Author Topic: Rostra regrets?  (Read 13494 times)
Offline GMan
Rostra regrets?
« on: April 08, 2013, 05:24:07 PM »
After spending the past 2 years hoping for a better cruise control option to appear, I've decided to quit waiting.  I've read all of the threads and Rostra appears to be the most popular, it's reasonably priced, and all of the installation instructions are a definite plus. Before I pull the trigger, I just wondered if anyone wishes they had made a different choice?  Also, is there anything about the installation that you would do differently? (I have an 09)  Thanks in advance for your collective wisdom!
Offline nxtdoor
Re: Rostra regrets?
« Reply #1 on: April 08, 2013, 06:37:44 PM »
I put it on my first 09 and loved it. No regrets. No reason to change how I did it the first time.
I get to do it again because some jerk hit me on the highway and totaled it. Just picked up another 09 a couple weeks ago and have it on the bench to install.
Best value in cc you'll find and no vacuum worries.
Just do it, you won't regret it.
Jeff
Re: Rostra regrets?
« Reply #2 on: April 08, 2013, 07:20:37 PM »
No regrets here. Has worked perfectly now for 2 years.
Offline MGvaleri
  • Country: it
Re: Rostra regrets?
« Reply #3 on: April 09, 2013, 12:02:25 AM »
Cost of KIT. Euro 15 Dollari 19.5
http://youtu.be/y_la_Ap5mrw
MGvalerio. 8)
Re: Rostra regrets?
« Reply #4 on: April 09, 2013, 05:48:19 AM »
I'm hoping to finally install mine next week.  I got all my projects together that require me to strip the plastics off the bike.  Going to install the Rostra, Fuse Block, Amber LED flashing warning lights, LED spot lights, pig tail for battery tender, pig tail for heated vest, and if I can find a place for my Stebel Nautilus I will install it as well.
Offline OCK913
    • The Orlando Riders Club
Re: Rostra regrets?
« Reply #5 on: April 09, 2013, 08:27:06 AM »
MGvalerio. 8)
That music makes me see 100 clowns getting out of a VW beetle.
            2009 Kawasaki C14 - Black
Re: Rostra regrets?
« Reply #6 on: April 09, 2013, 09:18:36 AM »
No regrets for choosing Rostra over current competition. Works great.
Thing I'd do different  :-[ : Be sure to do the thread making thing (thread forming) with a nut on the end of the cable cover (cable insulation), and screw the cable end into the plastic block(snap in adapter). It seems kinda mickey mouse that Rostra doesn't just put a threaded end on the cable cover, but the method they show does work pretty well. I didn't do it enough (only about 1/4 inch) and I was in a hurry at the end of the install, so I thought just jamming/pushing the cable end up into the plastic block (snap in adapter) would be good enough. It was for about 13 months, then it wasn't, so I went back in and fixed it like it should have been in the first place if I had properly followed the instructions.  ::)
..... I got all my projects together that require me to strip the plastics off the bike.  Going to install the Rostra, Fuse Block, Amber LED flashing warning lights, LED spot lights, pig tail for battery tender, pig tail for heated vest, and if I can find a place for my Stebel Nautilus I will install it as well.
That's a good plan, multiple farkles at once is usually a better plan. It does take restraint and mental discipline (resisting the little voice that says "It's good enough, just throw it back together and go ride!").  Since the plastic will be off don't rule out splitting the Stebel into separate compressor and horn unit if that will give you room for your install. If your work area (garage?) is cramped be sure to protect your removed plastics with old blankets as it's unlikely that they won't get bumped at some point. ;)
Offline riverbound51
  • It's all about the ride.
Re: Rostra regrets?
« Reply #7 on: April 10, 2013, 12:52:01 PM »
Works great.  No issues, I would do it again.
2008 Concours 14
Always looking for the road less traveled
www.odysseymotorcycletouring.com
Re: Rostra regrets?
« Reply #8 on: April 10, 2013, 01:52:38 PM »
MGvalerio. 8)
Went to the site and could not find the application you have, can you help us with that? And yes I agree with clowns coming out of a VW when I heard that music.  ;D
Re: Rostra regrets?
« Reply #9 on: April 10, 2013, 01:59:30 PM »
Is that Italian coffee shop music?
Does it attract these types? If so can you give me the name of the CD  :D
Re: Rostra regrets?
« Reply #10 on: April 10, 2013, 02:03:46 PM »
Except she is not Italian.......but extremely hot!!!!
Offline TJ
Re: Rostra regrets?
« Reply #11 on: April 10, 2013, 06:47:08 PM »
How much do you think the average shop would charge to install a Rostra kit?
2012 Black Kawasaki Concours
Re: Rostra regrets?
« Reply #12 on: April 10, 2013, 06:55:19 PM »
I paid a shop 5 or $600 to install it, 4 years ago.   I gave them the installation instructions from BDF on  this site.  They understood the basic install concept, but needed the instructions to do.  I have had zero problems since it was installed.
2008 Concours 14
Re: Rostra regrets?
« Reply #13 on: April 10, 2013, 08:37:10 PM »
Thanks for that post.  Will make me feel better tackling this project knowing how much I am saving.
Offline MGvaleri
  • Country: it
Re: Rostra regrets?
« Reply #14 on: April 10, 2013, 09:43:46 PM »
http://youtu.be/oMxIg5uXcTA
MGvalerio. 8)
Offline MGvaleri
  • Country: it
Re: Rostra regrets?
« Reply #15 on: April 10, 2013, 09:45:34 PM »
 :cool: :cool: :cool: :rotflmao:
MGvalerio. 8)
Re: Rostra regrets?
« Reply #16 on: April 11, 2013, 05:32:35 AM »
[throttle lock]  MGvalerio. 8)
That is not a cruise control.  Not even close.
Offline MGvaleri
  • Country: it
Re: Rostra regrets?
« Reply #17 on: April 11, 2013, 08:17:08 AM »
That is control.  :cannon: Not even close. :cannon:
MGvalerio :popcorn:
Re: Rostra regrets?
« Reply #18 on: April 11, 2013, 11:54:49 AM »
I wish I could have done it.  It was a bit intimidating for my knowledge of motorcycle repair.  It took the mechanic who does this kind of stuff for a living somewhere around 6-8 hours, if I remember correctly.  I was worried I would start it and then have to take the bike and a box of parts to somebody for help.  Or worse I would get it all back together and the throttle would stick open.
Good luck. It is a nice addition to this bike.
2008 Concours 14
Offline GMan
Re: Rostra regrets?
« Reply #19 on: April 22, 2013, 10:22:25 AM »
Thanks, everyone.  Installed it over the weekend with no major issues (although it's amazing how much better it works if you actually connect the ground wire).  I'm quite pleased with it so far.
