Author Topic: Throttle binding  (Read 4889 times)
Offline katata1100
Throttle binding
« on: May 14, 2013, 09:07:04 AM »
When I twist the throttle grip, sometimes it feels like I can feel something rubbing. Is there something inside that needs to be greased?
Re: Throttle binding
« Reply #1 on: May 14, 2013, 09:16:40 AM »
You could have some debris inside there but normally no lube is required.
Check your grip. Once in a while the grip on the throttle tube will slide up and bind a bit. I give it a lil blast of air from my compressor while pulling it down. I have to do this about twice a year.
« Reply #2 on: May 14, 2013, 09:20:38 AM »
I'd bet on the grips as well.  Have you lubed the cables??
Offline katata1100
« Reply #3 on: May 14, 2013, 09:26:35 AM »
Nope, haven't done that. Any suggestions on how do do this? What should i use to lube cable?
« Reply #4 on: May 14, 2013, 09:32:09 AM »
Check out Cycle Gear, they have an inexpensive kit that includes the cable luber and lube.  This reminds me I need to do my cables, it's been a couple years :(
« Reply #5 on: May 14, 2013, 09:39:12 AM »
This is the kit that I use, works great.
https://www.denniskirk.com/petrochem/cable-care-kit-72005.p3132.prd/3132.sku
« Reply #6 on: May 14, 2013, 05:03:12 PM »
Please put the model year of your bike in your avatar or signature :)   It can greatly help people when troubleshooting...
« Reply #7 on: May 14, 2013, 06:02:03 PM »
Oh Max....you're incorrigible.   (word of the day for tomorrow)
« Reply #8 on: May 14, 2013, 06:32:04 PM »
Somebody has to pick up the slack.
« Reply #9 on: May 14, 2013, 06:55:49 PM »
The year of his Katana?? How is that relevant to this thread Spock?  ???
« Reply #10 on: May 14, 2013, 06:59:10 PM »
Is there a differance in throttle setups between gen 1 or 2 bikes?  Just wondering out loud here.
« Reply #11 on: May 14, 2013, 07:34:32 PM »
We don't know, SOP.  Someone would have to chime in who knows both setups...
« Reply #12 on: May 14, 2013, 07:48:31 PM »
Where's Fre*H when we need him?
« Reply #13 on: May 14, 2013, 09:06:18 PM »
Katana??
Yes.   Plus, the answers will not be quite the same for such a situation on a 2012 vs a 2008...
Offline katata1100
« Reply #14 on: May 14, 2013, 09:20:03 PM »
The year of my katana? It is a '91. But, my C14 is a '11.
The throttle on my katana is fine, but if you twist it too much, you might be looking up at the sky ;D
« Reply #15 on: May 14, 2013, 09:24:28 PM »
Waiting on 'the other side'.
« Reply #16 on: May 14, 2013, 09:29:18 PM »
Most likely it is the plastic throttle tube grinding its way through the aluminum post that is used as a handlebar grip. I swear that while there might be a worse system, I cannot think of it offhand. Whatever you do, do NOT lube it with anything wet or of a paste consistency as that will only make lapping paste to accelerate the wear and increase the drag. Take the throttle tube off the right handlebar, clean both the tube and the (now probably badly worn and grooved) aluminum handlebar thoroughly, and then coat the handlebar with plumber's Teflon tape. Be very careful with the tape not to get wrinkles in it and don't overlap it so that it is more than two layers thick but otherwise it will be like having a new bike. Then clean and lube the clutch and brake lever pivot points as well as the shifter and rear brake pivot and it really will act like a new bike. Really.
« Reply #17 on: May 14, 2013, 10:10:36 PM »
How so?  Heated grips OEM vs non OEM?
« Reply #18 on: May 15, 2013, 03:59:12 AM »
I think we're doing quite fine at the moment.  He's much too busy somewhere else and that's all I'm going to say about that.
Brian is right on with his explanation.  However I have a question.  Did the OP just start noticing this (gradual onset) or was it like all of a sudden?  Just trying to determine the when at the moment.  Has any work been done on the grips or around where the cables operate?  I had some issues with my throttlemeister that caused the throttle not to return correctly (all my fault).  I can't say that we've seen issues with the cables or grips with this bike.
« Reply #19 on: May 15, 2013, 05:31:04 AM »
So, knowing if the bike is new or old would help to answer that.  It wouldn't make that much of a difference, but it is yet another clue when trying to solve a puzzle....
My responding to you is also answering "Silverylightblue"'s question :)
