Author Topic: Throttle body Sync. ?  (Read 9036 times)
Damaged Goods
« on: December 06, 2012, 04:38:38 PM »
Was at my local dealer today talking to them about services that may need to be done, and they told me that I needed a throttle body sync. and that it was pretty important to do this. Has anyone else had this done and is it a necessary, or are they just blowing smoke trying to get more money out of me for this. Additional $250 for this sync.
Offline CigarSki®
  • Newb again?
Re: Throttle body Sync. ?
« Reply #1 on: December 06, 2012, 05:00:41 PM »
I would wait until "valve check" time. Do the valves, spark plugs, throttle body sync and tighten exhaust headers all at once. The plastics have to come off, may as ell do it just once.
Wayne Sikorski aka CigarSki
2010 ZG1400 - South Jersey
COG 9250
« Reply #2 on: December 06, 2012, 05:01:51 PM »
model? year? mileage? undue vibration? poor running?
Did they explain why your bike needed a sync? If that important did they tell you the dire consequences if you don't do it?
« Reply #3 on: December 06, 2012, 06:59:46 PM »
Doubt it needs it.
Damaged Goods
« Reply #4 on: December 06, 2012, 07:01:55 PM »
09, C14, 22k miles, no vibrations, runs great, no issues that I know of. I commute 100+ miles a day and it seems to run like a top. I do all of my own service and try to stay up with Kawi recomendations as much as possible, or what makes sense.
« Reply #5 on: December 06, 2012, 07:08:49 PM »
That is the best mind set to have.
« Reply #6 on: December 07, 2012, 03:29:42 AM »
Damaged Goods
« Reply #7 on: December 07, 2012, 06:21:20 AM »
Thanks Pokey and The Pope. I think I will buy the tools and attemp to do this myself as I am a do it myself kind of person. Thanks for the links and I will let you know how it turns out in a couple of weeks.
Offline McJunkie
« Reply #8 on: December 07, 2012, 09:56:14 AM »
I would buy some Vacuum hose (I believe it's 4 mm) then install it on each throttle body and leave it there when you are done with the sync. Route them together and cap them off when you're done and then they will be there when/if you want to do it again.
« Reply #9 on: December 07, 2012, 12:00:12 PM »
+1 .... And mark them so you know which one goes to which port.
« Reply #10 on: December 07, 2012, 01:40:57 PM »
A guy on the COG forum sells a nice metal plate with ports for the vacuum tubes so that the Sync is always easy and it looks like a good functional mod.
If it idles smooth and has no vibration then it sounds like an attempt to drum up business...
Offline connie and me
« Reply #11 on: December 07, 2012, 06:47:35 PM »
Yes!!! did this on my old Vstrom 1000, which was sort of difficult, until i met this bike! future synthcs are super easy when exstensions are on.
2012 Black
« Reply #12 on: December 07, 2012, 10:09:54 PM »
I did the sync because I needed to jack my idle up to 1400 to prevent stalls. If you don't have any driveability problems I would not bother. It is not easy to do. In addition to the other tools mentioned you will need an inspection mirror to see the adjustment screw and then learn to manipulate the 90 degree screwdriver in reverse. It will also help to grow a third arm.
« Reply #13 on: December 08, 2012, 01:00:59 PM »
This member sells the plate I mentioned
http://www.zggtr.org/index.php?action=profile;u=468
« Last Edit: December 08, 2012, 04:50:55 PM by 556ALPHA »
Offline gildaguz
« Reply #14 on: December 09, 2012, 02:02:31 PM »
My 09 has already 27 k and idle perfect at 1100 rpm, planning to do some maintenance now when the temperatures are lower ,air filter, valve lash check and spark plugs, has any one done this work at this mileaje and replaced the valve cover gasket? does any one have a link where i can print a blank  for the valve lash shim map ?
Thanks
« Last Edit: December 09, 2012, 07:51:12 PM by gildaguz »
2009 Non ABS Concours Black
2004 Honda Shadow  Sabre 750
1979 Suzuki 185 all terrain
Offline Cheesecake
« Reply #15 on: December 21, 2012, 12:15:33 AM »
Here is a good shim map from Fred Harmon. It includes, on the center tab, all the different shim sizes. My #1 recommendation, don't do any conversions from metric/inches. Get feeler gauges in metric sizes, in .01 mm increments.  The shims come in .025 mm increments, if you use feeler gauges with .025 mm increments you may find the valves still out of spec after you put the cams back in. I did.
2008 C-14
« Reply #16 on: December 21, 2012, 05:37:02 PM »
Thanks for the link. A source for .01 mm feelers would be even more appreciated! I have spent hours searching online without finding any.
« Reply #17 on: December 22, 2012, 12:11:10 PM »
interesting note,
I couldn't find feeler in .025mm increment nor would I want them anyways.... oh wait, I have some....(.025mm = .000984") ::) ;D
based on the feelerstock available, the smallest metric measurment you can access is .03mm...
why don't they make metric feeler stock less than .03mm????
.03MM= .00118"
.04MM= .00158"
.05MM= .00197"
.06MM= .00236"
.07MM= .00276"
.08MM= .00315"
.09MM= .00354"
.10MM= .00394"
.15mm= .00591"
most sets all jump to .05mm increments (.002") from .15mm to .60mm
http://www.mcmaster.com/#metric-feeler-gauges/=kpesol
individual feeler stock:
http://www.mcmaster.com/#feeler-gauges/=kpf980
as long as I can use my brain, and simple math, I will still use my inch feeler sets, and individual strips i have purchased in inch increments, which will let me measure .0005"  ;)
besides that, my micrometers measure to the .0001", and that works for me also... ;D I use it to measure the shims....and also the thickness of the head on the buckets the cam lobes push on....... ;)
