Author Topic: Hella twin-tone horn  (Read 2687 times)
Offline jtk1531
  • Country: my
« on: April 07, 2013, 06:38:32 AM »
finally managed to replace the original horn which everyone on the road was ignoring anyway.
bought a Hella twin-tone set, comes with 2 snail type horns + one 30amp relay. used it in various cars and bikes for the past 6-7years without any problem. air-horns are difficult to find here, and i don't want to deal with international shipping if i can avoid it.
couldn't bear the agony of removing the side fairing again, so i installed it at the same Y bracket that the original horn was mounted.
plenty of clearance from the top of the front mudguard.
L shaped terminal connectors are definitely required as there isn't much clearance between the plastic guard (lower triple-tree) and the horn. i didn't want to bend the horn terminals. i used the yellow connector with the insulated portion cut off.
some pics of how it was mounted attached.
14 gauge wire used, instruction sheet says 16amp fuse required.
Offline Phil
Re: Hella twin-tone horn
« Reply #1 on: February 15, 2014, 11:21:26 AM »
I had looked at the Hella horn kit was was concerned with the thickness of the horns hitting the fender if the shocks ever bottomed out.  After researching it more, I found the Stebel HF/2 hi/lo horn set, which is made up of Stebel HF80 340Hrz & HF80 430Hz horns.  They are thinner by 44 mm and draw
I found this set had a thinner profile, draw 3 fewer amps, and are actually louder by 2 dB.  Here are the specs of 3 horns.
Comparison Specs:
Stebel Nautilus Compact Air horn
Stebel HF 80/2 Twin electric
Hella Twin-tone Horn Set
Stebel Nautilus Compact Air Horns (Model 11690051)
Loudness:  115 dB
Tones:  530 Hz & 680 Hz.
Current:  18 Amps
Dimensions:  150 x 112 x 95mm
Located behind the radiator, or stuffed up high and mounted on
the forks.  Note: Lack of a suitable location will lead to loss in effective loudness.
Stebel HF 80/2 Twin electric horns
Loudness:  112 dB
Tones:  340 Hz & 430 Hz
Current:  9 amps (pair)
Dimensions:  38 mm x 80mm diameter   (Measured)
Located at factory horn location
Found on ebay for $40 for the pair separately.  Murphs Kits $39.95.
Hella Twin Tone Horn Set
Loudness:  110dB
Tones:  400 Hz & 500 Hz
Current:  12 amps (2 x 72W)
Thickness:  82mm
Sources
Stebel: http://www.stebel.it/public/stebel.pdf
Hella:  http://www.myhellalights.com/index.php/default/horns/twin-trumpet-horn/
« Last Edit: February 15, 2014, 11:57:31 AM by Boston Bagger »
Phil, aka Boston Bagger
2010 Concours 14, 2008 BMW K1200GT, 2007 BMW K1200GT, 2004 BMW R1150RT, 2001 Harley ElectraGlide STD., 1999 Honda Shadow 750 ACE, 1971 Yamaha 360 Enduro RT-1,  1968 Yamaha 125 / 175 Enduro AT-1, 1963 Honda 250 Scrambler
