Author Topic: Driving Light Hookup  (Read 5065 times)
Offline chap
« on: May 05, 2013, 08:03:21 PM »
So I am putting some LED Driving lights on my 2010 C14. Today I connected them up, and have been trying to figure out where to get the power to run these lights. I had a brainwave (dangerous I know). I thought I would connect them to the Grip Warmer cct, as I hardly ever use them. I connected to the Warmer Switch side of the Grip Warmer Relay, to get switched power. I connected everything and tried it out. Perfect, well for a few mins (3-4). Then the lights went out. No Blown fuse. So  I tried again. It works, but only for a few mins. First question. Why is the ECU killing power to the grip warmer after a few mins. Second. Is there a convenient place to get power, It is less than 5 Amps I need for these LED Lights (I was thinking about the City Light cct, but not sure if there is enough spare amps there). I don`t want to use up the Aux power as I am already running GPS and Audio on that. I did`n`t want to pull the tank to run a new cct, but I may have to.
Thanks for any suggetions
2010 Concours ABS = Blue
2003 Concours - Red (sold)
Offline jtk1531
  • Country: my
Re: Driving Light Hookup
« Reply #1 on: May 06, 2013, 12:45:49 AM »
if i'm not mistaken, there's a circuit to cut power on and off to the grip warmers if your bike isn't moving.
it's to prevent the battery from going flat.
i didn't need to pull the tank or side panel when i installed a new relay + fuze + wiring for a new horn. so i guess you can install a new set of wiring for your lights without too much trouble.
Offline McJunkie
« Reply #2 on: May 06, 2013, 04:14:57 AM »
Why not just run a wire directly from the battery for your lights using a relay and fuse. Then tap into the acc. wire to switch the relay.
« Reply #3 on: May 06, 2013, 06:09:45 AM »
If you want switched power I used the front accessory leads under the top left black fairing.
Offline ljcorby
  • COG#: 9359
« Reply #4 on: May 06, 2013, 06:17:56 AM »
That's what I used...+1
10 Kawi Concours 14 ABS
Offline chap
« Reply #5 on: May 06, 2013, 07:06:04 AM »
Thanks guys for your responses. I will see if power is restored when I start moving the bike. Plan B will be to run a separate power wire with fuse and relay for the lights. I would be interested to know how you routed the wiring without moving the tank.
Offline ljcorby
  • COG#: 9359
« Reply #6 on: May 06, 2013, 07:53:37 AM »
If you go to the accessory lead on the front left side of the bike you don't have to deal with the tank.   8)
Offline chap
« Reply #7 on: May 06, 2013, 08:14:04 AM »
Thanks. But, as I stated, I a am already using thet cct for my GPS / Audio System. That cct unfortunately is limited to 5 Amps.
Offline jtk1531
  • Country: my
« Reply #8 on: May 06, 2013, 11:06:07 AM »
take off the right inner cover (black plastic panel), and its a big empty space there all the way down to the battery area.
take off the battery cover (plastic panel), and you can just push a wire down that space to get to the battery's positive terminal.
with all the covers back in place, no wires are visible.
Offline chap
« Reply #9 on: May 06, 2013, 01:18:28 PM »
Awesome. Thanks
« Reply #10 on: May 06, 2013, 02:39:59 PM »
great time to hookup a fuzeblock.
and it will eliminate 99% of current draw from your accessory plug (plug will only be used to determined "switched" power)
Offline freebird6
  • In a big country...
« Reply #11 on: May 10, 2013, 11:57:54 AM »
It would be a good time. Fuzeblock website says they are out of stock. Have been for a while. Any links as to where to find a Fuzeblock? I have been trying to run one down for a bout 6 weeks.
2008 Concours
2007 Mean Streak
99 r1100rt
Offline coldhearted22
2012 Candy Arabian Red Concours 14
Offline Broz
« Reply #13 on: May 11, 2013, 05:37:31 PM »
You don't actually need to remove the side panel to run the wires. There is a good video on:   Www.advancedsporttouring.com.  Fishing the wire up the right side from the battery box is the ticket.
Semper Fi
Broz
2012 C-14.  Black
