Author Topic: C14 OEM Tank Pads  (Read 3774 times)
Offline Gabriel
  • Near Galveston
C14 OEM Tank Pads
« on: July 12, 2013, 06:46:32 PM »
This is a quality product and it's easy to install. However I don't really care for this type of project because lining everything up is a pita. It's easy when using Windex, you can position it just like you want it but don't walk away until you at least secure a corner because it will fall off and hit the floor! It landed sticky side up, was I lucky? NO! I had to step on it before I noticed it had fallen off >:(. however there was no harm done and everything went well after that.
This material has a kind of "grabby" surface so your squeegee won't work very well, just use a paper towel to push out the Windex. :)
Offline bkromer
  • 2012 C14 Black
Re: C14 OEM Tank Pads
« Reply #1 on: July 13, 2013, 06:49:32 AM »
Nice job,I had to pull mine up a couple times to get the right alignment, but they are pretty forgiving and turned out very nice. I don't believe those small pieces you have at the bottom are supposed to be part of it though.
2012 Kawasaki Concours 14
1998 Honda Valkyrie Tourer
Bruce
Offline Gabriel
  • Near Galveston
« Reply #2 on: July 13, 2013, 08:44:43 AM »
Do you think those are just something they add to make it look good in the package?
They act like decals, I guess it's good they did not include anything else in the package because I would have probably stuck that on also?
Offline PH14
« Reply #3 on: July 13, 2013, 09:03:25 AM »
Offline bkromer
  • 2012 C14 Black
« Reply #4 on: July 13, 2013, 10:04:51 AM »
I think they are pieces left over from the die Cut process. If you go to the Kawasaki site, you will see they are not in their photo. http://www.kawasaki.com/site/kawasaki/CatImages/items/250x225/L168TPT0057.jpg
Bruce
Offline Gabriel
  • Near Galveston
« Reply #5 on: July 13, 2013, 10:45:42 AM »
Your probably right, however they are made from a different material and it feels/works like a vinyl decal.
If that's the only thing I screw up this week I got it made.
« Reply #6 on: July 14, 2013, 06:49:52 AM »
I can still get it on the center stand with a little more effort.
So you can feel the added weight of the pads when you hoist her up on the center stand?  ;)
Offline Gabriel
  • Near Galveston
« Reply #7 on: July 14, 2013, 07:15:26 AM »
Oop's wrong thread
