Author Topic: Main battery  (Read 5396 times)
Main battery
« on: November 27, 2012, 09:01:17 AM »
The skyrich battery I bought about a year ago seems to be crapping out early. I could not find any batteries at Murphs as listed in the Wiki.  I looked at the Westoc website and it looks like they have been bought out and not the same quality. PLus there battery finder kept pulling up batteries for different bikes. I am considering this  Scorpion: http://www.batterystuff.com/powersports-batteries/sYTX14-BS.html
Has anyone tried it?
Offline chap
Re: Main battery
« Reply #1 on: November 27, 2012, 11:27:09 AM »
I guess the trick with batterys is that they have to be properly conditioned when new. Don't expect to show up at the store and just take it home. if you do the life will be greatly reduced. A good battery shop will condition it for you and you pick it up the next day. Also if your bike is out of use for a while it should have the battery on a maintenance charger to keep it healthy.
2010 Concours ABS = Blue
2003 Concours - Red (sold)
Offline C1xRider
Re: Main battery
« Reply #2 on: November 27, 2012, 12:20:14 PM »
Bought my last few batteries from Amazon sellers.  Shipped to my door new, with electrolyte in a separate container.  Activate them when ready to use them, and you know the initial charge was done correctly if you do it yourself (and follow directions).
I've started buying the Yausa high end batteries with the Sulfate Stop additiive.  Since sulfation is the primary killer of batteries, I expect it will make them last much longer, easily justifying the slightly higher price.
Don't know anything about the batteries in your link though, sorry.
Offline reesedp
  • Sail Army
Re: Main battery
« Reply #3 on: November 27, 2012, 02:09:50 PM »
Auto-zone sells a conditioned AGM battery for our bikes ready to go.  At least they did here.
Re: Main battery
« Reply #4 on: November 27, 2012, 05:12:01 PM »
That is good to know, will give them a check when I am ready.
Re: Main battery
« Reply #5 on: November 28, 2012, 04:10:09 AM »
And that would be?
Offline scav8tor
Re: Main battery
« Reply #6 on: November 28, 2012, 08:28:40 PM »
How about a link to the battery on AutoZone?
Any ship can be a minesweeper once.
Offline Z71
Re: Main battery
« Reply #7 on: November 29, 2012, 07:46:56 PM »
I recommend Yuasa batteries (genuine Yuasa, not look-alikes).  You buy them dry, with the electrolyte packaged separately.   If you follow the filling instructions they tell you to let the filled battery SOAK for at least an hour before charging.   Check the electrolyte level after the soaking time and top off as necessary before sealing the battery with provided strips.  Generally freshly filled batteries will not need much charging and using a fully automatic trickle charger is the best way (1 to 1.5 Amps charging current).   Do not use higher than 2 amps charging current or you will shorten the life of the battery.  Concours C14 needs a BS-14 size Yuasa battery.
Re: Main battery
« Reply #8 on: November 29, 2012, 09:56:35 PM »
When I had a Strom I got a battery from Napa, filled it up and charged it. Worked great! Think I will go to Batteries Plus for the C14, hear great things about them.
Re: Main battery
« Reply #9 on: November 29, 2012, 11:10:27 PM »
Good luck with it.
I keep the battery in my KiPass fresh, and haven't had to replace the big battery  :D
Re: Main battery
« Reply #10 on: November 30, 2012, 06:36:55 AM »
Good luck with it.
Thanks, I like that plan, much cheaper!
Offline Shoe
Re: Main battery
« Reply #11 on: November 30, 2012, 08:43:39 AM »
Have you tried Walmart?
Eat corn. Drill for oil.
2008 Concours, 2010 Goldwing
Offline sf bay rider
  • Humble student of the ZG1400
Re: Main battery
« Reply #12 on: November 30, 2012, 09:21:34 AM »
I agree with those who recommend the Yuasa batteries. I have a couple on stanby for the Connie and the Voyager 1700.
$73.00 via Amazon.
Happy Holidays to all!
Jack
Jack
2014 Red ZG1400CEFL
Offline Cheesecake
Re: Main battery
« Reply #13 on: December 01, 2012, 11:51:59 AM »
The C-14 has always come from the factory with an AGM absorbed glass mat battery. AGM batteries have no overflow tube or openings for liquid. They can be shipped USPS because they are not liquid and can be stored upside down without leaking. I would never put a liquid acid battery on a motorcycle again given the choice, the acid overflow tube can be accidentally knocked off and the acid removes all paint on the frame below. And if the tube does ever work as planned, the acid coming out of it will be slung from the back tire onto everything nearby.
I use the MBTX12U Battery. 14 Amp, 200CCA AGM. Available at amazon, ebay, even sears. I paid about $80. They are yellow, have two extra connections for accessories. And they have threaded holes in the connections for direct bolting, instead of that old square nut balancing act that you have to do with the Scorpion or Yuasa, blindly trying to lift up/place the nut while turning the bolt, dropping the nut into the frame lost forever, where do you buy square nuts? Why would you put up with that?
2008 C-14
Re: Main battery
« Reply #14 on: December 01, 2012, 01:47:17 PM »
YEP...
BEST BATTERY DEAL OUT THERE..... ;)
well, maybe....they DID get it to me within 72 hours, and it was fully charged.....
http://www.zggtr.org/index.php?topic=10869.msg133292#msg133292
go for it....at that price it's a win... ;)
when I bought mine I called them and asked about the age/when it was activated/conditioning thing, and they sell only fresh batteries, filled and initially charged prior to shipping....i stuck my tender on it for giggles, and it registered fully charged right off.
Re: Main battery
« Reply #15 on: December 03, 2012, 05:19:41 PM »
Thanks for the replies all!
Re: Main battery
« Reply #16 on: December 04, 2012, 08:51:03 AM »
I have a question about the Motobatt. I read some reviews and it  seems to me the extra connectors are intended to make the battery fit more applications rather than connect accessories. Have you actually connected accessories to the unused terminals? It seems to me that could cause electrical problems with the complicated ignition system/KiPass. But I admit electrons still seem like magic to me so I'm probably wrong.
Re: Main battery
« Reply #17 on: December 04, 2012, 03:25:53 PM »
It won't cause any problems, as long as + is to + and - is to -.
Re: Main battery
« Reply #18 on: December 04, 2012, 04:06:41 PM »
While it is always a good idea to question anything that will come into the realm of KiPass (chuckle), it makes no difference in this case. I have been using a Motobatt in my C-14 for a while now and it seems to be a fine battery. As to the assortment of terminal connections, they are only there so the same battery can be used in more vehicles without having to change to a different part number.
