Author Topic: 90 degree valve stems  (Read 7573 times)
« on: May 08, 2013, 04:08:13 AM »
I'm thinking of adding a 90 degree valve stem during my next tire change which is going to occur very shortly on the rear wheel.
Murph has two types, a one piece or a two piece.
http://www.murphskits.com/catalog/product_info.php?cPath=130_136&products_id=417
http://www.murphskits.com/catalog/product_info.php?cPath=130_136&products_id=494
Any advantage to using either?  The tire is coming off regardless.
Re: 90 degree valve stems
« Reply #1 on: May 08, 2013, 04:26:48 AM »
I haven't used either but I would think one piece would be better than two piece.
« Reply #2 on: May 08, 2013, 04:36:40 AM »
Less chance of a seal going bad?
« Reply #3 on: May 08, 2013, 04:47:36 AM »
It may not be an issue but one less joint to possibly leak.
Offline Broz
« Reply #4 on: May 08, 2013, 05:43:39 AM »
I went w the 1 piece. Makes airing up so much easier.
Semper Fi
Broz
2012 C-14.  Black
Offline Sinstr
« Reply #5 on: May 08, 2013, 07:37:53 AM »
I have been running th eone piece for the last six months, no problems.
Sinstr
Offline CrashGordon
« Reply #6 on: May 08, 2013, 04:18:21 PM »
Can't help you on one vs. the other. Went with the one piece at my last tire change and they work great. As was mentioned in an earlier thread, they seem to hold air better than the stock ones did.
Offline fmwhit
« Reply #7 on: May 08, 2013, 06:44:15 PM »
I have had both and I like the one piece better.  It seems like it is stronger.. Its definitley a great addition to this bike.
« Reply #8 on: May 09, 2013, 04:26:54 AM »
That's what I'll go with then.  Now, I have to remember if I ordered anything from Murph yesterday morning.... ::)
Offline C1xRider
« Reply #9 on: May 09, 2013, 11:24:14 PM »
I removed my 90 degree valve stem.  I couldn't keep the tire balanced with it on the wheel.  Of course it was only a problem once the speedometer moved into triple digit range, so it might be acceptable to most.  I guess the phrase YMMV is applicable here.   ;)
« Reply #10 on: May 10, 2013, 04:07:17 AM »
This brings up a good point...for the ones that do have the 90 stem, do you have it mounted parallel to the wheel or facing outwards?  I'm thinking parallel at the moment would work best for me.
C1x, did you balance the wheel or did you get balanced via machine?
Offline C1xRider
« Reply #11 on: May 10, 2013, 10:13:45 AM »
I balanced it myself using the gravity method, several times.  I was really surprised how much weight it required the first time after I installed it.  Don't remember exactly, but it was more than I expected.  That was with a PR2 rear.  Never installed one on the front.
Offline DGOLD
« Reply #12 on: May 10, 2013, 12:40:16 PM »
I love the 90 degree one piece! It faces out and no issues with the balance. Now I don't curse every time I add air.
« Last Edit: May 10, 2013, 01:36:00 PM by DGOLD »
2010 c14(current mistress)
« Reply #13 on: May 10, 2013, 12:41:36 PM »
Pity, we could use some more cursing.. :censored: :censored: :censored: and  :censored:
« Reply #14 on: May 10, 2013, 01:07:12 PM »
:censored: that :censored:
Offline marku8a
« Reply #15 on: May 10, 2013, 02:17:54 PM »
I have the one piece 90s pointed outboard. I gravity balanced mine and have no problem at XXX mph.
Mark
2009 C14 Red
Offline Broz
« Reply #16 on: May 11, 2013, 05:25:12 PM »
Everyone knows your supposed to have one point to the left and one point to the right and bingo......Balanced.
Semper Fi
Broz
2012 C-14.  Black
« Reply #17 on: May 12, 2013, 07:14:04 AM »
I didn't know that...or are you pulling someone's leg?
Offline marku8a
« Reply #18 on: May 12, 2013, 10:47:44 AM »
So I guess that explains why mine is balanced. I installed the rear pointing right so it would be on the "up" side while parked on the side stand. I had the dealer install the front while replacing the TPS under warranty. Although I taped a note on the windshield and a note on the wheel itself saying to point right, they installed it pointing left!
VirginiaJim - It shouldn't make any difference having them pointed in the same direction. Having said that, I would be interested to know if someone had a different experience.
Mark
2009 C14 Red
Offline Broz
« Reply #19 on: May 12, 2013, 02:16:03 PM »
I was joking. But I too had the rear pointing right front left. But flipped the rear to point left to keep it from a hot muffler incase I have to do roadside repair. Haven't ridden bike since  changing it. Waiting for my ECU.  I seriously doubt the few grams  10mm off center will be noticeable.
Semper Fi
Broz
2012 C-14.  Black
