Author Topic: transponder  (Read 6880 times)
Offline CREICH
  • Country: ch
transponder
« on: November 17, 2012, 08:48:03 AM »
Hello friends! I'm very embarassed. After 3 month riding this marcellous GTR , my transponder disappeared .. (lost or probably stolen! there are 2 transponders on my 2008 model, but the first owner crashed one and so I have no second transponder to help me!!! )
the whole system costs about 1600 fr. swiss francs!! I cant afford it
I've benn hoping it would come forward, but nothing after 3 weeks... Could one of you help me ?
MGvalerio left a polemical message on 2012 february 17th saying
 "without the transponder can be set in motion by me" !
that would be great .. in secret anyway!
best regards , hopefully , Christian / Ne - Switzerland
Offline CARLÃO
  • Country: br
Re: transponder
« Reply #1 on: November 17, 2012, 10:03:36 AM »
Welcome, CREICH! Lost you mean... that it felt down while driving?
Re: transponder
« Reply #2 on: November 17, 2012, 10:08:19 AM »
If both FOBs have been lost, I'm pretty sure that you have to replace the ECU.  There is no way to recover, unfortunately.  Possibly a used one might work, assuming that unit has at least one FOB still with it.
Offline CREICH
  • Country: ch
Re: transponder
« Reply #3 on: November 17, 2012, 10:22:14 AM »
yes , both fobs are lost..
 have you ever heard of Motomatrix (UK)?
You send them the ECU
and you get à brand new Code-key + a regular key for 220£ ..
I just found it out through eBay... I'll probably try so and give
the good news to you all, if I come through this way!
I first have to order a new regular key (I found the keynumber in the booklet)
to reach the ECU! is that right?
Offline CREICH
  • Country: ch
Re: transponder
« Reply #4 on: November 17, 2012, 10:29:58 AM »
this forum is great :o !
 It's so amazing to get answers in half an hour from anywhere in this world..!
Thanks to be here! ;)
Re: transponder
« Reply #5 on: November 17, 2012, 10:41:04 AM »
Thank you for being here.  Tell all your friends and neighbors...
Thanks for the tip on the ECU.  :thumbs:
Re: transponder
« Reply #6 on: November 17, 2012, 11:31:13 AM »
There really isn't any way around a significant cost if you lose all the fobs that function with a C-14. At that point you will need a new KiPass ECU and at least one fob that functions with that new KiPass ECU to get the bike running. You will also need to have the new KiPass ECU programmed to work with the main ECU by a dealer.
As Jim mentioned, you can probably get a used KiPass ECU for a C-14 now but you will have to be careful: I know our (US) main ECU's are different from the ones you have in Europe, and I believe the KiPass ECU's are different as well. That would mean you cannot use a KiPass ECU from a salvage bike in a European bike.
Also note that there are TWO ECU's in a C-14 (or GTR 1400), one is the 'main' ECU that runs the engine and the other one is the KiPass ECU that is used to authenticate fobs and well as work with the tire pressure sensors. Whatever you do, do NOT buy a used 'main' ECU as that will not do anything for you. Also if you do buy a used KiPass ECU, make absolutely sure it comes with at least one functioning fob or it will again be useless to you. I do not know of any to make sure what you buy is a good, working set other than to go by the seller's feedback rating and perhaps do a little research into the seller before buying the ECU (is it a company with some history? Will they take back something if it does not work for you, etc?).
Best of luck getting the bike running again.
Re: transponder
« Reply #7 on: November 17, 2012, 01:00:29 PM »
Thanks, Brian.
Offline CREICH
  • Country: ch
Re: transponder
« Reply #8 on: November 17, 2012, 03:00:06 PM »
Ok ! I won't search for any used ECU / Motomatrix in UK just need my ECU so that they can make you new keys , one wich will be programmed with the original ECU part and anotherone without code..
That's what I read,  inclusive positiv customers appreciations .. :grouphug: :
I'll let you know, (it might be interesting for local dealers... )
Let's see  ::). !
