Heard something very odd from my C14 when I started it this morning. Normally I have a routine that goes like this : I gear up w/ earplugs in and helmet on, get on the bike and put the kick stand up, turn on the ignition, put it in neutral, start it and roll it out of the garage to the end of the 20' pad, then close the garage door and put the bike into gear and go.
Today I deviated from that routine a little. I wore a different coat, and grabbed my other garage door opener. When I got to the part where I close the door, it didn't work (that opener has a very short range), so I put the bike into gear and pulled back up to the garage door.
After I closed the door, I started to roll back down to my turn around point, and heard a really loud high pitch whine coming from the engine. It sounded much like the whine the bike always makes when riding (same pitch / frequency), but this would vary from none at all to really, really loud, just by moving the rear wheel a few inches with it in 1st gear, and holding the clutch in.
It took me a few feet of rolling before I realized it was completely dependant on the position of the rear wheel. I stopped at a point where there was no noise, then pushed the bike forward a couple inches, and there it was, as loud as ever. Rolled it back a couple inches, and completely gone.
Since I had just put in a brand new pair of foam ear plugs (nice ones, AO Safety brand 29dB NRR rated, looks like these
http://www.aearo.com/diy/hear_detail.cfm?con_prod_num=92050,%2090594,%2090583&con_family_id=104&con_platform_id=14), I was surprised at how loud the whine was. Compared to how I could barely hear the exhaust, it was loud. The temperature was around 50F, and it seemed to go away once the bike warmed up (at least I didn't hear it later).
So has anyone else heard this type of noise before, that would be output shaft position dependant? I'm thinking it would have to be in the clutch pack or clutch body since that's where the rotating parts were disconnected from the transmission. I will definitely repeat the process the next time I start it too. I'm not too worried about it just yet, more curious than anything.
