Author Topic: Brake and clutch fluid replacement  (Read 10990 times)
Offline Z71
« on: December 22, 2012, 03:31:20 PM »
This week I changed the brake and clutch fluid on my '09C14 for the first time.  After I removed the front brake and clutch master cylinder metal covers and plastic/rubber gaskets, there was another piece of what looked like styrofoam floating in the brake fluid.  What is the purpose of this piece?  Maybe to help prevent splashing of the fluid inside the reservoir?  I have not seen anything like this on any other bike before.
Also, is it better to use Kawasaki brand DOT 4 brake fluid?   Someone told me it has some additives that are better for motorcycle use.  Is this true?  I typically use Carquest brand DOT 4 brake fluid.
Re: Brake and clutch fluid replacement
« Reply #1 on: December 22, 2012, 06:42:24 PM »
The white piece of plastic floating in the reservoir is to keep the fluid from sloshing inside the reservoir so badly that the master cylinder could such in an air bubble. That sure isn't likely to happen unless the bike is upside down (at which point sucking in a small amount of air into the clutch or brake system is the least of your concerns) but the plastic reduces the odds even more.
You can use any brand / type of DOT 4 brake fluid you want or have access too. But this is the first time I have seen the 'oil / tire thread' type of debate used for brake fluid.  ;)  Kawasaki does not make brake fluid so it is very unlikely that they have the best / magic formula for the brake fluid used in their bikes. Besides, even if that were the case, perhaps Honda brand brake fluid has even more of the special motorcycle agent in their re- branded brake fluid.  ;D
Offline Z71
« Reply #2 on: December 22, 2012, 07:12:26 PM »
Thanks, I did not believe the story about Kawasaki brake fluid being any better in the first place.  The only thing worth mentioning about the brake fluid replacement here is that one has to be careful not to overtighten the master cylinder reservoir cover screws.  These reservoirs are plastic and it is easy to strip the threads (unless there are metal inserts in there, but I did not see them).  All other bikes I own have all aluminum reservoirs and you can tighten the screws a bit more.
And it took just over a pint of brake fluid to do the job.  So you should get a quart of brake fluid to be on the safe side.
« Reply #3 on: December 22, 2012, 07:48:03 PM »
There are metal nuts (easy boys!) in the reservoir so over tightening the cap is not much of a problem. That said, it really does not need to be very tight as it seals very easily. I tighten the screws in my reservoirs by using a #2 driver and holding it by the shaft alone (again, easy boys!)- I don't even bother to use the handle at all. That has been tight enough on my bike for over five years now.
Offline MGvaleri
  • Country: it
« Reply #4 on: December 23, 2012, 11:06:01 AM »
Offline JerBear
« Reply #5 on: December 24, 2012, 11:51:56 AM »
I know everyone has a favorite type/Brand of fluid, this is what I use and it is working well and priced right at 6 bucks a quart for a synthetic.  The only minus it has is that it is basically clear and so it's hard to check during the year, you do know when to change it though.
http://www.farmandfleet.com/products/588247-valvoline-synthetic-dot-3-and-4-brake-fluid.html#.UNijOqX3Bjc
2008 C14 Non-ABS
« Reply #6 on: December 24, 2012, 12:23:04 PM »
I use Kawasaki's brand as I don't want to mix fluid brands.  Just make sure it's DOT4 compatible.   I'm not sure how it can be both, though.  We had a big discussion on this awhile back on the various nuances...
Ah, found it....
http://www.zggtr.org/index.php?topic=9720.msg118283#msg118283
Offline Z71
« Reply #7 on: December 24, 2012, 01:05:24 PM »
Mixing the fluid brands would not be an issue in my case, as I used enough brake fluid to COMPLETELY flush the system and  replace all of the old fluid.    Either way, mixing different brands of DOT4 would not cause a problem.   Some time ago I had a question on another bike forum about mixing synthetic DOT 4 brake fluid with non synthetic DOT 4.  It is non issue again if you replace all of the existing fluid.
Offline Cheesecake
« Reply #8 on: December 24, 2012, 02:35:02 PM »
Some are careful--me--with those screws on the reservoirs. Others, mount GPS and Radios on them. Anywhere you can put a screw, some guy is trying to mount something there.
2008 C-14
Offline JerBear
« Reply #9 on: December 24, 2012, 03:33:13 PM »
awfully close to the censers kicking in there.  Lets keep it pg rated
2008 C14 Non-ABS
Offline tjpgi
« Reply #10 on: December 24, 2012, 09:08:29 PM »
2011 GSXR 1000
2009 Concours ABS
1976 KZ900
1991 Sportster XLH 1200
« Reply #11 on: December 25, 2012, 06:44:27 AM »
awfully close to the censers censors kicking in there.  Lets keep it pg rated
FIFY  ;)   Merry Christmas to all!
Offline JerBear
« Reply #12 on: December 25, 2012, 07:01:26 AM »
And a Merry Christmas to you as well VJ.  Thanks for correcting my poor spelling  :)
2008 C14 Non-ABS
« Reply #13 on: December 29, 2012, 08:27:46 AM »
I go %$#^ing nuts on mine too.
MOTUL FTW
Offline reesedp
  • Sail Army
« Reply #14 on: December 30, 2012, 02:37:14 PM »
Ah, found it....
Jim, I think that if you carefully peel the label off of that you'll find an STP label underneath!
