Author Topic: Speedometer error  (Read 10400 times)
Offline Z71
Speedometer error
« on: February 03, 2013, 07:50:57 PM »
What is the real speed at 90 MPH indicated on C14?
Re: Speedometer error
« Reply #1 on: February 03, 2013, 07:56:08 PM »
85
« Reply #2 on: February 03, 2013, 08:07:46 PM »
Speedohealer or a GPS is your friend.  8)
« Reply #3 on: February 03, 2013, 08:29:16 PM »
Put a 55 on the rear.  Improved everything...
Offline Snibbor
« Reply #4 on: February 03, 2013, 09:31:06 PM »
Offline chap
« Reply #5 on: February 04, 2013, 07:48:20 AM »
I am just about to order new tires for my 2010 Connie. I am ordering the Michelin PR3's. So (you are saying) if I put a 55 tire on the rear the speedo would be closer. Are there any drawbacks to putting this tire on. ie clearance feel etc.
2010 Concours ABS = Blue
2003 Concours - Red (sold)
« Reply #6 on: February 04, 2013, 07:59:21 AM »
Nothing but positive on the 55. Speedo will be closer.
Offline chap
« Reply #7 on: February 04, 2013, 08:00:53 AM »
Then I'll get the 55 tires. Thanks for the advice. It was well timed.
Offline Slideways
« Reply #8 on: February 04, 2013, 08:01:40 AM »
Put a 55 on and still had a speedo reading of 1mph to 2mph higher then the GPS showed. For me that is close enough, as long as I can figure out what the true mph are I can use that info to help answer that age old question, " Do you know how fast you were going?".
By the way, "Faster and faster until the thrill of speed overcomes the fear of death?" is not a good reply to the above question. A friend tried it thinking humor would easy the situation, not so much...
Offline tjpgi
« Reply #9 on: February 04, 2013, 08:08:50 AM »
Noooo! Don't correct anything so when you get asked the question about knowing your speed, you can truthfully answer" Sorry officer, I have no idea". When you contest the ticket in court you can blame it all on mama  Kaw! :thumbs:
2011 GSXR 1000
2009 Concours ABS
1976 KZ900
1991 Sportster XLH 1200
Offline chap
« Reply #10 on: February 04, 2013, 08:22:06 AM »
Great comedy guys. Actually the speedo was close enough for me. I always use GPS speed anyway. It just will slow down the accumulation of miles (km's) on the odometer.
Offline CADMAN97
  • 2010 C14 ABS
« Reply #11 on: February 04, 2013, 09:16:30 AM »
I think the faster u go the more it's off. At an indicated 80 my GPS says I'm doin like 76. At 90 your prob only at 84 or so???  Too cold to test that theory here in the buckeye state, have to wait till the spring thaw ;D
« Reply #12 on: February 04, 2013, 09:18:32 AM »
Better handling and improved speedo accuracy? Ok, next rear tire will be a 55.
Offline PH14
« Reply #13 on: February 04, 2013, 10:37:03 AM »
Actually, if you are going 65 MPH according to the speedometer, but you are really approximately 59.5 MPH due to error, the odometer will be logging MORE miles than you are truly traveling. So your bike will have more miles on it according to the odometer.
I prefer to have an accurate speedo. I installed a SpeedoHealer on my RC51 but haven't yet done it on the C14 but want to.
Offline chap
« Reply #14 on: February 04, 2013, 10:40:04 AM »
Looks like you have a bigger difference than most. You are saying over 5% diff. I see 120 kmh on the speedo and 117 kmh on GPS. That is under 3%. I think 3% is what most I have seen here are reporting.
Offline chap
« Reply #15 on: February 04, 2013, 10:44:22 AM »
Its logging more miles in the original configuration. If you put a tire on that will reduce the indicated speed to the correct value you will also decrease the accumulated miles.
« Reply #16 on: February 04, 2013, 10:45:57 AM »
I'm seeing about 5% as well. 79 on my speedo is 75 on my GPS.
« Reply #17 on: February 04, 2013, 10:48:13 AM »
We had this discussion once or twice before. If I remember correctly, the speedo is off but the odo is not.
« Reply #18 on: February 04, 2013, 10:55:42 AM »
Hmmmmm... I'm going to have to check that out.
« Reply #19 on: February 04, 2013, 10:59:30 AM »
Let us know, I'm pretty sure that I'm remembering correctly.
