Hi guys,
This is an issue that I've had the dealer look at and they told me I'm imagining things. I'm not, and the dealer has proven to be a pack of idiots (Broward Motorsports of Palm Beach).
This happens hot or cold, but more when it's cold. Now I'm in Florida, and it's summertime, and cold is about 80 degrees...
I seem to have an issue at very low speed and RPM that is only really noticeable when moving through a parking lot, for example - where I'm just trying to move slowly - just above idle speed, say 1500-1800 rpm...with the clutch partially engaged. (I notice it when letting the clutch out.)
It gets a little bit "jerky". 2 or 3 hiccups, then runs like normal.
If I let the clutch out all the way, it will idle me around with no problems - smooth.
It seems to be when the clutch is either on it's way out, or half-engaged (like when doing a tight circle or u-turn). It's supposed to be AMSOIL in the crankcase, but I don't think the dealer put it in even though I paid extra for it...I will replace the oil next week myself. (The only reason the dealer is touching it is because I bought the prepaid service package thinking I would "save" on the valve adjustment).
I've also developed a slight occasional popping on hard deceleration if that helps.
This has been going on for several months now. I have about 16,500 on my 2012 bike. Like I said, the dealer "didn't notice anything", and basically told me I was nuts, but I've been riding my Concours since mile 1, and it's always been smooth as silk in any operating condition.
So I thought maybe the valves needed adjusting, and took it in at 15,000 for the required adjustments...I don't believe they did ANYTHING. This is a different story and argument, but lets just say they "forgot" to change the air filter, and the one plug I pulled did not look brand new after 1000 miles on it. They kept it for 3 days and returned it to me with the same issue (that I was making up). I'm pretty positive they didn't do a damn thing but change my oil, but again, this is a different issue, just stay away from this dealer is what I'll suggest....when I called them on things, they "said" they did everything, but never produced a worksheet for the valves either.
Anyway, the bike runs fine, pulls hard, etc. It's just at this slow speed that's bugging me. There's no valve pinging, everything sounds great. Another clue - I now have some vibration when doing 85+ on the highway...leading me to think that the FI's are not synced either.
My only mod is a Delkovic pipe, and I've had that on for at least 5000 miles with no issues, popping, etc. so I know it's not the 18" pipe.
So other than starting out with trying some fuel injector cleaner (looking for a good brand suggestion)...any ideas? Anyone else experienced anything like this?
Most people would hop on my bike and say "it runs great", but I KNOW it's had better days.
Thoughts?
Thanks in advance, guys!
Mark
