade screen. Paniers secure latch mod. Gas cap lock mod. 3 year extended warranty purchased.
Offline Sea Level
« Reply #9 on: May 19, 2011, 05:38:36 PM »
Robert Dwork, Quincy, Ma.
COG #706096
2011 Black ABS VIN #JKBZGNC16BA006036
Purchased 12/02/2010 w/ 0 miles.
Riverside Motors, Somerville, Ma. $14,600.
Delivered 03/16/2011.
Mileage at this posting: 1,750.
Offline Wingfixer
« Reply #10 on: May 29, 2011, 08:30:36 AM »
I bought my KWACK ABS at Valley Cycle in Winchester, VA on 3/18/2008. So, to start a running history:
3/18/08  560 miles purchased for 11489.00
4/1/08   1123 miles installed Garmin Quest II, Battery Tender lead and grip puppies
4/17/08  1476 miles installed Throttle Meister
7/25/08  5997 miles installed Alaska Leather long hair seat
8/14/08   6039 miles switched to Mobile 1 gold top\replaced front tire with Avon Storm (6039).
8/17/08   6108 miles dropped at dealer for front brake shake, new rotors under warranty.
10/8/08  7893 miles installed Sargent seat.
10/17/08 8109 miles installed Xenon Rider HIDs, Heated grips, AP2 to run the goodies and Cox radiator guard.
10/30/08 8811 miles installed Avon Storm rear tire (8811).
12/10/08 11330 miles front rotors replaced under warrantee, again.
02/26/09 14832 miles removed the Quest II and installed a Zumo550.  Installed a cool blinky rear brake light.
03/21/09 15017 miles Valve adjust, pulled the flies, installed PC-V, ZX-14 header (wrapped) dual Yosh pipes.
04/24/09 16220 miles Installed front and rear PR-2's.  Very Nice!!(10181 FT, 7409 R)
08/14/10 25050 miles Replaced air filter
10/26/10 25558 miles Replaced front brake pads with EBC HH pads.
3/21/11 26770 miles Replaced the rear PR2 with a 2CT. (10550)
7/13/11 28068 miles Replaced front PR2 with a 2CT. (11848)
7/27/11 29790 miles Rear diff repaired for oil leak, under warranty.
8/15/11 32707 miles Rear diff repaired, again, for oil leak, under warranty.
2/2/12   35070 miles Performed valve check, no shims required. Replaced spark plugs.
5/3/12   35958 miles Replaced rear 2CT with another 2CT. (9188)
6/15/12 39220 miles Rear diff repaired, again, for oil leak, under warranty.
9/25/12 41880 miles Replace the oil pan after bashing a rock through it.
10/23/12 43635 miles Replaced front 2CT with a PR3. (15567!)
8/14/13   46737 miles Replaced rear 2CT with a PR3. (10779)
7/24/14   56196 miles Replaced front brake pads with EBC HH (30638)
9/6/14     58204 miles Replaced front PR3 with 2 CT (14569)
9/6/14     58204 miles Replaced rear PR3 with 2 CT (11467)
7/14/17   66531 miles Replaced rear 2CT with Angel GT (8327, changed maybe 1k early)
10/26/17 67890 miles Replaced front 2CT with Angel GT (9686)
Unable to remove smile any time I ride her!!
(I replace the oil and filter and the rear diff juice every 3k, now every 5k after it hit 15k total miles)
S/N 10312
COG# 8405
Brake recall notice rcv'd 1/16/09
« Last Edit: October 28, 2017, 04:50:31 PM by Wingfixer »
Mileage poll based on year of bike for C14s
« Reply #11 on: June 28, 2011, 11:09:52 PM »
So, something slightly differant, when you post a comment, please include date purchased and either new or from a PO.  Lets see who the riders are and how well this bike has stood up over the miles.  Although discouraged, KiPASS comments are welcome.  Share any issues you have had with the bike, be it brakes, KiPASS, Gear Position Indicator (My issue), broken bars, burning oil, leaking final drive, or any electrical issues.  Also indicate if you did the extended warranty-I did, I had only the one issue, I figured the gremlins read about the 3 yr, unlimited mileage and were just waiting for it to expire, so I cheated them out of the chance to wreck my bike the day after 8 July of this year 8)
Re: Mileage poll based on year of bike for C14s
« Reply #12 on: June 28, 2011, 11:17:11 PM »
09 ABS leftover model purchased this past fall, haven't hit 10k miles yet so have to vote "other" on your poll...  :(
« Reply #13 on: June 28, 2011, 11:29:59 PM »
Fixed it to include bikes just under or approaching the mileage mark!  Hence th+/- at the end.
Well see who gets there first ;)
« Reply #14 on: June 29, 2011, 12:05:23 AM »
Black '08 ABS leftover, got it in march '09, and she gets 4 months winterised due to snow. So technically, I've only been driving her for 19 months, in which she's got 18k miles.
Issues? I keep needing refueling and tires, sometimes at an alarming rate (140 mph in the Autobahn mean some 100 miles range before the beacon perforates my cornea and the back of my skull, and the rear tire does not last more than 3-4000 miles). Other than that, just the vibration at 4k rpm that got solved by adding a 50 cents washer.
God, I like this bike!
EDIT 5th of August, 2013: bike has 45k miles. I had to get the valve cover seal changed about 7k miles ago. That's it. The fuel/tires problem has not been solved 8)
« Last Edit: August 05, 2013, 09:13:12 AM by martin_14 »
« Reply #15 on: June 29, 2011, 12:06:27 AM »
'10 well over 30,000
10,000 or so more coming next month
« Reply #16 on: June 29, 2011, 02:36:20 AM »
My 09 is in the 23K range.  Got it with 300 mi. on it 11-25-09.  The only engineering issues I've had are warped rotors.
The only way I could have had more miles on it is if I got another job.  Then again, I wouldn't have time to ride then.   :)
T.S.R.
Offline vivo
« Reply #17 on: June 29, 2011, 04:45:14 AM »
My 09 was a leftover... have had it almost a year, maybe 11 months. Only has 5000 miles on it as it shares seat time with my Griso,
viovo
Offline S.Ga.Rider
« Reply #18 on: June 29, 2011, 04:49:33 AM »
09 bought used with 1200 miles and has 10300 right now. I have a 1500 mile trip shortly so that will put it around 12000.
« Reply #19 on: June 29, 2011, 05:04:13 AM »
'08 ABS purchased in Aug of '07.  Problems with the rotors, other than that, nothing.
Isn't this a duplicate of http://www.zggtr.org/index.php?topic=146.0 other than the poll?
Convince me why I shouldn't merge this with the other one started by MOB (Rich)?  I'm open to convincing....maybe, possibly, beer helps.  ;)
