Author Topic: Running pigtail for Battery tender  (Read 14627 times)
Offline Broz
« on: January 27, 2013, 03:18:26 PM »
Gents,
Was wondering if you could advise on the easiest way to run a wire from the battery to some easily accessible/ tucked away place on the C14.  I also plan on using it for a small air compressor in the event of a flat. It requires access to a 15amp fuse (so i figured wire straight to battery) and will easily blow the 5 amp accessory outlet. Thanks for your help.
Semper Fi
Broz
2012 C-14.  Black
Re: Running pigtail for Battery tender
« Reply #1 on: January 27, 2013, 04:12:56 PM »
Gents, Was wondering if you could advise on the easiest way to run a wire from the battery to some easily accessible/ tucked away place on the C14.  I also plan on using it for a small air compressor in the event of a flat. It requires access to a 15amp fuse (so i figured wire straight to battery) and will easily blow the 5 amp accessory outlet. Thanks for your help.
My Battery Tender Jr. came with a pigtail and it hooked right up, perfectly.  One to the frame and one to the hot on the battery.  Then route it out the side, above the oil tank (as indicated).  Comes with a cap when not in use, and doesn't get in the way or even show all that much.  No drilling, no cuts, no mods.
Offline Broz
« Reply #2 on: January 27, 2013, 04:40:35 PM »
Thanks Max. I didn't think I could get it out the battery box area.  Thought I would have to run it thru the fairing up towards the handle bars.
Semper Fi
Broz
2012 C-14.  Black
« Reply #3 on: January 27, 2013, 04:54:02 PM »
Yeah, I was all ready for a major fight and BAM, it was done.  That doesn't happen all that often :)
« Reply #4 on: January 27, 2013, 05:32:43 PM »
Just be careful when routing the wiring, be careful not to pinch anything. I also did mine exactly like Max, works great too.
« Reply #5 on: January 27, 2013, 05:59:09 PM »
Offline Scaffolder
« Reply #6 on: January 27, 2013, 06:12:14 PM »
I traced mine towards the back tracing the shape of the battery covers. Then I use the cap strap to hold it to the brake lines, beside the frame, near the foot peg.
Joel from Maine.
« Reply #7 on: January 27, 2013, 06:20:53 PM »
Mine bikes don't stay parked long enough, my battery tender is a dust collector
Offline Scaffolder
« Reply #8 on: January 27, 2013, 06:37:21 PM »
Must be nice!!
Joel from Maine.
Offline dolomoto
  • '08 C14 "Hot, Nasty, Bad-Ass Speed"
« Reply #9 on: January 27, 2013, 07:54:15 PM »
I run my heated vest off the battery, it exits the battery compartment on the left side and the lead tucks nicely inside part of the subframe. There is room to get another wire for a battery tender thru the same routing.
Forget those who say they ride too much to need a battery tender. I ride quite a bit myself but there is no harm in using a modern battery tender on our batteries...in fact, it appears a well-conditioned battery will give you max life.
YMMV.
« Reply #11 on: January 28, 2013, 06:57:50 AM »
Max, why to the frame instead of the negative terminal?
« Reply #12 on: January 28, 2013, 07:06:26 AM »
YMMV.
I agree but I usually ride every day!  And my C14 battery is 2 years, 11 months old. Its been through arctic conditions of the rockies, summer heat pf the Phoenix desert, and my hot garage in FL.  Still kickin' it!  Although my Tundra needs a new bat.  Of course it sits longer than the Connie =)
« Reply #13 on: January 28, 2013, 08:36:36 AM »
+1 I still have the 3 year old OEM battery and no problems. If I have to replace it this year, so be it. That said I have a hot wire running up to and under the right top fairing to an accessory relay (some day I'll put a fuze block in there) but if I were to put a battery tender pig tail that's where I'd put it.
Offline Broz
« Reply #14 on: January 28, 2013, 09:04:00 AM »
My main reason for the pigtail isn't for the battery tender (because I ride about 5 days a week) but for the portable air compressor, so I can quickly access a power source that will not blow the 5 amp accessory outlet.  Looks like the easiest fix is what several have already stated, right below the battery box.  If I was going to pull the side fairing off and gas tank maybe there are a few better locations.
Still interested in seeing what most guys are doing.
Semper Fi
Broz
2012 C-14.  Black
« Reply #15 on: January 28, 2013, 09:16:54 AM »
Well ok then. That's what my accessory relay is for. It powers my Rostra cruise control and I re-wired my accessory socket to that relay so I could also power a portable compressor.
Offline Broz
« Reply #16 on: January 28, 2013, 09:31:35 AM »
So did you replace the wire that runs to the accessory outlet with a larger guage wire, and larger fuse?  What is "your accessory relay?"  how difficult a job is this?  Pigtail to the battery box and splicing a 2 pin SAE onto the aircompressor instead of cigarette lighter attachment seems pretty easy, than you kill 2 birds w/ 1 stone.  I ask because I dont have a clue about most electrical wiring, not because I'm questioning your methods.  One thing I have realized is I will probably eventually want a Fuzeblock for the eventual farkels.  Thanks,
Semper Fi
Broz
2012 C-14.  Black
« Reply #17 on: January 28, 2013, 09:52:29 AM »
So did you replace the wire that runs to the accessory outlet with a larger guage wire, and larger fuse?  What is "your accessory relay?"  how difficult a job is this?  Pigtail to the battery box and splicing a 2 pin SAE onto the aircompressor instead of cigarette lighter attachment seems pretty easy, than you kill 2 birds w/ 1 stone.  Thanks,
Used a 12 volt 30 amp auto relay from O'Reilly's. Heavy gauge wires directly to the battery (I don't remember exactly what gauge). Then I used the original outlet connections to activate the relay. Then heavier wires from the relay with a 15 amp inline fuse to the outlet. The Rostra has an inline fuse as well. I also hard wired a micro USB adaptor to power either my phone or my Garmin gps all to that same relay. Like I said, someday I will replace all that with a nice Fuze Block.
Something like this one: http://www.oreillyauto.com/site/c/detail/BWD0/R4176/N0956.oap?ck=Search_relay+kits+-+universal_-1_-1&keyword=relay+kits+-+universal
With a connector: http://www.oreillyauto.com/site/c/detail/BWD0/PT193.oap?evaritm=BWD%2B--%2BR4176&rpl=1
« Reply #18 on: January 28, 2013, 09:59:31 AM »
Since I was installing the relay for the Rostra anyway it was a no brainer to use it for my other accessories as well.
Offline Stretch
« Reply #19 on: January 28, 2013, 11:45:48 AM »
Powerlet has an outlet that can be attached to the rear frame above the passenger foot pegs that works real well.  Direct wiring to the battery with an inline fuse.  A bit costly but well worth it.  Run battery charger off it and heated clothing if I want.
http://www.powerlet.com/shop-by-vehicle/kawasaki/2011/kawasaki-concours-gtr1400-14-2007-present/1/1#formtop
