Author Topic: 2010 Grip  (Read 2629 times)
Offline att2008vn
  • Country: vn
  • C14 2010 ABS
2010 Grip
« on: June 05, 2011, 10:42:33 AM »
Hi,
Anyone has replaced the stock grip on 2010 ??  The '10 comes with Heated Grip so i wonder if it should be a different than "normal" grip.
Thanks
at
Offline GordonM
Re: 2010 Grip
« Reply #1 on: June 05, 2011, 10:58:09 AM »
2010 heated grip looks like a stock grip, heating element is molded in to grip material.  Grip is flexible enough and can be removed using compressed air and a little effort depending on how much grip glue the factory used on installation.  I was able to remove mine and reinstall them on my LSL bars.
Gordon
Offline att2008vn
  • Country: vn
  • C14 2010 ABS
Re: 2010 Grip
« Reply #2 on: June 05, 2011, 11:00:08 AM »
Hi Gordon,
It means that i cannot use the grip i like but have to use the stock ones in case i want to change it ??
at
Offline Kazairl
Re: 2010 Grip
« Reply #3 on: June 05, 2011, 03:07:53 PM »
You can change them to anything you want. But you loose the heated grip feature. Right now a slip over grip like a Grip Puppy or similar is all you can use if you want the keep your heated grips. Or use an aftermarket heated grip.
Offline JetJock
Re: 2010 Grip
« Reply #4 on: June 05, 2011, 03:09:44 PM »
Gordon
Uhhh . . . no. The heated portion is separate, a rubber inner layer with the heating wires. The outer grip is just a grip and can be replaced.
« Last Edit: June 06, 2011, 05:13:24 AM by JetJock »
