Author Topic: zx-9 front end conversion complete!  (Read 28822 times)
Offline Uglydog56
« on: June 02, 2011, 10:25:24 PM »
I drove it and everything!  On the first trip, the handling was less than exemplary, plus the speedo didn't work.  I got home and found I hadn't set the sensor close enough and the front tire was only at 25psi.  Back out with 40 in the front and it was another story.  Previously I had progressive springs and 15w oil.  Now the bike is much more composed over bumps, yet has no dive when grabbing a handful of brake.  That plus the C14 rear shock has really made this a new motorcycle.  I didn't get real aggressive as it's a little wet out and the front tire is brand new, but it feels very stable and relatively ease to maneuver.  I have some 1" bar risers on the way; once they are installed I may drop the front forks about 5mm and see if it hurries up the turn-in a little.  I've been riding my CB400 to work in the mean time and it has spoiled me a little with its instinctive handling.
Rick A. Cone
COG #9186
98 Connie, 76 CB400F
Offline GF-in-CA
Re: zx-9 front end conversion complete!
« Reply #1 on: June 02, 2011, 11:10:41 PM »
Rick,
What tires are you using?  I have Shinko 011's right now, and the turn in seems effortless.  Are you using the C14 shock without a lowering link?  I have a ZZR shock on the back, so the rear is not as high as with the C14, so I would think your turn in would be even quicker than mine.  I recommend riding it a little before dropping the front, JMHO.
BTW, great to hear it's done, when do we get to see pictures?  :D 8) :thumbs:
Gary F.
1998 C10
California North State
Offline Centex
    • Central Motorcycle Roadracing Association
« Reply #2 on: June 03, 2011, 06:35:37 AM »
enquiring minds want to know ....
What's the fork offset with the ZX-9 setup (distance from stem centerline to fork tube centerline)?
How 'bout the maximum static fork length (distance from top of head tube/bottom of top triple to the axle centerline with the bike on the wheels but no rider)?
Bottom line, wondering if the ZX-9 setup has less trail than stock and how much.  Yep, trail is maximum with forks lowest in the triple and rear ride height also affects trail.
Thanks!
Alan in Central Texas
2004 Connie COG 9476
2001 Ducati M750
Offline Uglydog56
« Reply #3 on: June 03, 2011, 09:32:12 AM »
I have roadsmarts, 120/70 front and 170/60 rear.  Not my first choice, but the rear was literally brand new, so I'm going to wear them out.  2" lowering link in rear, which changes the rake quite a bit.  I figure with the 170 tire and C14 shock that puts me about 1" lower than stock.  When I had the 17" rear but still had the stock front on I had dropped the forks in the clamps until the dust seals were 1/4" away from the lower triple at full compress to get it to turn in adequately.  It is supposed to be beautiful all weekend, so I'm going to scrub in the tires and go relearn the bike..  The combination of untested parts, new tire and wet roads made me somewhat apprehensive yesterday which was undoubtedly a factor in all this as well.
AFAIK, the trail was around 4.4" vice 4.8" stock?  Foggy memories from old board?  Haven't measured length but I thought someone said it was 30.38, same as zrx front?  I'll have to dig around the zrxoa forum where Gary got his info from and see what I can find.
Rick A. Cone
COG #9186
Offline Uglydog56
« Reply #4 on: June 03, 2011, 09:57:46 AM »
Gary, I completely screwed up the front fender while attempting to clear it, plus my fenda extenda came in, so you're going to have to wait for pictures until I sand and repaint the pieces.  My comment on the looks is that it lresembles an ST1100 much more than a BMW now.  The front fender's not even going to match when I'm done, but it should be close enough for government work.  I'm painting the fender GM emerald green metallic over semi-flat black to darken it up.  It isn't dark enough but it will do until I paint the whole bike this winter.
Rick A. Cone
COG #9186
Offline GF-in-CA
« Reply #5 on: June 03, 2011, 10:26:09 AM »
Thanks!
Alan,
Bottom line, the trail with the ZX9 front end is less than the stock C10.  Rick has the numbers right, I calculated the new trail to be about 4.4", while the C10 is 4.8".  Stock offset is about 1.6", and the ZX9 offset is about 1.4".  I measured the ZX9 fork length to be 30.38", and my Connie was 30.88" from center of axle to top of triple.  I modified the ZX9 top triple to put the top at the same location as stock, relative to the steering head, so there is a .5" difference in installed fork length.  With the smaller tire, the front end is about 1" lower, which is where the decrease in trail comes from.  In comparison, the ZRX front end has an offset of about 1.2", with the same fork length as the ZX9, so the trail ends up being more with the ZRX setup on the Connie.  Having ridden my bike with the ZX9 front end and a Connie with the ZRX front end, I can say that the ZX9 front end definitely steers quicker, which confirms the trail numbers.  Both setups work really well, but after riding the ZRX setup, I came away happy that I chose to do what I did.
