Well being quite the Oxford heaterz fan, I figured that would be what I would "finally" be installing on the C14. Decided to go with Moose grip heaters, "made by Symtec" and they were a whopping $38 at the Iron Pony. I bought some bullet connectors at Home Depot because I did not want to cut or possibly make shorter the accessory leads. I tried really hard to salvage the grips, but seems the glue collected heavily in one place, and they were EXTREMELY hard to get off without damaging them, needless to say they got cut off. I was hoping to simply slip my grip puppies over the heaters, but they were too big without grips to go over. Bought a 3/4 inch hole saw bit and drilled right into the center of the dash plug, only had to slightly make it a bit bigger with a utility knife so that I could get the rocker switch flush. Routed everything real factory looking I must say, and fired up the bike. HOLY CRAP these things get hot, I was amazed. I actually wrapped electrical tape over both grips, then once I applied the heat tape, I then secured them a bit better with some more tape. So off to the Iron Pony in the morning to buy some cheap grips, hopefully the grip puppies don't stop the heat from coming through too much. I had Oxfords on my Vstrom and I used them allot, how I went without this long on the C14 is quite astonishing.
