Author Topic: How much fairing removal for new headers?  (Read 4988 times)
Offline Glennn
    • Metric Rider
« on: December 18, 2012, 07:51:25 PM »
Hi All,
Like the title says, how much of the fairing on a 2012 do I have to remove to replace the exhaust headers.  Is it the whole front end, just the lower half, somewhere inbetween..?
Thanks in advance.
1999 Yamaha Road Star
Canberra, Australia
CDA #390
Offline C1xRider
Re: How much fairing removal for new headers?
« Reply #1 on: December 18, 2012, 11:25:36 PM »
If you're good, you don't need to pull any fairings. ;)
I've done it several times.  But then, I adjusted my own valves too.  Yes, I'm that good!  8)
« Reply #2 on: December 19, 2012, 06:34:50 AM »
Couldn't resist Rob. ;D
I swapped headers without pulling the whole fairing off, just loosen up the bottom, have the right tools, and some patience.
Offline JamminJere
« Reply #3 on: December 19, 2012, 06:38:36 AM »
That would depend on your hand tools..  The more basic they are, the more fairing you will have to remove. If you have extensions and swivels for your sockets, you may not need to remove much if any to remove the header. But i would remove the lower part of the fairing just to make the whole job go smoother.
JJ
« Reply #4 on: December 19, 2012, 06:55:08 AM »
It all comes down to how much clearance you want to have to do the job.  Personally, I take as much of the fairing off to see what I'm doing as I can.  I don't know about a 2012 model but as long as you document what you take off in what order and keep the screws together you should be ok.  Just remember that there are interlocking tabs all over the place.  It's not a complex job to remove the fairings and you get to see more of the engine that way.
Offline McJunkie
« Reply #5 on: December 19, 2012, 07:08:40 AM »
It's also easier if you remove of loosen the radiator. Not necessary, but easier.
Offline C1xRider
« Reply #6 on: December 19, 2012, 09:30:45 AM »
Not at all Tom, but after all the BS about ignoring the valves because it's too technical, or dangerous to go inside the engine, I couldn't resist.
« Reply #7 on: December 19, 2012, 09:58:50 AM »
If you got it, flaunt it!    ;)
Offline Glennn
    • Metric Rider
« Reply #8 on: December 19, 2012, 03:01:07 PM »
G'day Everyone,
Thanks for the replies.  It's not that I am adverse to removing the fairing, just don't want to go all gung-ho and tear the entire thing off only to find out I just needed to remove the bottom. I'm a believer in that no matter how careful you are, every time you pull something off a bike there is a small chance of something going wrong when you put it back on.
So looks like getting the bottom off at least is worth doing and loosening the radiator.  Can you remove the radiator without having to drain/refill it?
(Yar yar I know, get a manual.  I am, but it won't be here in time)
Oh and maybe last question, seeing as a few of you have done the headers - any hassle/tricks keeping new header gaskets in place while installing the headers, or is it a non-issue?
Thanks again, folks.
Canberra, Australia
CDA #390
Offline Spanky
« Reply #9 on: December 19, 2012, 03:22:05 PM »
Dab a little oil on the new gaskets and they will stay in place much better.
Offline C1xRider
« Reply #10 on: December 19, 2012, 11:05:32 PM »
I didn't have any problems with the gaskets on mine.  They stayed in place and didn't cause any trouble.
In fact, I was going to say 'what gaskets?'   ;)
Offline JamminJere
« Reply #11 on: December 20, 2012, 04:44:53 AM »
If the copper gaskets at the exhaust port dont fit tight enough and want to fall out before you can get the header installed, as Spanky mentioned, a little oil, or grease, can give it the stiction needed to hold it in place until the header is installed. Also a wrap or two of scotch tape around the outside center diameter will also snug it up in the head and will melt and burn off almost instantly on startup.
JJ
Offline cablebandit
« Reply #12 on: December 20, 2012, 06:38:49 AM »
It only takes about 5 minutes to remove the fairings once you've done it.  Just start from the top and move down.  Easy Peasy.
Offline Glennn
    • Metric Rider
« Reply #13 on: December 20, 2012, 04:15:53 PM »
Excellent thanks, Guys!
Canberra, Australia
CDA #390
« Reply #14 on: December 20, 2012, 06:30:30 PM »
5 minutes off, 2 hours back on.... :rotflmao: ;)
Offline cablebandit
« Reply #15 on: December 21, 2012, 07:01:22 AM »
It's just a matter of insert tab A into slot B, not rocket surgery.
« Reply #16 on: December 21, 2012, 07:05:40 AM »
It can take that long if you forget about the tabs and get it all back together and have to do it again.  Don't ask me how I know this.
« Reply #17 on: December 21, 2012, 07:09:05 AM »
Especially if one forgets to plug in the turn signal on one side.
Don't ask me how I know...
« Reply #18 on: December 21, 2012, 07:37:39 AM »
Yep, that's a good one.  Got the T shirt for that.
« Reply #19 on: December 21, 2012, 05:32:32 PM »
I have done the same thing, if you take them off enough it is bound to happen.
