Author Topic: A question for Russell seat owners only  (Read 4311 times)
Offline philipintexas
    • Phils Farkels
« on: December 19, 2012, 09:38:27 AM »
The forward end of the grab-rail is held to the bike with an Allen-head, 8 mm bolt that is barely visible down between the stock seat and the grab-rail on both sides. With the Russell seat in place is that bolt visible, could you reach it with a long Allen wrench with the seat in place?  Since the seat is wider I need to know if that bolt is obscured by the Russell seat. Thanks
Re: A question for Russell seat owners only
« Reply #1 on: December 19, 2012, 03:26:43 PM »
I don't see any bolts on mine where you say to look.  Don't know if taking the side case off makes any difference.  Gotta find my keys to do that and supper is calling...
    • Phils Farkels
« Reply #2 on: December 19, 2012, 03:54:01 PM »
At the front of the grabrails, where the color changes from silver to the black piece the bags attach to, look straight down between the seat and grabrail. The upper bag support (where the latch grabs) even has a rounded recess molded into it for the bolt to come straight up. It is stainless steel with an Allen socket on top and has an unusually large washer under it. There are actually 2 bolts that secure the front end of the grabrail, it's the forward of the two I'm interested in, the rear isn't visible unless the seat is removed. I appreciate your help.
Offline Necron99
    • Facebook Page
« Reply #3 on: December 19, 2012, 04:18:13 PM »
I'm not quite understanding what you're asking, Philip.  If you don't get your answer by the time I get back from Christmas, I'd be happy to ride over with my Russell on so you can look.  I'll be back Wednesday the 26th.
-Dylan Thomas
2010 ZG1400 COG #9384
« Reply #4 on: December 19, 2012, 04:28:23 PM »
Still can't see em....
    • Phils Farkels
« Reply #5 on: December 19, 2012, 05:24:54 PM »
This is the bolt in question:
With the Russell seat in place can you see the bolt looking down between the seat and grabrails as in photo below??
Offline tjpgi
« Reply #6 on: December 19, 2012, 05:28:57 PM »
Phil
Not sure if this will help you but with a Corbin in place there is about a 1/4" space between the outside border of the passenger section and the inside edge of the rail. The bolt can be seen if your looking for it and looking straight down otherwise you would not know it was there.
2011 GSXR 1000
2009 Concours ABS
1976 KZ900
1991 Sportster XLH 1200
    • Phils Farkels
« Reply #7 on: December 19, 2012, 07:43:55 PM »
tjpgi: Thanks, that does help, I'm thinking Russell is maybe the widest seat, but it's good to know the Corbin has a little clearence.
Offline yellowrench
  • COG #10485 2011 C14
« Reply #8 on: December 19, 2012, 08:48:57 PM »
Phil, what are you fixing to make for us?
COG #10485                                                            2011 C14
Offline PH14
« Reply #9 on: December 19, 2012, 09:30:40 PM »
Phil, with a Russel, you can't even see the saddlebags.  :yikes:
« Reply #10 on: December 20, 2012, 04:03:34 AM »
Even with pictures, more explanations.....still can't see em...
« Reply #11 on: December 20, 2012, 05:24:45 AM »
You need more coffee!!!!!  ;D
« Reply #12 on: December 20, 2012, 05:35:10 AM »
or better glasses...  Seriously folks, my Russell is blocking access to those bolts.  Now keep in mind that the passenger area has been setup for my wife so it has the 'wings'.  These wings block access to those bolts.  On my C10, I did not have the passenger area set up so it did not have the 'wings'.  In that case, it could be possible to have access to the bolts.  So you may want to get someone here who has not set it up for a passenger as well to look at the access.
Update:  I took the seat off and found the bolts.  You cannot get to them with the seat on.  The wings obscure the bolts.
« Last Edit: December 20, 2012, 11:48:48 AM by VirginiaJim »
    • Phils Farkels
« Reply #13 on: December 20, 2012, 11:50:17 AM »
Thanks for the replies, actually you answered my question VirginiaJim, there are some seat configurations that cover that screw and that's what I needed to know. Others will not.
Yellowrench: Someone asked about a way to mount an Aux. fuel tank over the passenger's seat, I'm trying to come up with something.
« Last Edit: December 20, 2012, 05:00:53 PM by philipintexas »