Re: transponder
« Reply #9 on: November 17, 2012, 03:07:08 PM »
Both FOBs must be programmed if they are the large FOBs.
Offline C1xRider
Re: transponder
« Reply #10 on: November 17, 2012, 03:28:40 PM »
For those who are curious (like I was), here is their web site : http://www.motomatrix.co.uk/
Re: transponder
« Reply #11 on: November 17, 2012, 04:23:22 PM »
Seems like the OP might have the wrong idea about the kipass system. The web site sounds like chip embedded keys not FOBs.
Offline C1xRider
Re: transponder
« Reply #12 on: November 17, 2012, 04:29:08 PM »
Don't think so.  If you look at Kawasaki on their "What to send us" page (http://www.motomatrix.co.uk/what.htm#KAWASAKI), they seem to know what they're talking about.
Re: transponder
« Reply #13 on: November 17, 2012, 05:21:51 PM »
They talk about the KISS immobilizer. Not the same as Kipass if my understanding is correct.
Re: transponder
« Reply #14 on: November 17, 2012, 05:32:53 PM »
I've sent a note to them specifically asking if they can work with KIPASS or not.
Re: transponder
« Reply #15 on: November 17, 2012, 05:44:22 PM »
Be interesting to see if they have new fobs to go with the reprog. Look's like they're selling Red and Black key blanks. That system is used on the zx and other lesser models.
Re: transponder
« Reply #16 on: November 17, 2012, 05:57:20 PM »
Lesser, I like that... :thumbs:
Re: transponder
« Reply #17 on: November 17, 2012, 06:04:11 PM »
It is actually the KiPass ECU, the part on the bike, that is programmed, not the fobs or tire pressure sensors. And the KiPass ECU has to be programmed to recognize any fob, large or small (remote or RFID..... fobs containing a battery and those not containing a battery).
Re: transponder
« Reply #18 on: November 17, 2012, 06:30:19 PM »
Agreed- those are systems used on European bikes. Yamaha FJR's have immobilizers in them when they are sold in Europe but not the US. That particular site also references 'red' keys and 'black' keys which sounds like the system Ducati uses and is not similar to KiPass.
KiPass is based on permanently encoded fobs and the bike is programmed to recognize the correct one(s). It is a fundamentally different system that what is commonly used on cars where the key has an chip inside it; those systems have the keys encoded to work with the vehicle unlike KiPass which has a code embedded (called 'hard coded') in each fob when the wafers are cut (the same way each Intel processor has a unique code hard coded into it when the silicon wafer is manufactured).
I won't say something stupid like 'it can't be done' but I doubt that anyone can manufacture / code a remote fob for KiPass without already having a valid for code; in other words, without having a valid fob available. I believe the original idea that goes with KiPass remains- lose the last valid fob and you are off to get a new KiPass ECU and at least one valid fob that goes with that ECU. New KiPass ECU's from Kawasaki come with two fobs because a new ECU without any fobs won't do anyone any good and cannot be used. For anyone interested, there is an abundance of information available about how encryption works generally; KiPass uses Mitsubishi’s MISTY system specifically and there is a fair amount of information about that system available too.
One final, hopefully logical, thought: Is it really likely that some individual hacker, no matter how naturally talented or intelligent, is likely to outwit a system designed by professional cryptographers, likely at least as intelligent and very well schooled on the ways and means of encryption? There are an infinite number of codes that are wrong but only one that is correct and figuring out that one code is not easy nor is there a straightforward method of determining that code as it is truly random.
Offline CREICH
  • Country: ch
Re: transponder
« Reply #19 on: November 18, 2012, 06:48:36 AM »
dear friends, here the answer of Ian ( Motomatrix)  ...
"hello Christian
At the moment we do not cover the kawasaki GTR1400 as this uses a key fob system ... We hope to have this model covered in 2 months time. Regards  ian"
I guess it's quite à serious adress... and
We all need patience don't we?
take it easy!
Christian