Gary F.
1998 C10
Offline Centex
« Reply #6 on: June 03, 2011, 12:50:21 PM »
Thanks Rick and Gary for the info, all interesting and useful as I continue to play with the Connie.
Rick, jumping between the C10 and your CB400 must be similar to the contrast I have ... see my sigline  ;D
2001 Ducati M750
Offline Tele130
« Reply #7 on: June 03, 2011, 06:29:40 PM »
Heck, I wanta see some Pictures ::) :thumbs:
Doug Colton
Offline GF-in-CA
« Reply #8 on: June 04, 2011, 01:16:22 PM »
Hopefully I'm not stealing Rick's thunder, but I took a few pictures today while dodging raindrops.  I had posted some photos on the old forum from when I finished the project, but the thread went away with the crash.  Besides, I've made some updates since then.
I hope Rick will give us some photos soon, I really want see how the Mean Streak front wheel and the instrument panel worked out.  8) :thumbs:
Gary F.
1998 C10
Offline Uglydog56
« Reply #9 on: June 04, 2011, 06:30:56 PM »
Okay, here are pics.  I didn't get the front fender fixed, it's too sunny outside.  Please note I'm not Gary or Jim Miller or Bergmen - the bike is dirty and I've got some fit/finish to deal with after The Great Motorcycle Trip (which commences in two weeks).  But, on the whole, I'm satisfied.  I sunk the forks 10mm today and now the bike is awesome!  I contend that since I've lowered it about an inch in the rear, I needed to lower some in the front to match.  The bike is so stable, so compliant, and will put a peg on the ground so easily and drama-free it isn't even funny.  This is the first bike I've ever ridden with cartridge forks, and I can't believe the difference.  I have the preload all the way out (no preload), and about halfway on the bottom one and 1.5 turns from full hard on the top one.  I THINK bottom is compression and top is rebound, but don't quote me.
I still need the cover for the center of the handlebars, or maybe polish the upper.  I put 1" bar risers on it, and now it looks like a conglomeration of crap.  I'm going to get 1.6's and have less pieces.
Rick A. Cone
COG #9186
Offline GF-in-CA
« Reply #10 on: June 04, 2011, 07:04:07 PM »
Very nice, great job, Rick!  Your description of the suspension action and handling match my impressions exactly.  Rock solid stability, yet able to lean as far as you want with little effort.  You'll come to appreciate it even more as you continue to ride it.  It makes sense now that you would drop the front a little to get to the same place I am, since I have the ZZR shock without a link, and my rear is raised slightly more.  I really like the instrument panel, too, and the front wheel looks like it was made to be there.
You're correct the bottom adjuster is compression and the the top is rebound.  I'm at 1 click out from full soft on compression and about midway on rebound.  I can actually feel the difference between a couple clicks, so the adjustments are actually meaningful, unlike some suspension I've had.
Enjoy the ride, sounds like you've got a good one coming up.  Once again, nice job!   8) :thumbs:
Gary F.
1998 C10
Offline Uglydog56
« Reply #11 on: June 04, 2011, 11:50:51 PM »
Just got back from riding around the Hood Canal - a good ride to set things up.  This was two up with luggage and the trunk.  I ended up 1 click softer on rebound up front, and went from 1 3/4 all the way to 1 turn from full hard on the rear shock, and ended up at 9 clicks preload on the rear.  This is with 40r/42r in the roadsmarts.  I determined at this point that the handling was nearly perfect.  The local police officer concurred with me assessment and charged me 196 bucks for testing performance on his roads  :( Still a great ride however.
Rick A. Cone
COG #9186
Offline kawaholic
« Reply #12 on: June 06, 2011, 11:07:43 PM »
nice job rick, looks great. i really like the look with the matching wheels. so is it just the three of us now or are there more out there?
sorry i haven't been checking in much lately. i just found out tonight that the old site is gone... :'(
also, don't polish the upper triple. i made that mistake. i put a lot of effort into it and got it looking like chrome. when the sun is high in the sky and you get the right angle while riding down the road, that thing will blind you. i found a nice carbon fiber cover for the triple on fleabay. i haven't installed it yet but if you're interested i can dig up the link for you.
tom
04 connie
07 zx6r
02 kx250
Offline Steve in Sunny Fla
    • Shoodaben Engineering
« Reply #13 on: June 07, 2011, 05:58:01 AM »
I rode the bike pictured above (hey Tom!) at the RWTW up in the north Ga mountains. what I came away with was that it was real easy to ride it fast - I've been trying to keep my bike "sleeper" but I'm starting to think about this zx9 conversion a bit harder... Steve
Offline Uglydog56
« Reply #14 on: June 07, 2011, 08:42:53 AM »
Steve, nobody but a couple of us weirdo cogger's even know what the front end is supposed to look like. I probably have the most modified bike in the parking lot at work (probably 40+ there of multiple shapes and sizes) and don't get a single comment except on the exceptional number of driving lights and a few speculations on my eyesight and/or sanity.
