Author Topic: ECU removal  (Read 4185 times)
Offline eng943
ECU removal
« on: April 17, 2013, 05:40:47 PM »
This might be a silly question, but the ECU is under the passenger seat correct? I want to pop it off this weekend and send it to Guhl for a reflash.
Second Bike 2017 BMW R12R
Offline pistole
Re: ECU removal
« Reply #1 on: April 17, 2013, 05:48:32 PM »
yes. Under tool box
Offline eng943
Re: ECU removal
« Reply #2 on: April 17, 2013, 06:18:15 PM »
yes. Under tool box
Thanks for the reply. I am assuming a battery disconnect before removing the ECU is good protocol?
Offline Spanky
Re: ECU removal
« Reply #3 on: April 17, 2013, 06:37:56 PM »
Battery disconnect is a must! Not doing this is a good way to fry your ecu and they cost a little bit of cha ching  ;)
Offline Richard. Wales UK
  • 2010 1400 GTR trike.
Re: ECU removal
« Reply #4 on: April 18, 2013, 03:14:23 AM »
Hi
On mine the toolbox is held down by 4 security screws which have also had thread lock on them.
Managed to get them out using long nose vice grips.
Richard
Re: ECU removal
« Reply #5 on: April 18, 2013, 04:42:13 AM »
Yes, the ECU is under the seat but the ECU is NOT under the tool box.
See this thread for the location.
http://www.zggtr.org/index.php?topic=12672.msg157364#msg157364
Offline jonathan
Re: ECU removal
« Reply #6 on: April 18, 2013, 07:42:49 AM »
Technically that is correct, however there is no way to get the ECU out without removing the toolbox.
Re: ECU removal
« Reply #7 on: April 18, 2013, 08:45:02 AM »
Um, yeah.
Offline harryS
Re: ECU removal
« Reply #8 on: April 25, 2013, 06:22:40 PM »
I just removed the fuse right by the tool box labeled "ECU 15 amp". worked fine. the ecu is the one under the three plug box. the ecu has two connections.
Offline eng943
Re: ECU removal
« Reply #9 on: April 25, 2013, 06:52:08 PM »
ECU was sent to Guhl for reflash and is already on it's way back! Ordered Area P slip on and BMC street filter also. ;D
