Author Topic: 2009 to 2010 Storage box swap  (Read 3822 times)
Offline Spackler
« on: May 18, 2013, 06:04:38 PM »
Does anyone know if its possible to remove the tank top storage compartment from a 2009 and replace it with the tank top trim piece (with no compartment) from a 2010+?
Thanks
Offline Spackler
Re: 2009 to 2010 Storage box swap
« Reply #2 on: May 18, 2013, 06:22:15 PM »
So it's not a direct swap? Looks like there was some fabrication involved to get it to work.
« Reply #3 on: May 18, 2013, 06:31:50 PM »
You could buy a '10 bracket and modify it slightly or make your own as I did.
Offline Spackler
« Reply #4 on: May 18, 2013, 06:35:37 PM »
I'm going to give it a go. I want to use the riser adapters for more pull-back, and there a no-go with the storage box.
« Reply #5 on: May 18, 2013, 06:37:51 PM »
The box was about useless to me and interfered with the tank bag I wanted to run.
Offline Spackler
« Reply #6 on: May 18, 2013, 06:45:33 PM »
It doesn't hold much. My sunglasses and some ear plugs. And it doesn't lock so ultimately all I put in there are my earplugs.
« Reply #7 on: May 18, 2013, 07:11:31 PM »
I didn't have any problems with any of the risers I used with the box...  Which risers are you thinking about?
Offline Spackler
« Reply #8 on: May 18, 2013, 07:23:33 PM »
These:
http://www.advancedsporttouring.com/Concours_14_Risers_p/c14-16.htm
From the page:
*Application: 2010-2013 Kawasaki Concours 14. These will not work on 2008-2009 due to the location of the storage compartment.
I found the part number for the 2010+ tank plate but can't find the bracket part number.
« Reply #9 on: May 18, 2013, 07:40:19 PM »
I'd be steamed if I needed to pull the box, my Autocom is in there, along with the cables, registration, and PCV cable...  It's also a handy place for my spare magazine/s ;)  I do have issues when I pull the box due to the LSL risers, but I deal with it.  No issues when running.
« Reply #10 on: May 19, 2013, 05:00:07 AM »
Try this but do your own confirmation. Part#11056
http://www.kawasakipartshouse.com/oemparts/a/kaw/500b8290f8700223e4799674/chassis-electrical-equipment
« Reply #11 on: May 19, 2013, 07:49:28 AM »
These:
From the page:
I used Heli 1 3/4 and Phil's wedges and didn't have a problem.  I wonder why they're called risers when it seems that they're lowering the bars.  I've never heard of such a thing.  The intent of risers is to 'rise'.  The wedges change the angle a bit.    Anyway, good topic for a mod.
Offline Spackler
« Reply #12 on: May 19, 2013, 08:10:28 AM »
I'm using 2" risers but I think those riser adapters would be nice for the additional pullback they provide. He makes a set of risers with the additional pullback, and those adapters for those who already have risers.
