Author Topic: MC Enterprises Canyon Cages  (Read 30153 times)
Re: MC Enterprises Canyon Cages
« Reply #40 on: October 29, 2013, 08:07:43 PM »
Only nit pick I have, and it's just ME (cuz I'm anal like that) that the rear upper motor mount bar could be of better quality. Similar to
the factory one the was removed. Also the way the bar and welded bolt capture inside the right side cage could have a slightly better
design.....
I still love them and the "nit picks" would not have kept me from purchasing them..............
Excellent points.
Ryan, GEN 2Cages.  ;D
« Reply #41 on: October 29, 2013, 09:23:48 PM »
Excellent points.
Would that be gen2 gen2?  ???
Offline RyanMCEnterprises
    • MC Enterprises
« Reply #42 on: October 30, 2013, 08:40:40 AM »
Got them yesterday and installed them today during the 1st engine oil and  gear drive oil service. Other than a small blemish in the powder coat on the right side cage, I am quite happy with them. Installation was simple, and took me about an hour for the front and rear cages (for the bags).
Only nit pick I have, and it's just ME (cuz I'm anal like that) that the rear upper motor mount bar could be of better quality. Similar to the factory one the was removed. Also the way the bar and welded bolt capture inside the right side cage could have a slightly better design.....
But hey, do not flame me!!!  :o
Nice product.
Cheers,
-Mark-    8)
Thanks, Mark! I'm glad to hear you like them!
Excellent points.
Gen 2 Cages? As in the 2008-2009 C14? We have those...
« Reply #43 on: October 30, 2013, 09:02:42 AM »
I probably should of said Version 2.
    • MC Enterprises
« Reply #44 on: October 30, 2013, 11:27:14 AM »
Ohhh you mean a second version of that same guard. Now I get it! At first I thought you were suggesting that we should make a Canyon Cage for a new bike. D'oh!
« Reply #45 on: October 30, 2013, 12:58:12 PM »
Ya, a new version with the upgrades that RcrBoy suggests. I bet it would just drive the cost up on the cages though.
I will repeat what RcrBoy said, "I still love them and the "nit picks" would not have kept me from purchasing them.............."
Offline RBX QB
« Reply #46 on: October 30, 2013, 01:12:11 PM »
^ that.
2011 Concours 14 ABS
Offline RcrBoy
« Reply #47 on: October 30, 2013, 01:15:15 PM »
Should you ever decide to have a machinist make a better bolt for that rear upper mount I will buy one.....
-Mark-
    • MC Enterprises
« Reply #48 on: October 30, 2013, 04:24:05 PM »
-Mark-
Forgive me but I'm still a tad confused on which part you're talking about. Are you talking about the long bolt that goes through the entire bike at the rear mount? I guess it was just the "upper" part that threw me off as there is only one rear mount so I wasn't sure if you meant the upper front mount or just the rear mount itself. Unless I'm thinking of the wrong guard altogether. You're talking about the Canyon Cage for the 2010-2014 Concours, correct?
« Reply #49 on: October 30, 2013, 04:50:07 PM »
I just want some nice plug for the "hole" in the right tube that go through the bike (front set).  They should include some type of cap or plug!!  I am showing rust in that hole now (pic is before the rust)
Offline RBX QB
« Reply #50 on: October 30, 2013, 04:54:15 PM »
Mine came with a plug.
Offline RcrBoy
« Reply #51 on: October 30, 2013, 05:24:15 PM »
..................... the long bolt that goes through the entire bike at the rear mount?
Yes.
It's three pieces of  $#*/  welded together............
I know it's inside and you can't see it.
But.
It bugs me......................
 :o
« Reply #52 on: October 30, 2013, 05:41:48 PM »
My memory is weak.  Either mine did not come with a plug or it came with one that would not fit...
Offline RBX QB
« Reply #53 on: October 30, 2013, 06:06:28 PM »
I've never tried installing mine... I recall others stating that it was a (retracted colorful expletive) bear to fit.
Offline wingrider
« Reply #54 on: October 30, 2013, 07:55:18 PM »
Line the plug up. Carefully smack it with a hard plastic hammer. Goes right in.
« Reply #55 on: October 31, 2013, 04:30:17 AM »
+1 for the right side. The left side on the Gen 1 bikes that needs a plug too.
    • MC Enterprises
« Reply #56 on: October 31, 2013, 08:29:11 AM »
I can't remember for sure but I believe there was a reason we couldn't plug that spot. I'll be sure to look into this today. If it can be plugged, I'll PM you for your address and get one sent out to you.
Yes.
But.
 :o
It's actually 3 pieces welded together that NEED to be welded together. I know it's not that pretty but it is inside of the bike and it has to have that hex section welded to it so it'll sink into the saddle and stay stationary. I suppose we could get it powder coated though to make it look a little better. If anyone has an idea as to how to improve that piece of hardware, I'd be more than happy to hear them out.
This is how most people tend to install that plug and it seems to work fine. I don't understand why a few people were having such trouble with it unless our supplier accidentally sent us a few different sized plugs mixed in with our order in which case it would make perfect sense. We're always willing to replace pieces at no cost that don't work for people though. All they have to do is ask!
Same as the 2010-2014 Concours Canyon Cage, I believe there was a reason we couldn't plug the left side. I'll definitely check into this today though along with the #1400-410. If it can be plugged, I'll make sure they add that to the kit.
« Reply #57 on: October 31, 2013, 09:54:10 AM »
Do you really want to know about plugs?  :rotflmao:
« Reply #58 on: October 31, 2013, 10:15:47 AM »
Knowing you, no.    ;)
« Reply #59 on: October 31, 2013, 10:26:54 AM »
Wise answer, grasshopper.
