Author Topic: Anybody mount the Tankslapper 3M protectant stuff to 2nd gen C14 bags?  (Read 8352 times)
Offline PlaynInPeoria
I can't get the wrinkles out and I don't think it's just me. I would avoid the 3m, maybe their other product, known simply as Tankslapper, is better but the 3m stuff just plain will not lay flat and I don't see how it possibly could.
Just curious what other foiks results are?
Offline BackInTheSaddle
Re: Anybody mount the Tankslapper 3M protectant stuff to 2nd gen C14 bags?
« Reply #1 on: February 10, 2013, 04:32:24 PM »
Did you try warming the film with a hair dryer as you applied on contours?
Don, Apple Valley, MN
2008 C-14 ABS, AeroFlow Tall, Murph's risers with wedges, Buell pegs, Zumo 590, lowered pegs, Russell Day-Long
Previous bikes 2001 Kawi C10 (RIP), and 1981 Honda CB650
http://i879.photobucket.com/albums/ab353/DonaldHollinger/MOTO/Map_zpse09bb1e5
Offline Broz
« Reply #2 on: February 10, 2013, 06:53:49 PM »
It just requires pulling and tugging and patience. A second set of hands help too. Start on top work your way forward and down. It helped having someone keep it from sliding down while pulling horizontally.  Do that and work it down slowly. I struggled w some of the other pieces but those were not that bad.  Be sure you are using lots of soapy water.
Semper Fi
Broz
2012 C-14.  Black
« Reply #3 on: February 11, 2013, 04:53:05 AM »
You gotta get that stuff, and the bags, warmed up to get it applied correctly.
« Reply #4 on: February 11, 2013, 10:11:06 AM »
Do you mean this stuff: http://www.ebay.com/itm/Kawasaki-Concours-14-Hardbag-Reflective-Decals-GTR1400-/120698504920
Because I put these on and had no problem what so ever.
Offline rwilliamm
  • 2012 Concours 14 ABS
« Reply #5 on: February 11, 2013, 03:47:34 PM »
I used the tech spec tank grip. It has like 6 pieces that go around the tank where you thighs touch the sides and 1 big piece for the tank. Think it looks rather well too. Thought about the tank slapper but decided against it.
« Reply #6 on: February 12, 2013, 11:52:24 AM »
I have excess material. Warming would make the existing material larger. How would this help?
« Reply #7 on: February 12, 2013, 11:53:17 AM »
Everything was inside for days.
« Reply #8 on: February 12, 2013, 11:54:40 AM »
No, I used that stuff (or the tank slapper version of it) and it went on like cake, perfect and easy.  I am speaking of the protective clear film that goes on top of the saddlebags that has to match multiple contours.
« Reply #9 on: February 12, 2013, 11:58:21 AM »
No, that stuff is all flat as a pancake and stiff. That would be very easy.  I am speaking of the 3M material that goes on the top surfaces and wraps both around the edges and down the sides of the bags AT THE SAME TIME.  Take a flat piece of paper and try and bend it around a basketball, you end up with too much material.  Same problem. I talked to the guy on the phone and watched the videos endlessly and followed the procedure as closely as I possibly could. I suppose if I did it 100x I may have better luck, but I only have one bike.  I looked at yours, you have 3 pieces on each side, what protects the surface where your belt bucklet or coat zipper rubs?
I am seriously considering just buying some packing tape. Same concept, petroleum based glue, cut each piece down to fit and wet it down enough on the surface of the bag and on both sides of the tape with the baby oil/water mix, bang, done.
Offline Broz
« Reply #10 on: February 12, 2013, 05:27:02 PM »
PIP. You just have to pull a little.  Start In one place back top of  case and work towards the front and down.  Use lots of soapy water. Keep it wet and squeegee as you go. Trust me I never applied any before my bike. If you can get some one to help you an extra set of of hands help tug while the other squeegee.   You are not going to have extr you are pulling it to take form of the curve and get rid of wrinkles by squeegee as you go.
Semper Fi
Broz
2012 C-14.  Black
« Reply #11 on: February 12, 2013, 06:41:31 PM »
Hey PIP,
If you just want to do the side cases have you seen the TechSpec protection for the bags? It works great IMO for keeping boot scuffs off.  :thumbs:
http://techspec-usa.com/products.php?cPath=475_476
Offline AZ-ZG
« Reply #12 on: February 13, 2013, 08:15:53 PM »
I like my boot scuffs!  8)
Reminds me it gets ridden and not washed.  :P
They usually polish out when I get after 'em!
FWIW mine got a bath today. Yep, it rained!   :D
Good luck!
I live. I ride. I am. ZG14
IBA#53928
« Reply #13 on: February 14, 2013, 06:07:09 AM »
I pulled a little, I pulled a lot, no joy.  You did the exact same stuff on bags?
« Reply #14 on: February 14, 2013, 06:12:27 AM »
Have you tried porn?
« Reply #15 on: February 14, 2013, 07:59:21 AM »
 :rotflmao: :rotflmao:
Offline Broz
« Reply #16 on: February 14, 2013, 05:52:36 PM »
PIP,  yes!
I would go take a picture of it in the garage but you can't tell it's on there......but it is.  Don't get me wrong there is a learning curve.  I bought the entire kit. About 25 pieces and I buggered up one learning. The one that goes on top of gas tank over filler area and covers large area on left and right of the tank.   That was a struggle.  I got a replacement from Lucas for that piece. I am waiting for it to warm up to put on the new replacement and the head light pieces. They have a lot of contour changes and are probably the most difficult to apply.
Semper Fi
Broz
2012 C-14.  Black
« Reply #17 on: February 15, 2013, 09:28:38 AM »
Um, no, why do you ask?  <looks down at palms>
