Author Topic: Oil capacity  (Read 3156 times)
Offline nevadazx12
Oil capacity
« on: June 07, 2013, 03:50:59 PM »
Thought I had this figured out, but in my owners manual in the section discussing changing oil it has the spec of 3.2 quarts with filter.  Now in the specifications in the front under capacities it has 3.9 qts with filter.  Checked the service manual and it is 3.2.    :P :yikes:
« Last Edit: June 07, 2013, 09:24:31 PM by nevadazx12 »
1986 Connie
1974 BMW 90/6
1964 Triumph T100SC
Offline Daytona_Mike
Re: Oli capacity
« Reply #1 on: June 07, 2013, 04:29:56 PM »
Your going to use the sight glass anyway. Dont forget, there are 2 drain plugs.
3.7 after engine disassembly
3.0 liters with filter change
2.7 liters without filter change
Offline works4me
Re: Oli capacity
« Reply #2 on: June 07, 2013, 04:31:17 PM »
That's correct. You're absolutely right.
Offline Mettler1
Re: Oli capacity
« Reply #3 on: June 07, 2013, 10:29:41 PM »
   Same here.
Offline nevadazx12
Re: Oil capacity
« Reply #4 on: June 08, 2013, 10:46:04 AM »
Thanks guys.  Had to go to a conversion table to get answer, 3.0 liters is 3.17 quarts.  No wonder my sight glass was always full.  :yikes:
1986 Connie
1974 BMW 90/6
1964 Triumph T100SC