Rick A. Cone
COG #9186
Offline GF-in-CA
« Reply #15 on: June 07, 2011, 08:47:33 AM »
Hey, Tom, welcome back!
Steve, I concur with Rick, don't think, just do it!  I know you want your wheels to match and stuff, but you can barely see the wheel anyway with those big rotors.  :stirpot:
Gary F.
1998 C10
« Reply #16 on: June 07, 2011, 05:59:12 PM »
So if I do this, i already have the 320's and the 4 pots. what else do I need, top and lower tripple, forks, wheel, speedo drive, fender? how'd yall go about sourcing this stuff, a little here, a little there?
Offline GF-in-CA
« Reply #17 on: June 07, 2011, 09:18:21 PM »
Steve,
Here's my list of the required parts from the old forum.  I know you wouldn't need all the parts, but I've included everything for the sake of completeness:
-  Forks from a ZX9, model year 1994 thru 1997 model (B1 thru B4).
-  Upper and lower triple clamps from a 1994 thru 1995 ZX7, or a lower triple clamp from a 1994 thru 1997 ZX9 and the upper triple clamp from a 1994 thru 2001 ZX7
-  Wheel, axle, speedo drive, and 320 mm rotors from a donor compatible with the ZX9
-  Calipers compatible with the ZX9.  For the 1994 thru 1996 zx9 these would be 4 piston Tokicos or Nissins, and for the 1997 they would be 6 piston Tokicos.
-  Some way of mounting handlebars to the ZX7 top triple clamp, since the ZX9 used clip-on handlebars, which would not clear the Concours tank.  I bought some dirt bike handlebar risers that I adapted to the top triple clamp.
-  A fender from a ZX9 or ZX7, or an adapted fender.
Here is the list of donors that cross over or are compatible with the ZX9 front end.
The following bikes have interchangeable brakes/ wheels/ axle/ speedo:
ZX7    1993-1996  1997-2003 had different calipers but otherwise compatible
ZX9B  1994-1996  1997 had different calipers but otherwise compatible
ZX11D 1993-2001
Wheels/ axle/ speedo from the following will fit:
ZZR1200
ZRX1100/ 1200
Rotors:
Ninja ZX-750 J1/J2/L1-L3 (ZX-7) 91-95
Ninja ZX 7R (ZX750 K1/K2/M1/M2) 91-95
Ninja ZX 7R (ZX 750 P1-P8) 96-03
Ninja ZX-7RR (ZX750 N1/N2) 96-99
ZX-9R B1-B4 Ninja 94-97
ZX-9R F1/F2 Ninja 02-03
ZX 1100 D1-D9 Ninja 93-01
ZX 12 R A1/A2/B1/B2 00-03
ZX 1200 C1/C2/C3/C4 (ZZR 1200) 02-05
VN 1500 P1/P2 Vulcan Mean Streak 02-03
VZ 1600 K4/K5 04-05
VN 1600 B1/B2/B6F/B7F/B7FA/B8F/B8FA 04-08
Fender from 1994-1997 ZX9 or 1993-2003 ZX7, though the ZX7 fender will require some minor fabrication to fit.
Your GSXR/ ZZR calipers will work, but they use a smaller bolt than the ZX9 calipers, so you would probably want to make some sleeves to make up the difference.
You can pretty much source things in whatever way works the best for you.  The most cost effective way is to source a complete front end from a ZX9.  Then the only thing left is the top triple and your handlebar arrangement.  I bought my forks with the lower triple included, but sourced everthing else piecemeal.  Again, it depends on whether you have contacts, or are at the mercy of eBay.
I've got a lot more info, but hopefully that will get you started.   ;)
HTH,
Gary F.
1998 C10
Offline Uglydog56
« Reply #18 on: June 08, 2011, 09:56:32 AM »
To put the mean streak front wheel on a zx-9 front end, (this should work for zrx front end as well)  you put a zx-12 spacer on the left and machine 3mm off the existing zx-9 right side spacer.  An electronic speedo is required.  Flip the rotors so they angle in.  I just shimmed the caliper in with precision washers, I will get a measurement for the bushings that are going to replace them.  2 70mm 10mmx1.25x50mm and 2 10mmx1.25x45mm allen head bolts to attach the calipers (I just ordered four longer ones, but the bottom two are really close to the rotor).  I already had braided lines on my stock connie brakes and they transferred over.  There you go steve, the recipe for matching wheels!
Rick A. Cone
COG #9186
Offline Daytona_Mike
« Reply #19 on: June 08, 2011, 02:46:23 PM »
Rick,
 I would like to install the Mean Streak front wheel as it would match my rear wheel. They look great on your bike.
 I have already done so much to the front of my Connie  and it seems like  i would be going backwards. I already have 320mm rotors and 4 pots and sonic springs with emulators, fork brace ...
I guess I am on the fence right now and need coaxing.
